Finally building my HTPC (added build pics 9/28/13) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-22-2013, 12:29 PM - Thread Starter
pd veeps's Avatar
I've been playing around with xbmc on my old laptop and finally ready to build my htpc. I just ordered all my components. Can't wait for them all to get here and build this thing.(and cancel my directv). My wife should be happy being able to dvr her tv shows.
1SILVERSTONE ST45SF 450W SFX12V 80 PLUS BRONZE Certified Active PFC Power Supply
$64.99
2ENERMAX UC-8EB 80mm Case Fan
$15.98 for both
1G.SKILL Ripjaws X Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBXL
$44.99
1AMD A6-3500 Llano 2.1GHz (2.4GHz Max Turbo) Socket FM1 65W Triple-Core Desktop APU (CPU + GPU) with DirectX 11 Graphic AMD ...
$64.99
1SILVERSTONE Black Aluminum skin reinforced plastic front panel, 0.8mm SECC body MILO Series ML03B Micro ATX Media Center ...
$59.99
1 BIOSTAR TA75A+ FM1 AMD A75 (Hudson D3) HDMI SATA 6Gb/s USB 3.0 ATX AMD Motherboard
$94.00
1LG Black Blu-ray Burner SATA WH16NS40 - OEM
$64.99
1Sandisk 64GB 2.5" SATA III Solid State Drive (SSD) HGST 0J11563 750GB 5400 RPM 8MB Cache SATA 3.0Gb/s 2.5" Internal Notebook Hard D
$63.00
1 Seagate Barracuda 3 TB HDD SATA 6 Gb/s NCQ 64MB Cache 7200 RPM 3.5-Inch Internal Bare Drive ST3000DM001
$119.98
1. HP USB IR receiver .
$13.99
Already have a Harmony one I bought from a friend for $30 and a HD homerun dual I bought last year for about $70. Also have Windows 7 from my broken laptop.
Any recommendations on using this setup as some type of nas server? I would like to access movies and recorded tv shows from iphone or android tablet.
Ended up spending more than i wanted but I I got some decent deals.
******Added build pics 9/29/13******
Parts came in and I put it together late last night. Took my time as I've never build a pc before. Ended up putting both hdd under the optical drive because of power cord length. Good news is I have room to add another 3.5 hdd in the future! Fired right up. Got windows installed. Runs cool and seems pretty quiet. My old dell laptop is louder. I will update all the drivers, etc tonight and hopefully have WMC ready to go. Anyone know where I can by a filer to but on the right side of the case where the fans are to reduce dust intake?
pd veeps is online now
post #2 of 5 Old 09-23-2013, 12:45 AM
ikkuranus's Avatar
Quoted: 86 Post(s)
Liked: 53
I realise the case you picked is compatible with 2.5" drives but why would you get a bunch of laptop hdd's when you could have got a single 3.5" drive that is bigger and probably faster for roughly the same price?
Plex should be able to stream the recorded shows to your portables.
Lastly you really should ask for help before placing an order.
ikkuranus is offline
post #3 of 5 Old 09-23-2013, 06:36 PM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
StardogChampion is offline
post #4 of 5 Old 09-25-2013, 01:28 PM - Thread Starter
pd veeps's Avatar
ended up returning the 2 2.5" drives and bought a Seagate 3TB drive
post #5 of 5 Old 09-28-2013, 05:44 PM - Thread Starter
pd veeps's Avatar
Reply Home Theater Computers
