Help moving old HTPC media to new HTPC's HDD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 09-25-2013, 06:29 AM - Thread Starter
EpicVegas's Avatar
I just built a new HTPC that has a 126gb SSD and a 3Tb 7200rpm Baracuda HDD. I need to move all my media from my old 1TB HTPC's HDD to the new HTPC's 3TB baracuda drive. How can I do this fast and easy?
Right now both HTPC are in the same room next to each other.
Please help, Thanks.
EpicVegas is offline
post #2 of 7 Old 09-25-2013, 06:44 AM
assassin's Avatar
Quoted: 155 Post(s)
Liked: 261
Gigabit switch.
assassin is online now
post #3 of 7 Old 09-25-2013, 07:28 AM - Thread Starter
EpicVegas's Avatar
I'm pretty new to networking. Would a need to purchase a gigabit switch or could I just run a ethernet cable between the two computers?
post #4 of 7 Old 09-25-2013, 07:37 AM
itznfb's Avatar
Liked: 58
Did your internet provider install a router? Typically the routers they install have a 10/100 or 10/100/100 switch built in.
Running Windows Home Server 2011 Evil Abandoned Edition
itznfb is offline
post #5 of 7 Old 09-25-2013, 08:08 AM
mrfattbill's Avatar
Quoted: 108 Post(s)
Liked: 93
Personally I would just toss the old drive into the new machine and move everything over then put the drive back into the old machine or just leave it depending on if the old one is being decommissioned.
Bill
mrfattbill is offline
post #6 of 7 Old 09-25-2013, 08:22 AM
wpbpete's Avatar
Quoted: 110 Post(s)
Liked: 96
I just used Win7 Explorer. It moved everything, albeit its very slow. I also used Xbmc's file program to do the same thing, its faster. And if you need to rename your files you can also use programs like Couch Potato, Sickbeard and theres others.
wpbpete is offline
post #7 of 7 Old 09-25-2013, 09:21 AM - Thread Starter
EpicVegas's Avatar
Ill try the gigabit switch first. If I remove the old drive and add it to my new pc it says it needs to format it in order to use it. I've already got xbmc, sickbeard and couchpotato running in the new system. I can also try my external usb 2.0 drive dock to transfer if its not too slow.
Thanks for the help
Reply Home Theater Computers
