WOL on haswell mobo, causing me trouble - AVS Forum | Home Theater Discussions And Reviews
Old 09-25-2013, 07:55 AM - Thread Starter
h8redv2's Avatar
Hi my system is Asrock H87M with Intel core i5 haswell
8 GB Kingston DDR3
Following is a recap of my setup:
Allow pci to wake is set in bios
Suspend to S3 i bios
Windows standard suspend options selected
WOL is activated on atheros network Card, with magic packet, magic packet pattern as active.
All 3 checkmarks checked, allow to power off device and allow this device to wake system and respond only to magic packet.
When I put the system to sleep, i can send a magic packet from my phone and the pc wakes.
If the pc has been a sleep for a longer period of time, the magic packet does nothing.
Seems like the device i totally powered off.
If I deselect allow computer to power off device, WOL stops working completely.
This setup worked fine on my previous build of htpc.
What am I missing ? Why does it Work, when tested immediately but not if the unit has been a sleep for a longer period of time ?
Someone know ?
Any help appreciated...
h8redv2 is offline
Old 09-25-2013, 09:14 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 399
Did you disable the hybrid sleep which will put PC into hibernation mode (power off with state saved on disc) after predefined period of time? It is in advanced settings of Power Options.
Foxbat121 is offline
Old 09-26-2013, 09:11 AM - Thread Starter
h8redv2's Avatar
Thanks...
But that does nothing... Alas...
h8redv2 is offline
