Anyone using Private internet access vpn - AVS Forum | Home Theater Discussions And Reviews
 4Likes
Old 09-26-2013, 09:31 AM - Thread Starter
pd veeps's Avatar
I'm looking for a vpn service. I've been doing some research about services that don't log ip and have good speed.
Is anyone using Private internet access for vpn?
What company does everyone recommend?
pd veeps is offline
Old 09-26-2013, 10:31 AM
assassin's Avatar
Quoted: 83 Post(s)
Liked: 246
Privatvpn
assassin is offline
Old 09-26-2013, 11:48 AM
Bizzy G.L.X.'s Avatar
+1 for PrivatVPN:   https://www.privatvpn.se/en/
OpenVPN, great support staff and full connection speeds - they're the only VPN provider that I've used wherein I can saturate my 55 mbps download speed while connected to VPN.
Remember, there's no "E" at the end of "Privat".
Case:Fractal Design Node 605
APU:AMD Richland A10-6700
RAM:8GB AMD 1866
Board:ASUS A88XM Plus
Storage:OCZ 256 GB Vector
Optical:Panasonic Slim BDR
PS:Silverstone Strider 550 Gold SFF
Software:WMC8+LAV+madVR+MPC-HC
Input:Logitech K400 mini KB/trackpad+Harmony 720
Output:Sammy 55" S6 LED LCD+Yamaha soundbar
Bizzy G.L.X. is offline
Old 09-26-2013, 01:19 PM
DylanFromCanada's Avatar
I used Private Internet Access VPN for one month. Worked great and I've read VPN reviews online and it was one of the ones listed as a great choice for anonymity as they don't keep records of IP addresses that use their service.
I was very happy with the exception of the sporadic speeds. At times as high as my local ISP 50 mbps bandwidth, but as low as 2-3 mbps per second depending on time of day and which server your using.
I've also tried pureVPN. Faster speeds for sure, but less anonymity and more expensive.
I'm still in the process of trying difference VPN's to find one that fits my needs at a reasonable price.
-DylanFromCanada
hometechprojects.com
My HTPC: Mini-Box M350 w/ 150W PICOPSU • ASUS P8H77-I mITX • Intel G2120 Dual Core 3.1GHz Ivy Bridge • Corsair DDR3 1333 Value 2x4GB • OCZ Vertex II 60GB SSD • Logitech Wireless K400 Keyboard • Logitech Harmony One • OpenELEC/XBMC
DylanFromCanada is offline
Old 09-26-2013, 02:30 PM - Thread Starter
pd veeps's Avatar
Doesn't privatvpn keep logs of your ip?
pd veeps is offline
Old 09-26-2013, 02:41 PM
assassin's Avatar
Quoted: 83 Post(s)
Liked: 246
Nope.
assassin is offline
Old 09-26-2013, 03:30 PM
VPN Services That Take Your Anonymity Seriously, 2013 Edition
Quote from Article on TorrentFreak.com:
1. We absolutely do not maintain any VPN logs of any kind. We utilize shared IP addresses rather than dynamic or static IPs, so it is not possible to match a user to an external IP. These are some of the many solutions we have implemented to enable the strongest levels of anonymity amongst VPN services.
-DylanFromCanada
Old 09-26-2013, 03:56 PM
Dark_Slayer's Avatar
Quoted: 661 Post(s)
Liked: 435
I'd recommend PIA
Great speed, lots of support, good privacy, let you pay with bitcoins
Subscriptions can be as low as $32/yr if your timing is right http://slickdeals.net/f/6067642-private-internet-access-20-off-vpn-service-32-year-or-5-50-per-month
No speed issues for me, but I run their OpenVPN config on a linux VM rather than their client app
Their client app is built for security, but it gets in the way of too many other things. Users in this thread and forum have seen PMs from me asking if they had issues with things like HDHR Prime communicating with NPVR or Flexraid webui while using the client app. I've never gotten a straight answer on their forums about it, so I just went the OpenVPN route instead. No problems thereafter
Dark_Slayer is offline
Old 09-26-2013, 05:09 PM - Thread Starter
pd veeps's Avatar
Originally Posted by assassin View Post
Nope.
What does this mean. These two statements on their FAQ page. One says they log IP addresses on incoming connections in the US but then is says they do not log any IP numbers in our US-based servers.
3. Do you log any data traffic while browsing the net through PrivatVPN?
We NEVER produce logs of any data traffic. The only thing we store is your username, password and your e-mail address.
With the exception of our servers in the U.S. where we log IP addresses on incoming connections.
Then it says
8. Do you log any IP numbers on the server in the U.S.?
No, we do not log any IP numbers in our US-based servers.
pd veeps is offline
Old 09-26-2013, 05:14 PM
assassin's Avatar
Quoted: 83 Post(s)
Liked: 246
They used to only log in the US servers only (meaning when you connected to a server based in the US). They no longer do this however.
assassin is offline
Old 09-26-2013, 05:41 PM
AVTechMan's Avatar
Quoted: 34 Post(s)
Liked: 37
I roll my own VPN by creating one on my server which runs Server 2008 R2. I have my own domain and SSL and works nicely. Im just not very trusting of commercial providers.
AVTechMan is offline
Old 09-26-2013, 05:58 PM - Thread Starter
pd veeps's Avatar
Looks like privatvpn is the way to go. Do you know how many devices they support? Or does running it on one pc protect the entire network. Do they have ios support? Their site doesn't have much info.
pd veeps is offline
Old 09-30-2013, 11:56 AM
I can't remember if it was 3 or 5 connections at one time (it should say on their site) and yes it worked fine on my iPhone, I would assume the same would be true for an iPad.
-DylanFromCanada
Old 09-30-2013, 08:10 PM
amarshonarbangla's Avatar
Quoted: 28 Post(s)
Liked: 43
Used PIA for a month and I loved it. The experience was mostly positive with the rare speed hiccups. The client is stupid easy to use as well, both on my PC and Nexus 7. I will buy an 1yr subscription soon.
amarshonarbangla is offline
Old 09-30-2013, 08:19 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2686
Which location do you use ?
Mfusick is offline
Old 10-01-2013, 04:54 AM
assassin's Avatar
Quoted: 83 Post(s)
Liked: 246
Usually the default.
assassin is offline
Old 10-01-2013, 06:45 AM
Ruiner's Avatar
/tinfoilhat -on
So which of these companies are NSA shells?
/tinfoilhat -off
Ruiner is offline
Old 10-01-2013, 06:50 PM - Thread Starter
pd veeps's Avatar
Ended up getting privatvpn today. Pretty easy to use. Downloaded a couple tv shows and speed didn't seem to suffer either.
pd veeps is offline
Old 10-13-2013, 07:03 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2686
What price did it cost you ?
Mfusick is offline
Old 10-13-2013, 08:01 PM
Defcon's Avatar
Quoted: 1114 Post(s)
Liked: 573
That is quite the download speed :eek:
I have a friend who uses bolehvpn and recommends it. They have a very good privacy policy from what I read.
As to how much these services actually protect you from a determined adversary, who can say for sure?
Defcon is offline
Old 10-14-2013, 03:06 PM
Thanks! Yeah, I used to have 105 mpbs download, but never really found the need for that much speed, especially at $115.00 USD/month. If I had multiple people living in my domicile, and could split up the costs (and the bandwidth) then it'd be worth it.
TBH, the only determined adversary's I'd be worried about are the broadband providers themselves.
That being said, I used to work for a provider as a broadband installer/configuration tech in three different regions. I worked with closely with folks from all different departments at said provider. No one I worked with had the time to hunt down people using a whole ton of bandwidth. The staff that would probably "own" the "hunt-down-the-heavy-bandwidth-users-and-possible-content-pirates" process didn't have the inclination to do so (that staff being the Information Security/Fraud team).
RAM:8GB AMD 1866
Old 03-02-2014, 04:26 AM
Dont Use's Avatar
~~Recently I have been receiving warnings from Trend Micro that Private Internet Access is not trustworthy. I have tried to have them removed from Trend's no trust list but to no avail. I ran a deep computer scan this morning and ADW_OPENCANDY spyware was found in RealPlayer software. The originating infection came from www.privateinternetaccess.com/vpninfo/servers. Trend removed this infection and I am about to uninstall PIA. This also explains why after contacting PIA many times about this they have only returned vague responses with nothing positive about trying to have themselves removed from Trend's dangerous list. That is what I know and I am just passing it on for you to evaluate for yourselves.
Dont Use is offline
Old 03-02-2014, 05:39 AM
captain_video's Avatar
Quoted: 511 Post(s)
Liked: 336
I just signed up for PIA a few weeks ago when they were running the special linked above at slickdeals.net. I still don't have it configured properly for use with pfSense and it has throttled my download speed and the number of simultaneous connections as a result. I expect that will improve considerably once I get it set up correctly. I haven't seen any problems using it with my HDHR's.
AFAIK, a VPN only hides your IP address and it doesn't filter out whatever you're downloading. If you've got spyware embedded in a web link then it's probably going to get passed through to your PC. I'm no expert on networking by any stretch of the imagination, but I don't expect it to protect me from and sites that will pass along little nasties like that. That's what your AV software is for. The spyware likely did not originate from the PIA servers but rather just passed it along with whatever you downloaded or linked to.
captain_video is offline
Old 03-04-2014, 10:50 AM
Dont Use's Avatar
You miss the point. The spayware is in the PIA homepage. That is why Trend blocks it. I requested several times for Trend to reevaluate this site and they did. It comes back as a dangerous site and it is. The software to block your IP may be itself OK, but to get to it you have to go to their home page and that is where the spyware is hiding. It is not coming from somewhere else. The people who write the reviews for the online magazines are nothing but profiteers. One write a review and the others plagiarize it and repeat it like parrots. You can't trust them. If you can find the operating software on another site like softpedia without going through their website I believe that you would be safe. Since you apparently did go through their homepage I suggest that you run your antivirus for your own safety.
Dont Use is offline
Old 03-04-2014, 10:58 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2686
You have 2 posts and your user name is Don't use. I am not sure I trust you.
StinDaWg and pd veeps like this.
Mfusick is offline
Old 03-04-2014, 11:24 AM
Quoted: 511 Post(s)
Liked: 336
I run my antivirus program almost daily and it hasn't detected anything from the PIA web page. I suspect your AV program is giving you a false positive, which isn't all that uncommon.
BTW, what's spayware? Is this something you neuter your dog with?
Mfusick, dcard and StinDaWg like this.
Old 03-04-2014, 06:54 PM - Thread Starter
pd veeps's Avatar
$8.95/month. I'm happy with the service having used it a few months.
pd veeps is offline
Old 03-04-2014, 07:18 PM
Quoted: 661 Post(s)
Liked: 435
I've used them for a while, I have no ADW_OPENCANDY spyware on my computers. There is nothing like that on their homepage
The information you are spreading is either intentionally misleading and libellous OR you are extremely misinformed but posting as if you were
Trend Micro is not a huge name in AV. Most noobs complain about all the key_patchers and batch files that get labeled as "malicious" or "trojan" by their noob lifetime subscription to FreeAVG (which I'm sure was highly touted by some place on the internet just as Trend Micro is yet somewhere else). Yet to come out at a VPN provider's homepage is something else entirely. If you've never heard of DNS cache poisoning, then you will likely continue to make such claims about many common websites and others will continue to scratch their heads as to why you are trying to provide information. At this point you should be looking for what's happened rather than trusting the first piece of anti-spy, anti-virus, anti-ad software you came across
Mfusick and StinDaWg like this.
Old 12-29-2014, 11:41 AM
oikonen's Avatar
As fas as I know Private Internet Access is reliable service provider that can be recommended. I have not noticed any spyware or any other kind of malware while using this service. Other valuable VPN service that doesn't keep logs and offers great speeds is TorGuard VPN. TorGuard also has an android app which PIA does not have at the moment.
oikonen is offline
Old 12-29-2014, 07:21 PM
Quoted: 661 Post(s)
Liked: 435
https://www.privateinternetaccess.co...id-pia-vpn-app
Don't use it but PIA does have one available
The log vs don't log slew of comparisons made across various different providers on sites like lifehacker maybe cute for bragging rights, but when push comes to shove there is going to be some amount of logging that occurred and can be turned on you. Just from a practical standpoint, there are a plethora of truly illegal criminal activities that can be performed from a computer connected to the internet. Is a $40/yr subscription to some well recommended provider going to give you anonymity to heinous illegal activities like distribute child pr0n, buy/sell illegal substances, pass highly confidential trade secrets? Obviously not, so no reason to think it's some kind of bulletproof protection for downloads. Just a little more obscurity to keep you from being low-hanging fruit (a.k.a. all those who don't use a vpn but still download)
