Graphics Card - Will upgrade help? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 09-30-2013, 07:30 PM - Thread Starter
laakness's Avatar
Liked: 29
I currently have a HTPC with an integrated ATI 4200 graphics chip. I use HDMI to my TV and optical audio out to my receiver. I use the Ceton tuner for television.
Will upgrading the graphics card give me a better picture out to the TV? I don't have any juddering or motion problems but I think the cable box from the provider looks better on my upstairs TV.
laakness is offline
post #2 of 10 Old 10-01-2013, 05:37 PM
JavaJohnNV's Avatar
Quoted: 12 Post(s)
You didn’t mention what kind of problems you are having with the integrated 4200 graphics. Is the HTPC set to 720p and the cable box at 1080i?
The AMD HD 6450 is very popular in HTPCs. They can be found on Egghead for around $50. Available in low profile and fanless designs. Good for HD video, but not games. I myself have an older HD 5450 and it works OK.
JavaJohnNV is offline
post #3 of 10 Old 10-01-2013, 07:27 PM - Thread Starter
laakness's Avatar
Liked: 29
Sorry, I feel like picture clarity is a little "softer" than the cable box. The resolution is set at 1920x1080.
Colors also seem to not be as deep and a little more faded when compared.
laakness is offline
post #4 of 10 Old 10-01-2013, 08:02 PM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Is your tv's picture setting the same on each hdmi input?
assassin is online now
post #5 of 10 Old 10-01-2013, 09:04 PM - Thread Starter
laakness's Avatar
Liked: 29
Yes, I even played back the same recordings through my xbox vs directly on the media center and they look better.
I think my main question is if a better graphics card will process the TV channels/recordings any differently.
laakness is offline
post #6 of 10 Old 10-02-2013, 01:20 AM
Dave Harper's Avatar
Quoted: 463 Post(s)
Liked: 210
Are both devices and inputs calibrated to the same correct levels? Chroma/saturation, gamma, luminance, black levels, sharpness, etc may be different which could be resulting in the differences you're seeing, especially chroma/saturation based on what you're describing.
Dave Harper
ISF, CTS
Harper Home Theater Systems
ISF Calibrations, Consultations
Sales & Installations
Dave Harper is online now
post #7 of 10 Old 10-02-2013, 07:25 AM - Thread Starter
laakness's Avatar
Liked: 29
I'll have to look through the ATi control panel and see what color adjustments I can do to try and get them closer. I just wasn't sure if a better graphics card would help or if ATi vs Nvidia would be better for those type of adjustments.
laakness is offline
post #8 of 10 Old 10-02-2013, 07:43 AM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
There is a registry edit for fixing the washed out look in WMC, but I don't remember it off the top of my head. It's the first thing I do whenever I build an HTPC.
mdavej is online now
post #9 of 10 Old 10-02-2013, 07:56 AM - Thread Starter
laakness's Avatar
Liked: 29
laakness is offline
post #10 of 10 Old 10-02-2013, 09:55 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
0-255 or 16-235 ?
Mixed matched settings can get you what you are getting.
Try another player ? Verify what you are in- possibly test with some blacker than black test shots ?
Mfusick is offline
Reply Home Theater Computers
