Suggestions on a 400 Watt modular PSU - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 44 Old 10-11-2013, 07:52 AM - Thread Starter
stevethebrain's Avatar
Quoted: 108 Post(s)
Liked: 25
it's just smelly kindof lke stepping into a tire store smelly car tires w/out ventalation.
Samsung PN58C500/Amp: Yamaha RX-V465/Polk DSW1KProSub/DefTECH SM450/C1CC/Pro80/Sony BPX37 BD/Magnavox515/ HTPC-CPU: I3 550, 3.2 GHz/Mobo: Intel H57/RAM: 6GB DDR3 1333/HDD: 1TB/2TBX2 Internal, 1TB external/Tuner: 1800-950 Haupague/W7 64 OS Remote: Harmony 700
stevethebrain is offline
post #32 of 44 Old 10-11-2013, 01:47 PM
EricN's Avatar
Quoted: 154 Post(s)
Liked: 240
I love the smell of Shenzhen in the morning...
That's just the factory freshness. I associate it with new toys.
EricN is offline
post #33 of 44 Old 10-16-2013, 04:38 AM - Thread Starter
Quoted: 108 Post(s)
Liked: 25
Tested (for 5 minutes) and Installed new Corsair PSU seans to be working fine.
played PC for a few hours and the smell seams to have dissapated.
I was a little confussed w/ the CPU cable it's terminater was 8 pins so I started reading and found that this terminater is in realatity a two piece
is it posiable to use the wronge four pins?
Image of stuff I’ve added to my prebuilt PC and future plan of 4th HDD at
Bottom front of case Using this bracket
http://www.ebay.com/itm/2-5-SSD-HDD-To-3-5-Inch-Mounting-Adapter-Bracket-For-PC-SSD-Holder-ATX-Case-/171110007534?pt=US_Computer_Case_Accessories_Tool_Kits&hash=item27d6f382ee
then adding and 5th 2.5HDD inside top compartment.
plus a intake fan inside the front bezel.
Will sealing the orginale small slites (at bottom front of case) that function as the
Intake then cutting slites in front bezel covered w/ a screen
Be beneficale to current cooling?
Haven't thoughly tested the temps. yet monitoring temps. w/ core temp. SW.
I think coming from the blob to the modualar wireing helps w/ the cooling also the bigger opening on bottom of Corsair helped.
edit: the OEM PSU has a wire starting w/ two SATA power terminaters and ending w/ a molex can I cut this wire at the PSU end shrik wrape the cut ends and reuse this wire for additionale molex to SATA connections?
Thanks STB
post #34 of 44 Old 10-16-2013, 06:33 AM
wiley165's Avatar
Location: State of Rhode Island and Providence Plantations
Quoted: 62 Post(s)
Liked: 98
Probably not. If you look at the connection, there are small differences between the different pins. The corners of them are angled in different patterns.
Take it one step at a time. Monitor the system temps. Hacking up the case can help, but if you are considering doing that, you should also start budgeting for a new case.
A good case can last a long time, and doesn't have to be expensive. Just get something you like.
Thanks STB
I would not recommend altering the permanent connections to the power supply. #1. Its dangerous, and #2, it will void the warranty. If you need extra SATA connectors, just purchase the Molex to SATA adapters. They are cheap enough.
wiley165 is offline
post #35 of 44 Old 10-16-2013, 07:25 AM - Thread Starter
Quoted: 108 Post(s)
Liked: 25
[quote name="wiley165" url="/t/1493171/suggestions-on-a-400-watt-modular-psu/30#post_23842086"]
I would not recommend altering the permanent connections to the power supply. #1. Its dangerous, and #2, it will void the warranty. If you need extra SATA connectors, just purchase the Molex to SATA adapters. They are cheap enough.[/quote]
The OEM PSU has this wire w/ two SATA terminations and a molex (that I'd like to reuse) not the new corsair.
actualley I was thinking about a new case more drive slots is appealing however my MOBO only has 6 SATA ports.
also my case has ten USB ports an I'm using six of them.
What do you think of my plan on using the Ebay bracket at the bottom of case for extra HDD?
and my other plan for the 5th HDD in the top compartment?
some of the wires are touching the PSU will a hot PSU melt these wires?
Thanks STB
post #36 of 44 Old 10-16-2013, 08:00 AM
wiley165's Avatar
Quoted: 62 Post(s)
Liked: 98
Yes, I realize that. How do you plan to "re-use" them?
If you need additional sata ports, you can add something like this: http://www.newegg.com/Product/Product.aspx?Item=N82E16816124045
I can't tell if that would work. It could, but I don't think that's the intended purpose for that bracket.
Seems like that is a good place if there isn't anywhere else.
Probably not. I'm assuming you are referencing the cables, not bare wire.
wiley165 is offline
post #37 of 44 Old 10-16-2013, 08:15 AM
bryansj's Avatar
Quoted: 1376 Post(s)
Liked: 638
[[SIZE=4
Are you talking about a small y-cable that is attached to your old PS?
This is what you need if you don't already have one: http://www.monoprice.com/Product?seq=1&format=2&p_id=8796&CAWELAID=1329457130&catargetid=320013720000010931&cadevice=c&cagpspn=pla&gclid=CIjd4LzSm7oCFe1DMgodSBcA8w
bryansj is offline
post #38 of 44 Old 10-16-2013, 08:30 AM
wiley165's Avatar
Quoted: 62 Post(s)
Liked: 98
wiley165 is offline
post #39 of 44 Old 10-17-2013, 07:00 AM - Thread Starter
Quoted: 108 Post(s)
Liked: 25
Originally Posted by wiley165 View Post
Yes, I realize that. How do you plan to "re-use" them?I decided to not cut the OEM PSU wires and just keep it as a spare just incase deal.
If you need additional sata ports, you can add something like this: http://www.newegg.com/Product/Product.aspx?Item=N82E16816124045That PCI card is so cool I did'nt know I could expand the SATA ports so I'll reconcider a new case however my case has ten USB ports and I'm using six
the couple of case's I'm concidering only have 2 USB ports and I'm not willing to add hubs.
I can't tell if that would work. It could, but I don't think that's the intended purpose for that bracket.I had a hard time searching for a 3.5" HDD bracket all I found was 2.5" to 3.5" brackets.
thinking of making a surport myself for bottom of case.
yes referencing the cables see the flat cable laying on the PSU case. there is no bare wire exposed.
Thanks STB
Thanks for suggestion STB
post #40 of 44 Old 10-17-2013, 07:16 AM
Dark_Slayer's Avatar
Quoted: 722 Post(s)
Liked: 451
If you are considering adding sata ports with a PCI card, then you might want to consider a couple extra options
The one quoted is a SYBA, and I have one very similar to it. It works just fine
If I'd done any research, I would have made better use of that PCIe slot by purchasing a IBM M1015 or Dell PERC 310 and flashing them to IT mode. You can add 8x 6.0Gbps drives this way to start (supports a lot more than 8 at 3.0GBps with an expander). I just purchased a 310 last week for $60 and 1 breakout cable for $20
For the breakout cables and the card not to mention the trouble of flashing, you are not likely to come out any cheaper per drive than the plain SYBA card. You do get more drives per PCI slots, which is good if you have a need to occupy other card slots on the board
To recap, you might not need or want to support that many drives, but if you think it's a possibility later on you can have the option for a little effort and extra cost right now
Dark_Slayer is offline
post #41 of 44 Old 10-21-2013, 06:07 AM - Thread Starter
Quoted: 108 Post(s)
Liked: 25
Will Intel H57 surport two fan’s from MOBO three pin header
I recently connected a extra case fan w/ a separate molex connection
Would prefer to use a fan splitter wire
http://www.newegg.com/Product/Product.aspx?Item=N82E16812189063
and then use the molex for additionale HDDs. w/ a molex to SATA termination.
http://ark.intel.com/products/42700/Intel-BD82H57-PCH
http://www.intel.com/content/www/us/en/chipsets/mainstream-chipsets/h57-express-chipset.html
edit looks like the new PSU is working fine I assume if it was going to go up in smoke it would have allready done so.
STB
post #42 of 44 Old 10-21-2013, 07:20 AM
wiley165's Avatar
Quoted: 62 Post(s)
Liked: 98
Fan splitter wire should be fine. I've been using them for years.
Has nothing to do with the chipset.
wiley165 is offline
post #43 of 44 Old 12-03-2013, 04:29 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
+1
Mfusick is offline
post #44 of 44 Old 12-04-2013, 01:17 PM - Thread Starter
Quoted: 108 Post(s)
Liked: 25
If you need additional sata ports, you can add something like this: http://www.newegg.com/Product/Product.aspx?Item=N82E16816124045]this module you link to is interesting I would like to have some redundancy storage on recordings that I expect to keep.
I was looking at a module that had external E-SATA ports (using two docking stations that get there power from a 120VAV wall outlet).
http://accessories.us.dell.com/sna/productdetail.aspx?c=us&l=en&s=bsd&cs=04&sku=A4046565&ST=pla&dgc=ST&cid=262075&lid=4742361&acd=1230980794501410
Is it possiable to have internal storage individual and use a PCI SATA adaptor module for two external SATA ports that mirror each other for redundancy? like this
http://www.monoprice.com/Product?seq=1&format=2&p_id=3581&CAWELAID=1329448412&catargetid=320013720000010834&cadevice=c&cagpspn=pla&gclid=CILkwKTCl7sCFaxr7AodMW8AKg
http://www.monoprice.com/Product?seq=1&format=2&p_id=3581&CAWELAID=1329448412&catargetid=320013720000010834&cadevice=c&cagpspn=pla&gclid=CPPj_dbFl7sCFW5o7AodR0AALQ
BTW Guys I recieved my $20. rebate from Corsair. Thanks for advicings.
Reply Home Theater Computers
