XBMC and CIH 2.35:1 screens - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 10-04-2013, 11:45 AM - Thread Starter
ScAndal's Avatar
Liked: 27
I'm starting to configure my xbmc pc and wondering how people are using it with scope screens.
Has anyone modified a skin to work with this aspect ratio?
ScAndal is offline
post #2 of 17 Old 10-04-2013, 11:54 AM
mrfattbill's Avatar
Quoted: 91 Post(s)
Liked: 89
I ended up running a custom resolution on the desktop (1920 * 800) and then using the PM3-HD skin and setting XBMC to run full resolution (1920*1080) and THEN setting the zoom features within XBMC appearance options to -20%, so the skin fits decently and then 2.35 video plays at the proper resolution, for 1.78 I adjust it when I watch the video the first time.
Bill
mrfattbill is offline
post #3 of 17 Old 10-04-2013, 01:19 PM - Thread Starter
ScAndal's Avatar
Liked: 27
Thanks Bill, you've given me something to go off of. I'll see if I can replicate that.
ScAndal is offline
post #4 of 17 Old 10-04-2013, 01:25 PM
mrfattbill's Avatar
Quoted: 91 Post(s)
Liked: 89
Good luck. I had ZERO luck finding a skin made for CIH so that was my solution, if you try other skins you will quickly notice that they actually HIDE the side menus off the screen which if you set the zoom that way you can still see mad.gif
Bill
post #5 of 17 Old 10-10-2013, 02:48 AM
DoghouseCinema's Avatar
Interested in testing one?
This is a skin I am working on adapting based on Aeon Nox.  So far I have most of the video tree done and a simple setting switches back and forth between CIW and CIH.  Note the skin cannot auto zoom your 1.85 movies to fit, or detect AR and change based on that (due to XBMC not knowing 2.35 films in a 1.85 container are 2.35).  I do not plan to do the audio, pvr, pictures and other parts of XBMC, just the video tree to display my movies on my CIH projector setup.
I have almost completed work to get this much out.  I don't know yet where I will post it.  When I do, I will follow up this post and one I have responded to on XBMC.  Hang in there...I've been waiting many years for a CIH XBMC skin, I finally decided to help myself....hopefully it may help you as well soon.
DoghouseCinema is offline
post #6 of 17 Old 10-17-2013, 02:31 PM
haujob242's Avatar
Hi DoghouseCinema,
your skin looks great. That is exactly what I am looking for.
haujob242 is offline
post #7 of 17 Old 10-17-2013, 02:34 PM - Thread Starter
ScAndal's Avatar
Liked: 27
I'll give it a try! Aeon Nox is what I run so i'm extremely interested.
ScAndal is offline
post #8 of 17 Old 10-20-2013, 07:05 AM
Quick question for you guys...what content do you display on your CIH screen?  Audio, Pictures, TV, PVR etc....
Are you using a zooming projector for 1.85 content, or just showing 1.85 content at reduced resolution?
What AR is your CIH screen?  2.35:1, 2.40:1 etc..I did 2.40, but know others have 2.35...I don't want to miss a common AR
Originally I was just doing the CIH thing for the Movie/Video Tree, but I have just about completed modding the entire Confluence skin for CIH.  (Aeon Nox is a complicated skin, wanted to get a better idea of structure thus the work with the simpler Confluence...I have the video tree mostly done in Aeon as seen above).  As such, I have decided to do full mods to three skins, Confluence, Ace, and Aeon Nox and your input will help as some variables need to be setup from the start or it means going back and redoing stuff.
Thanks for you input.
post #9 of 17 Old 10-28-2013, 03:56 PM
Alright.  I have set up project pages for the skins I am modding.  You can find them at my website http://www.doghousecinema.com
Confluence has quite a bit done.
Aeon Nox has the video tree mostly done, and work on the rest has begun.
Alaska HD work has started.
Rather than do Ace, I have decided to wait for Aeon MQ5 to be completed by MQ and then mod it.
post #10 of 17 Old 01-01-2014, 12:44 PM
fidali's Avatar
i have done one using the "refocus" skin. It's converted to 2.35.1 then themed it like imax.
have a look. youtube - http://www.youtube.com/watch?v=NujRMr4apCk
fidali is offline
post #11 of 17 Old 03-08-2014, 09:39 PM
aniv's Avatar
can you post a link to the skin? looks great,
aniv is offline
post #12 of 17 Old 05-16-2014, 12:12 AM
DAlba's Avatar
Quoted: 32 Post(s)
Ditto.. I would love to have IMAX skin. Please share:)
DAlba is offline
post #13 of 17 Old 10-16-2014, 04:06 PM
Ænz's Avatar
Send a message via Skype™ to Ænz
Has there been progress here. The skins at doghouse doesnt seem to work. I have even tried it with older versions of XBMC without luck. Is the numax done? available anywhere?
What is your solution running XBMC on a scope screen?
Ænz is offline
post #14 of 17 Old 10-17-2014, 10:45 PM
DAlba's Avatar
Quoted: 32 Post(s)
I've tried contacting the authors of both numax and doghouse and got no response
DAlba is offline
post #15 of 17 Old 11-17-2014, 07:38 AM
Ænz's Avatar
Yes I tried as well. The doghouse seemed particularly interesting to me anyway. Looked like he had the perfect understanding of the 4 (or more) different approaches to CIH. Even a setting in-skin to switch between 1:2.35 and 1:2.40
Anyway we keep looking. There must be someone competent enough to modify an existing skin. I use lens memory on the projector now, and would just like all the menu items and the osd to be within the 2.40:1 image. That way it would not matter what lens memory setting you had selected.
Ænz is offline
post #16 of 17 Old 11-18-2014, 02:51 PM
DAlba's Avatar
Quoted: 32 Post(s)
Same here. I only need the movies portion skinned. Don't need music, photos, or other widgets. I would try but I have zero free time with a 5 month old
DAlba is offline
post #17 of 17 Old 04-04-2015, 05:39 PM
Ænz's Avatar
I decided to dig in. Has been hoping for a solution for years. But some improvements can be done relatively easy.
Right now I need to find the "Now playing" label in confluence skin... If anybody knows, please help.
Name:	Skærmbillede 2015-04-05 kl. 01.21.13.png
Ænz is offline
Reply Home Theater Computers
