FlexRAID Data Protection ??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 97 Old 10-07-2013, 11:55 PM - Thread Starter
Airbander's Avatar
Hello
I am new to FlexRAID and i want to buy it and try it and so on but before i do so i have question about Data Protection
How does FlexRAID actually protect the data if one of the drive died ???
I understand the One large pool concept but i still cant understand the protection part
Please look at this image to undertand what i am trying to say or ask
Thanks in advance
Airbander is offline
post #2 of 97 Old 10-08-2013, 12:18 AM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Take a look at my guides. I explain it there. Or do a search here at avs as it has been discussed multiple times.
assassin is offline
post #3 of 97 Old 10-08-2013, 12:21 AM - Thread Starter
Airbander's Avatar
Hello assassin good to see you in this fourm also so which guide you talking about ?
post #4 of 97 Old 10-08-2013, 12:36 AM
AVTechMan's Avatar
Quoted: 31 Post(s)
Liked: 37
Look at Assassin's signature; there's a link for his blogs and guides and he has a section done on FlexRaid that should answer most of your questions.
AVTechMan is online now
post #5 of 97 Old 10-08-2013, 12:42 AM - Thread Starter
Airbander's Avatar
Hi
why do i have to go to his blog ?
post #6 of 97 Old 10-08-2013, 12:55 AM - Thread Starter
Airbander's Avatar
Hi
giving example of parity backup this wont work well for me as all sata ports are full and all drives are full so not sure if i am out of luck or what can i do to slove my issue
post #7 of 97 Old 10-08-2013, 02:19 AM
jim2100's Avatar
Liked: 34
Short term solution: copy the contents of D: among the free space on the other drives, then use the now empty D: as a parity drive
Better solution: add more drive ports with a SATA or SAS card, then get more HDDs
jim2100 is offline
post #8 of 97 Old 10-08-2013, 04:52 AM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Hi
Because I have spent the time to put it there for you as an easy reference. It's free for all now.
assassin is offline
post #9 of 97 Old 10-08-2013, 06:01 AM
cybrsage's Avatar
Liked: 154
Hi
...he has a section done on FlexRaid that should answer most of your questions.
The answer to your question is in the post you quoted.
cybrsage is offline
post #10 of 97 Old 10-08-2013, 08:23 AM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
assassin is offline
post #11 of 97 Old 10-08-2013, 09:27 AM - Thread Starter
Airbander's Avatar
Even easier for you: http://assassinhtpcblog.com/server-flexraid/
Hello assassin
i already book marked you site yesterday thanks so you have an old blog very organized and no add or thing like that and it is not wiki based love your work
Nice site really keep the hard work.
So FlixRaid Data protection , i run into one issue i dont have disk space anymore so parity drive wont work
1- No hard drive space
2- No more Stat Space
3- No more power space
I am MAX OUT completely , so if i use flexraid it will be only for data pool only
Not sure what else to do here NAS are expensive and cheapest one are around 300 bucks
post #12 of 97 Old 10-08-2013, 09:29 AM - Thread Starter
Airbander's Avatar
Hi Jim2100
When i say i am MAX out i am not joking that picture is little old since then i replace 1 TB drive with 4 TB drive and fully max out on all drives now
post #13 of 97 Old 10-08-2013, 09:29 AM
mrfattbill's Avatar
Quoted: 91 Post(s)
Liked: 89
No available USB ports?
Bill
mrfattbill is offline
post #14 of 97 Old 10-08-2013, 09:42 AM - Thread Starter
Airbander's Avatar
Hi
I have alot of USB and 2 USB 3.0 and 2 e-sata and some other ports why ?
post #15 of 97 Old 10-08-2013, 09:44 AM
mrfattbill's Avatar
Quoted: 91 Post(s)
Liked: 89
Hi
Get an external 4TB USB3 drive and make that your parity drive.
Bill
post #16 of 97 Old 10-08-2013, 09:51 AM - Thread Starter
Airbander's Avatar
Bill
I thought about it but worried of the heat kill the extranl drive ?
post #17 of 97 Old 10-08-2013, 10:06 AM - Thread Starter
Airbander's Avatar
Hello Guys
There is more into my issue but i am trying to fix it all by planing for it first but if someone really interested in my issue here are some info
1- http://community.mediabrowser.tv/permalinks/15381/what-would-you-do
2- http://community.mediabrowser.tv/permalinks/14409/can-t-read-from-the-source-file-or-disk-error
3- http://www.sevenforums.com/general-discussion/306774-hard-drive-images-not-showing-up.html
Here are 2 Video of my setup
http://www.youtube.com/watch?v=wrjq0D6-BH4
http://www.youtube.com/watch?v=5ei84VKfIXQ
see heat killed 4 drives so far since 2008 till now at all times i was able to fully recover all my data but this time when my 1TB drive went bad i took me almost 1 month of trying so so so many software to recover my data and finally i recovers 80% and i am going to RMA this drive if it is still under warranty
I am thinking to use flexraid with Crushplan for backup and protection and one Pool this time but running into issue of space and No funding
post #18 of 97 Old 10-08-2013, 10:11 AM
mrfattbill's Avatar
Quoted: 91 Post(s)
Liked: 89
Bill
post #19 of 97 Old 10-08-2013, 10:14 AM - Thread Starter
Airbander's Avatar
Bill
Hello Bill
Cant do no space let on my PC , as i said i am MAX out of space , power , sata port so if i use e-sata the drive will set outside and heat is huge issue for me
Here are 2 Video of my setup and pc , once you watch it you will undertand my issue
Heat is huge issue no fans and no power , my pc is shutdown for almost 2 weeks as i am trying to figure this out
post #20 of 97 Old 10-08-2013, 10:18 AM
wsume99's Avatar
If you want protection against a drive failure then you either have to add another drive to your existing PC using USB or a SATA expansion card OR build a media server. You could build a server for $300 that would be expandable up to 12-16 drives. It sounds like you are running out of room in your current PC and I'm betting your storage needs are constantly increasing so you will probably eventually need a server anyway so I say build one sooner rather than later. The only other thing you can do is replace your 2TB drives with 4TB drievs and move things around to free up a drive to use as your parity drive. This will work but if you are constantly acquiring data then eventually you'll need to add physical drives.
wsume99 is offline
post #21 of 97 Old 10-08-2013, 10:19 AM
mrfattbill's Avatar
Quoted: 91 Post(s)
Liked: 89
Are there filters in front of those case fans?
Bill
post #22 of 97 Old 10-08-2013, 10:25 AM
bryansj's Avatar
Quoted: 1130 Post(s)
Liked: 560
Maybe start by deleting crap you will never watch again. I know I can pare down my collection with the simple question of "will I ever watch this again".
bryansj is offline
post #23 of 97 Old 10-08-2013, 10:27 AM - Thread Starter
Airbander's Avatar
already did that remove all duplicate and extra stuff 2 TB worth of stuff deleted
post #24 of 97 Old 10-08-2013, 10:28 AM - Thread Starter
Airbander's Avatar
Bill
Hi Bill
Yes these are filters i need to clean them but no worried as my server is shutdown so dirty filter is not an issue lol
the case is DF-85 and it comes with 7 fans and i added more so total of 10 fans in the system to keep it cool
post #25 of 97 Old 10-08-2013, 10:30 AM - Thread Starter
Airbander's Avatar
This is my server and DF-85 Case can take Max of 10 Drive
post #26 of 97 Old 10-08-2013, 10:34 AM
mrfattbill's Avatar
Quoted: 91 Post(s)
Liked: 89
Hi Bill
So is it not booting up? I was in a similar situation space wise and ended up purchasing a San Digital 8 bay tower and a PCI esata port replicator. I also moved as much as I could to my biggest drives prior to building my parity when the time came around.
Bill
post #27 of 97 Old 10-08-2013, 11:01 AM
wsume99's Avatar
Have you considered adding a 5-in-3 enclosure in the 5.25" bay? That would give you room for 5 more drives.
wsume99 is offline
post #28 of 97 Old 10-08-2013, 11:06 AM - Thread Starter
Airbander's Avatar
Bill
Out of my budget but thanks
post #29 of 97 Old 10-08-2013, 11:10 AM - Thread Starter
Airbander's Avatar
Hi yes i thought about looking into something like this
It is 100 bucks in NewEgg but i am not sure if it will fit in my case
http://www.newegg.com/Product/Product.aspx?Item=N82E16817121405
My case df-85
OR i can wait for this guy to go to $129.99 and then buy it
post #30 of 97 Old 10-08-2013, 11:12 AM - Thread Starter
Airbander's Avatar
Hi
here is the link for
SANS DIGITAL TR4UTBPN 4Bay USB 3.0 / eSATA Hardware RAID 5 Tower RAID Enclosure (no eSATA card bundled)
http://www.newegg.com/Product/Product.aspx?Item=N82E16816111149
Reply Home Theater Computers
Flexraid
