DVI => Component => Epson 5020UB Projector - AVS Forum
post #1 of 5 Old 10-08-2013, 06:43 AM - Thread Starter
SativaNL's Avatar
Hi there,
While creating my hometheater living room I thought it would be nice to also use my HTPC as a input for the split screen option.
So my Onkyo TX NR 616 reciever goes to HDMI1, and as a secondary input I use a component cable.
I already have run the cables so I really have to use this option, but I made a design flaw.
I thought I could use my DVI port and use a DVI => Component adapter and run those to my projector.
But as some may know; This doesn't work! DVI is digital, and the conversion to component doesn't work.
Can anyone give me some tips how I can make this work? Please take in mind that I have to use the component cable, and the HDMI output is already taken.
Thanks in advance!
SativaNL is offline
post #2 of 5 Old 10-08-2013, 07:41 AM
jdmag00's Avatar
Can't you just do dvi>HDMI to receiver to projector?
jdmag00 is offline
post #3 of 5 Old 10-08-2013, 07:49 AM - Thread Starter
SativaNL's Avatar
The spit screen function on the projector only can handle 1 HDMI input. So component is the option I must use. (And I already have the cables).
I am thinking of this stupid way; DVI => HDMI => HDMI convertor to component => Component.
That will be 50 USD of extra costs, but if it works than it's fine.
Are there any more things I can consider?
SativaNL is offline
post #4 of 5 Old 10-08-2013, 09:57 AM
jdmag00's Avatar
My bad.... missed the split screen part!
jdmag00 is offline
post #5 of 5 Old 10-09-2013, 02:28 AM
springmaker's Avatar
I can think of two options 1st a hdmi to component adapter box or 2nd add videocard with component out sometimes called hdtv out socket.
springmaker is offline
Reply Home Theater Computers
User Tag List
