USB Driver Security Update?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-13-2013, 09:08 AM - Thread Starter
Sammy2's Avatar
Quoted: 515 Post(s)
Liked: 250
This is the first time I've seen any mention of dual restarts for an update and issues that this causes. Has anyone applied this update to their system yet?
http://support.microsoft.com/kb/2862330
http://support.microsoft.com/kb/2894518
Known issues with this security update
After you install security update 2862330, your computer may restart two times. For more information updates that require multiple restart, click the following article number to view the article in the Microsoft Knowledge Base:
2894518 Software updates that require multiple reboots may cause task sequence failure within Configuration Manager.
Sammy2 is offline
post #2 of 3 Old 10-13-2013, 09:37 AM - Thread Starter
Sammy2's Avatar
Quoted: 515 Post(s)
Liked: 250
Okay, so I went ahead and installed this update and it is exactly as described.
My computer hung on a black/blank screen on initial re-boot after downloading and installing the update.
I hit the reset button to reset and it re-stared whereupon it was at 32% "configured" for several minutes before giving me a log in screen.
So, if you are about to do this update, it works but it is a bit frustrating. I was thinking that I needed to go into recovery mode there for a bit so be patient!
Sammy2 is offline
post #3 of 3 Old 10-13-2013, 01:49 PM
Vlad Theimpaler's Avatar
Liked: 33
I didn't have any problems with this month's patches, but I did notice that my Win7 HTPC autodetected a "new" USB controller (saw the New Hardware alert in the system tray), and it auto-installed itself after the PC finished its post-patch reboot. Everything seems fine ATM.
Vlad Theimpaler is offline
Reply Home Theater Computers
