Basic $500 HTPC? What would you recommend for hardware? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 50 Old 10-15-2013, 02:27 PM - Thread Starter
NicksHitachi's Avatar
Quoted: 182 Post(s)
Liked: 189
I've been pondering a basic HTPC build for the living room. This would be my first PC build. This unit would be used for light movie watching, Media Browser, XBMC, etc. Since its only connected to a 55" plasma hard core up conversion like MadVR power is really not necessary but if possible thats great too.
Ive looked at the new haswell socket stuff and that looks to be the best bet. Assassin's guide doesn't have anything up for Haswell yet so I was hoping you guys might steer me towards the best values.
Here are some of the hardware features I want in this build:
  • SSHD for OS
  • BR Player and Burner
  • At least 2TB HD
  • Windows 7 OS
  • Server type horizontal case
  • Big enough case to hold 4 hard Drives(mother board should accomodate 4HDDs too)
The rest is wide open, I really intend to use this unit lightly and later build a heavier one for the theater that can do all the heavy lifting stuff like intense up conversion and processor intensive stuff.
NicksHitachi is offline
post #2 of 50 Old 10-15-2013, 02:39 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Asrock H series motherboard + Haswell G3220 CPU (i3 if you want 3D) + Gskill 8GB Ram (1866mhz) + Samsung 128GB SSD + Seagate 4TB HDD + Silverstone Case (you pick form factor) + Quality PSU
For PSU I like Rosewill, Seasonic, or Seasonic/Superflower OEM's (MKIII, Antec Neo, Certain Corsair models, certain Rosewill models etc)
You want a 350 watt PSU, no more than 450/500 watts for sure.
Cost breakdown:
AsRock Socket 1150 Mobo with HDMI ($80)
Haswell G3220 ($65) [superbiz has sale for $59 with a code but shipping brings close to Newegg price]
Gskill Ram $60
Samsung SSD $89
Seagate 4TB $140
Silverstone Case $59-$139 [Milo3 is $59 but would lack enough HDD's for you, probably a Grandia series is what you want]
PSU $50
Any BR drive
You can get something like this for about $500 if you catch a couple good deals.
Really nice HTPC for $500 budget (IMO)
Bizzy G.L.X. likes this.
Mfusick is offline
post #3 of 50 Old 10-15-2013, 02:43 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
You might be closer to $600 mad.gif If you must buy windows
Mfusick is offline
post #4 of 50 Old 10-15-2013, 03:22 PM
emcdade's Avatar
Quoted: 141 Post(s)
Liked: 141
Sorry man, I busted your budget. Here's a decent Haswell build that will do everything you asked. You could always look to ebay or stretch your budget a bit. I'm not good at recommending cheap stuff, this will be a nice rig.
Case: Fractal Node 605 -- $165
CPU: Intel G3220 Dual Core -- $70
Mobo: Asrock H87m Pro4 -- $80
PSU: Silverstone SFX 300 W -- $50
RAM: 4gb Gskill eco series -- $40
SSD: Corsair Force 60GB -- $50
HDD: Seagate Barricuda 3 TB -- $120
BD-Rom: LG Slim BR Drive -- $70
GPU: Sapphire 6570 -- $40
Total: $685
*You could always go cheaper on your case, I'm not sure if you'll have it hidden away somewhere or not. This one is a looker though.
NicksHitachi likes this.
emcdade is offline
post #5 of 50 Old 10-15-2013, 05:40 PM
jdmag00's Avatar
Why you add a 6570? No need also get cheaper case will get you closer to $600 at least
Jeff Krogue likes this.
jdmag00 is offline
post #6 of 50 Old 10-15-2013, 06:03 PM - Thread Starter
Quoted: 182 Post(s)
Liked: 189
Its all good guys I figured we would break the budget....
Question: Is 60 Gb SSD enough? What would i want to put there besides the OS?
post #7 of 50 Old 10-15-2013, 07:15 PM
emcdade's Avatar
Quoted: 141 Post(s)
Liked: 141
60 should be ok. 80 would be a little more breathing room. You just want Windows and your apps loaded on there. I just checked my SSD and I'm using 28 GB with plenty of apps installed.
emcdade is offline
post #8 of 50 Old 10-15-2013, 07:40 PM
emcdade's Avatar
Quoted: 141 Post(s)
Liked: 141
I think he'll get a better experience with an AMD gpu to be honest. He did say Madvr would be nice, and 6570 is a good budget card for that. 7750 would be better for an extra $50.
No surprise AVS member suggesting the integrated Intel gpu and cheap case, typical. I'd be much happier with a real gpu and nice case for a few extra bucks.
emcdade is offline
post #9 of 50 Old 10-15-2013, 09:20 PM
StinDaWg's Avatar
Quoted: 451 Post(s)
Liked: 216
$165 is ridiculous for a case, but that's just my opinion. I wouldn't spend more than $50-70, but then again I'm cheap.
StinDaWg is offline
post #10 of 50 Old 10-15-2013, 09:42 PM
Toys7505's Avatar
Quoted: 69 Post(s)
Liked: 26
That Fractal is very sleek looking! I myself use a Silverstone Grandia GD08.........has plenty of room for expansion and looks like it belongs in an equipment stand (if you need to show it).
Toys
Denon AVR-3311CI, Denon DVP-602CI, B&K Reference 200.7 S2, Belkin PF60
Sony BDP-S5000ES, Silverstone HTPC (6 Tuner DVR & 10 TB Media)
PSB Stratus Minis, PSB Stratus C6, PSB Alpha S surround, James Subwoofer EMB-1200
Sharp LC-70LE755U, Harmony 880 Remote
Toys7505 is offline
post #11 of 50 Old 10-16-2013, 05:49 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I prefer 128 GB as often 60gb is not enough ( it can be enough but it never seems to work out that way for me in the long run)
The cost difference today in price difference is now smaller so twice the capacity does not cost twice the price making the 128 GB the better value.
You can get under $100 SSD that are 120 or 128gb. That's my suggestion. Samsung and OCZ routinely pop up on sale.
Mfusick is offline
post #12 of 50 Old 10-16-2013, 05:51 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I have 24gb free (of 128)
Mfusick is offline
post #13 of 50 Old 10-16-2013, 05:52 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Cases are a very subjective thing that's mostly looks and personal opinion so I rarely push a certain case.
I agree its pricey , which is why I thought Silverstone (I've always had good luck with these)
Mfusick is offline
post #14 of 50 Old 10-16-2013, 05:56 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I use a Radeon myself so no hate from me . I just think Nick is better off going all out in areas up front like ram, CPU, SSD. He can come in near budget and adding a card in future is easy (if that's something he wants to do)
Saving the GPU purchase for future is a solid strategy and he was not 100% in MADVR so I'm not sure he even needs it.
That's a nice future upgrade IMO.
Mfusick is offline
post #15 of 50 Old 10-16-2013, 06:05 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
http://www.newegg.com/Product/Product.aspx?Item=20-227-966&nm_mc=EMC-GD101613&cm_mmc=EMC-GD101613-_-index-_-Item-_-20-227-966&
Digital rebate too. You can fill it out online and they just mail you a ATM card.
Mfusick is offline
post #16 of 50 Old 10-16-2013, 08:29 AM - Thread Starter
Quoted: 182 Post(s)
Liked: 189
Awesome information guys.
I'm learning a lot here.... I had anticipated on cutting the cord eventually and using this machine to help with that. In looking at the hardware choices its very easy to get caught up in the "just a few more dollars" and pretty soon the budget is just a memory. eek.gif
I think the machine that would serve me best is outlined below. Unfortunately this is waaay above budget so I'll prob have to save some more before pulling the trigger. Please look over the parts list and see if anything stands out as a incompatible or just bad choices......
Now I just gotta find another 5bills to rub with the initial 5.... tongue.gif
post #17 of 50 Old 10-16-2013, 08:42 AM
wiley165's Avatar
Location: State of Rhode Island and Providence Plantations
Quoted: 61 Post(s)
Liked: 98
My only concern is that you chose a RAM kit that is unsupported (1866). If you are going with a "H" series motherboard, you can't overclock the RAM.
You can get a 1600 kit usually for less money.
Either go with a "Z" series Mobo if you intend to Overclock, or go with the correct RAM.
wiley165 is offline
post #18 of 50 Old 10-16-2013, 09:12 AM - Thread Starter
Quoted: 182 Post(s)
Liked: 189
I wasn't even aware of the difference...
So would I want to overclock this type machine? I'm not gaming on it. Would normal HTPC stuff require overclocking?
Also, Is there any advantage to two sticks of 4GB ram over a single stick of 8GB? The single stick seems like a better option since it takes up fewer slots and they can be later filled......
Assuming im not overclocking, how about these memory choices:
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBXL
AMD Radeon 8GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model AE38G1609U2
post #19 of 50 Old 10-16-2013, 09:34 AM
wiley165's Avatar
Quoted: 61 Post(s)
Liked: 98
Based on what you have stated so far as the intended purpose of the HTPC, No.
I tend to lean toward a dual channel kit rather than a single stick of RAM. so, +1 for the GSkill kit.
You might be able to get by with a 4GB kit (2x2GB) as opposed to 8GB (2x4GB).
Look for kits with lower latency (CAS). On 1600, look for 9 and less. Generally, the lower the better.
wiley165 is offline
post #20 of 50 Old 10-16-2013, 12:07 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
True that Z series mobo is better for high memory clock speed or overclocking. +1 there.
On the matter of RAM it is not so simple. There is many factors to consider. First is price, then capacity, also CAS LATENCY, and speed all make differences. Often you can get 1866mhz for basically the same price as 1333mhz- the difference being you can run 1866mhz with CL8 or lower and it's actually better/faster. 8GB you want for sure if you are going with iGPU as your GPU will compete for RAM. Second you want two sticks (DUAL CHANNEL) Third and 4th would be CAS L and speed.
HERE IS THE ORDER OF IMPORTANCE:
1. Amount of memory
2. Number of sticks of memory
3. Placement of those sticks in the motherboard
4. The MHz of the memory
5. If XMP/AMP is enabled
6. The subtimings of the memory
http://www.anandtech.com/show/7364/memory-scaling-on-haswell
Mfusick is offline
post #21 of 50 Old 10-16-2013, 12:09 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
If you are cutting the cord why spend $115 on a tuner card ?
Mfusick is offline
post #22 of 50 Old 10-16-2013, 12:13 PM - Thread Starter
Quoted: 182 Post(s)
Liked: 189
I was going to use it to DVR OTA digital broadcasting.....
It can do that right?
post #23 of 50 Old 10-16-2013, 01:31 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Yup you could do that. I bought a $10 card on ebay that does that though ( no cable card and OTA only )
Mfusick is offline
post #24 of 50 Old 10-16-2013, 10:35 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
Toys
I really like the looks of the Fractal, and looked at it - it has limited drive configuration options. If the case works for the setup that you want, it is pretty neat. I remember it is quite shallow - which was a requirement for me. I would say the Silverstone's are the default case that I would suggest for HTPC builds. Solid design and reasonable prices.
lespurgeon is offline
post #25 of 50 Old 10-16-2013, 10:39 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
90+% chance the ram will still work, just at lower timings. Funny, I haven't checked in this specific case, but faster memory is sometimes cheaper these days.
post #26 of 50 Old 10-18-2013, 12:13 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Yup. Depending on the sales you can get 1866 (sweet spot in value and performance) cheaper than 1600 or 1333 in many cases
Mfusick is offline
post #27 of 50 Old 10-19-2013, 03:06 PM
Jeff Krogue's Avatar
Its probably big enough but the sweet spot price to gig right now is 128Gig
I have good luck with 4gigs of ram.
Jeff Krogue is offline
post #28 of 50 Old 10-19-2013, 04:30 PM
SWAgent's Avatar
If you're trying to stick close(ish) to you budget I ran up something pretty similar to what I have for you.
$625 including the OS (and before any kind of bundle pricing... double check Micro Center for some of this stuff if you have one nearby)
http://pcpartpicker.com/p/1QLGl
CPU: AMD A10-5800K 3.8GHz Quad-Core Processor$109.99
Motherboard: MSI FM2-A75MA-P33 Micro ATX FM2 Motherboard$54.98
Memory: G.Skill Sniper Series 8GB (2 x 4GB) DDR3-1866 Memory$73.98
Storage: Sandisk Ultra Plus 64GB 2.5" Solid State Disk$64.99&Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive$89.98
Case: Silverstone ML03B HTPC Case$59.99
Power Supply: Corsair Builder 430W 80 PLUS Bronze Certified ATX12V Power Supply$49.99
Optical Drive: Asus BW-12B1ST/BLK/G/AS Blu-Ray/DVD/CD Writer$78.99
Just a few notes/opinions... The AMD APU's are a pretty fantastic bang for your buck these days. I've done two very similar builds using an A10 and an A6 and both performed without a hitch with uncompressed MKV rips using XBMC. (And certainly no need to overclock.)
I picked a case that is reasonably easy to work in and has a great 'component style' form factor but will not allow the quantity of drives you're talking about. My suggestion would be to separate those into an independent NAS down the road
60GB for a boot drive is plenty! I'm only about half full with my Win8 install and a handfull of applications. My games and whatnot go on the secondary HDD.
For reference I've got almost the exact build listed here and it works really well for the kinds of things you're asking for. I've even used mine for some light gaming and it's handled things better than I'd expect (like playing Arkham City at 40+ fps on medium settings). That being said if I'm looking to play the latest games at 60+ fps on ultra settings I go into my office and use my desktop outfitted withan OCed i7 3770k coupled with 16GB or RAM and a GTX770.
SWAgent is offline
post #29 of 50 Old 10-19-2013, 09:20 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
Yes,
Disable hibernation with an SSD. They boot so quickly - and it saves space.
post #30 of 50 Old 11-15-2013, 10:58 AM - Thread Starter
Quoted: 182 Post(s)
Liked: 189
OK, finally ready to put this together. Some minor changes due to price changes at Newegg. Somebody please go over the hardware and make sure I'm not missing anything and that all this will work well together.
Also, what about cables? Will I need to order any? I hope they come with the hardware but IDK this really is my first go at building a PC. I have installed RAM and replaced hard drives before but thats about it!!!biggrin.gif
The cart is loaded I just need a final OK before I click the checkout button......
Reply Home Theater Computers
