Media browser won't play avi dolby digital 2.0 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 10-18-2013, 12:08 PM - Thread Starter
pd veeps's Avatar
I'm using lav splitter
Media browser classic won't play a tv show in this format
avi, dolby digital 2.0
It plays fine in xbmc.
Do I need to install another codec, etc?
pd veeps is online now
post #2 of 16 Old 10-18-2013, 12:18 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Did you use shark 007 codec pack ?
http://assassinhtpcblog.com/wmcandmbsetup/#guide61
Follow that and try again
Mfusick is offline
post #3 of 16 Old 10-18-2013, 01:10 PM - Thread Starter
pd veeps's Avatar
I just uninstalled lavsplitter and installed shark007.
post #4 of 16 Old 10-18-2013, 01:47 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
working ?
Mfusick is offline
post #5 of 16 Old 10-18-2013, 02:49 PM - Thread Starter
pd veeps's Avatar
Yes working. Thanks.
post #6 of 16 Old 10-18-2013, 05:02 PM
Bizzy G.L.X.'s Avatar
+1 for Shark's stuff.
I know a lot of people denigrate codec packs, especially Shark's for some reason.
I've been using Shark's for years and have setup tons of friends, family and co-workers alike, always with good, long lasting results.
Case:Fractal Design Node 605
APU:AMD Richland A10-6700
RAM:8GB AMD 1866
Board:ASUS A88XM Plus
Storage:OCZ 256 GB Vector
Optical:Panasonic Slim BDR
PS:Silverstone Strider 550 Gold SFF
Software:WMC8+LAV+madVR+MPC-HC
Input:Logitech K400 mini KB/trackpad+Harmony 720
Output:Sammy 55" S6 LED LCD+Yamaha soundbar
Bizzy G.L.X. is offline
post #7 of 16 Old 10-18-2013, 06:13 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
All you need to make sure you do is uncheck the bundled crapeware that comes in the pack
Mfusick is offline
post #8 of 16 Old 10-18-2013, 06:15 PM
True, no doubt !
Mfusick likes this.
RAM:8GB AMD 1866
post #9 of 16 Old 10-20-2013, 01:46 AM - Thread Starter
pd veeps's Avatar
Seems like shark007 plus disabling windows audio decoding is actually giving me better sound out quality out of my avr as well.
post #10 of 16 Old 10-20-2013, 08:08 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
What is running on the bottom right ? Near clock ?
Mfusick is offline
post #11 of 16 Old 10-21-2013, 01:44 PM - Thread Starter
pd veeps's Avatar
Ffdshow audio, ffdshow video, lav splitter
post #12 of 16 Old 10-21-2013, 02:00 PM
bryansj's Avatar
Quoted: 1130 Post(s)
Liked: 560
Better to unzip the downloaded .exe file and run the installer from there just to be sure no crapware slips through. Too many reports of something happening where crapware gets installed even though all boxes were unchecked. The download hosting sites (majorgeeks) are the ones that bundle in the crap, not the developer.
bryansj is online now
post #13 of 16 Old 10-21-2013, 02:32 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I tend to think it's user error.
They make it seem like it's not there. You need to go out of your way to pay attention, and click "custom install" and then uncheck stuff.
I am sure the people that complain it's their fault for not doing it right or paying attention.
I've installed shark 30 times without a problem. But I also know better biggrin.gif
Mfusick is offline
post #14 of 16 Old 10-21-2013, 03:34 PM - Thread Starter
pd veeps's Avatar
Yes luckily I caught all that crapware on my first install.
post #15 of 16 Old 10-21-2013, 04:49 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
They definitely put effort into hiding the crapware... and making you not notice it easily.
Mfusick is offline
post #16 of 16 Old 10-21-2013, 06:40 PM
Shark007's Avatar
Quoted: 80 Post(s)
Liked: 73
IMO, the best solution is to use 7zip to extract the distributed file and you will have a clean installer (that I created) with no extra crap.
Use Shark007 Codecs and retain your sanity.
Shark007 is offline
Reply Home Theater Computers
