HTPC using Radeon 7990 HDMI - no sounds in games. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-19-2013, 02:46 PM - Thread Starter
tainle's Avatar
I used to be able to get sounds for games when i use my htpc setup with gtx 670 card. now i swapped to radeon 7990 i have the same setup but whenever i play games I cannot get sounds. some games like lineage 2, castlevanian lord of shadow have sounds. starcraft 2, the witcther 2, and graphics benchmark program dont have sounds. does this happen to Radeon 7990 card?any fix for this? thanks
tainle is offline
post #2 of 4 Old 10-19-2013, 02:54 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
I think that card it not powerful enough for HTPC...
You should consider getting something a little bit more powerful.
Mfusick is offline
post #3 of 4 Old 10-19-2013, 04:00 PM - Thread Starter
tainle's Avatar
like what? i don't see any card can be better than radeon card. and i have no problem bitstreaming dts hd ma and truehd...my question have nothing to do with htpc though but maybe someone can help my problem.
tainle is offline
post #4 of 4 Old 10-19-2013, 05:18 PM
Antripodean's Avatar
I don't think the OP was looking for sarcasm.
Perhaps try the Beta driver as reviewed
explore the music
Antripodean is offline
Reply Home Theater Computers
