Youtube: IE11 vs Google Chrome uses ~5x less cpu - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 10-20-2013, 09:58 AM - Thread Starter
ymarker's Avatar
Quoted: 27 Post(s)
Looks like newer versions of internet explorer support accelerated video decoding in addition to accelerated video rendering resulting in significant decrease in cpu utilization on newer intel cpu's. In comparision, google chrome only appears to support accelerated video rendering and software decoding resulting for flash youtube videos resulting in significantly higher cpu utilization. While the screen cap for IE shows ~2.5% cpu, in reality it went down to almost 0.8%
IE:
Google Chrome:
Here is the source:
Oddly enough, even using HTML5 still results in the higher cpu utilization in google chrome. I've heard disabling the inbuilt flash player and downloading the latest from adobe may fix it, but I would prefer to get the inbuilt flash to work in google chrome.
Also for some reason, text appears sharper on IE11 than google chrome. >>> This issue was solved using this
TLDR; Anyone know how to turn on accelerated video decoding in google chrome for flash videos?
ymarker is offline
post #2 of 23 Old 10-20-2013, 12:37 PM
nxsfan's Avatar
Quoted: 24 Post(s)
I discovered this earlier this year. This was my solution at the time (I imagine it still works):
Go to Adobe’s Site and download the external flash decoder. Once installed you must disable the built in pepperflash/Adobe flash plugins. Type about://plugins into the search bar, click on +”details” to expand the details for each plugin and disable the bundled pepperflash/Adobe flash plugins. It’s easy to differentiate the native chrome plugin from the one you just installed by looking at the plugin path (i.e. disable the plugin residing in C:\Program Files (x86)\Google\Chrome\Application).
Once done refresh the offending youtube page and you should have Hardware Accelerated Rendering and Decoding.
[Had I properly read your post I would seen that you don't want to disable the internal flash plugin, but I know of no other way].
nxsfan is offline
post #3 of 23 Old 10-22-2013, 02:44 AM
72.9.159.100's Avatar
I also would use HTML5 youtube instead.
72.9.159.100 is offline
post #4 of 23 Old 10-22-2013, 08:19 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Why is this important ? I routinely surf AVS on Chrome (10+ tabs) while having Firefox open with 5 more tabs on another monitor managing my Fantasy footballs teams, and IE open with a bunch more tabs doing random stuff. Plus I am downloading, Ripping, unzipping, and managing media at the same time.
I'm not being a smart ass, but genuinely want to know if this is important ? And why ? (aware me pls)
Mfusick is offline
post #5 of 23 Old 10-22-2013, 05:13 PM
NTNgod's Avatar
One practical reason is, that on a laptop or other fanned device, it might be the difference between your fan not running at all vs. spinning up when you're playing video.
StinDaWg likes this.
NTNgod is offline
post #6 of 23 Old 10-22-2013, 06:58 PM - Thread Starter
ymarker's Avatar
Quoted: 27 Post(s)
More cpu utilization = more power draw (i.e. your laptop runs out of juice earlier).
ymarker is offline
post #7 of 23 Old 10-23-2013, 08:37 AM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
Here's an even better reason. My cheapo netbook which would stutter badly on HD video now plays 1080p smooth as silk.
mdavej is online now
post #8 of 23 Old 10-23-2013, 07:18 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Thanks makes perfect sense. (I use a 4470k i7 Desktop)
I don't do much on the laptop anymore. I find it difficult to use as efficiently as I can my desktop. The lack of mouse bothers me greatly.
Mfusick is offline
post #9 of 23 Old 10-24-2013, 01:34 PM
mdavej's Avatar
Liked: 940
Gotcha. In my case, lugging a desktop and monitor through airports and hotels is a lot harder than getting a mouse for my laptop wink.gif I never watch Netflix on a computer otherwise. There are tons of other devices that do it a lot better.
post #10 of 23 Old 10-27-2013, 12:26 PM
Jeff Krogue's Avatar
IE 11 still hasn't made it possible for zacate e350 or e450 to play HD netflix, so I guess its not offloading enough.
Jeff Krogue is offline
post #11 of 23 Old 10-27-2013, 07:48 PM
Ruiner's Avatar
The bottleneck is still Silverlight there.
Ruiner is offline
post #12 of 23 Old 10-27-2013, 08:31 PM
mdavej's Avatar
Liked: 940
How is that possible? IE11 doesn't use silverlight.
post #13 of 23 Old 10-28-2013, 10:12 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
I just tried it on mine, IE11 with Core-i3 3225 with Intel IGP. 2 to 3% CPU usage on 1080p 5800bps (the max Netflix can offer today sans 3D) video. Is AMD really that bad?
Foxbat121 is online now
post #14 of 23 Old 10-28-2013, 11:48 AM
mdavej's Avatar
Liked: 940
Hmmm... my AMD C-60 is far slower than the e350 or e450, yet plays 1080p 5800 silky smooth in IE11. Previously choked badly on just 720p in Silverlight before. Jeff, are you really running 8.1? Maybe your GPU is the problem.
post #15 of 23 Old 10-28-2013, 12:06 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
Or could be video drivers. Win8.1 may replaced it with an older non-hardware accelerated driver.
post #16 of 23 Old 10-28-2013, 12:43 PM
Yeah, just checked amd website.  There are no drivers for 8.1 on the website right now.
post #17 of 23 Old 10-28-2013, 12:57 PM
Ruiner's Avatar
My bad. Even for netflix?
Ruiner is offline
post #18 of 23 Old 10-28-2013, 12:59 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
IE11 has the new Netflix player, probably built with HTML5, that can support 1080p and Super HD. The old Silverlight based player is only capable of 720p max.
post #19 of 23 Old 10-28-2013, 01:04 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
It doesn't surprise me at all. After brief stint with an AMD video card, I will never own another AMD video card ever (driver slow to update and take forever to load then crash constantly). In the CPU side, I don't even bother look at AMD at all. Other than AMD die-hard fans, I can't think of any reason to build an AMD based system.
post #20 of 23 Old 10-28-2013, 02:28 PM
Ruiner's Avatar
Interesting. There is a version of ie11 for Win7. I will have to test this.
Ruiner is offline
post #21 of 23 Old 10-28-2013, 02:55 PM
mdavej's Avatar
Liked: 940
Don't bother. IE11 for Win7 still uses Silverlight. IE11 in 8.1 is currently the only way.
post #22 of 23 Old 10-28-2013, 06:56 PM
oops
post #23 of 23 Old 10-29-2013, 05:43 AM
Ruiner's Avatar
Oh well. thanks.
Ruiner is offline
Reply Home Theater Computers
