Toslink from PCI Soundcard - AVS Forum | Home Theater Discussions And Reviews
Old 10-22-2013, 08:22 PM - Thread Starter
kckun's Avatar
Hello everyone
I am currently using a Yamaha 5.1 HT System but only with 2.1 channel, with amp crossover. So I need 2 channels input only.
The receiver has two toslink inputs. I have tried to connect it to a PlayStation 2 and it worked.
I remember that the sound quality of toslink is better than the analog 3.5mm to RCA from a Realtek onboard sound chip.
Therefore, I would like to upgrade a bit by using toslink with the computer.
May I ask is there any differences in sound quality in toslink with inexpensive and expensive sound card?
Also is there any digital only sound card? Since I don't need the DAC.
Please recommend a gear within $40:) PCI or PCIE x1
Thank you very much,
Johnson.
kckun is offline
Old 10-22-2013, 10:14 PM
A9X-308's Avatar
Quoted: 1296 Post(s)
Liked: 959
I wouldn't coun ton that being the case. However, as your AVR most likely operates almost completely in the digital domain, ie digitises analogue signal for processing, it saves you a conversion.
No. Does your mobo have a Tos out?
Buy a cheap card with the Tos output and don't worry about not using the onboard DAC.
A9X-308 is offline
Old 10-23-2013, 02:42 AM - Thread Starter
kckun's Avatar
Thank you for answering. My motherboard has no Toslink output, only 3 3.5mm plugs. It seems to be a low end motherboard.
kckun is offline
Old 10-23-2013, 08:20 AM
pittsoccer33's Avatar
Quoted: 648 Post(s)
Liked: 426
It is possible your motherboard has SPDIF headers on it, but doesn't have an actual connection on the back. you can get a bracket that will connect to that header and won't need a sound card.
kckun likes this.
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is online now
Old 10-23-2013, 10:49 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
$19 for PCI http://www.newegg.com/Product/Product.aspx?Item=N82E16829130002
$20 for PCI-e http://www.newegg.com/Product/Product.aspx?Item=N82E16829186003
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
Old 10-24-2013, 05:05 AM
Mike99's Avatar
Quoted: 133 Post(s)
Liked: 63
That's what I did. If search this forum there are threads on how to make a bracket/connector which is what I did. Cost was 0.
kckun likes this.
Mike99 is offline
