Organizing channels in WMC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-25-2013, 09:13 PM - Thread Starter
jefejt's Avatar
Originally when I set up my HTPC I used guidetool to organize my channels. Recently I went to a cablecard setup and guidetool doesn't seem to be working. When I open it I get an error.
Failed to create TV Setup Helper. No connection could be made because the target machine actively refused it 127.0.0.1:5733.
Please make sure media center is started.
WMC is certainly started. I can edit the channels one by one, but that's going to be a PITA. Any suggestions?
jefejt is offline
post #2 of 2 Old 10-25-2013, 09:16 PM - Thread Starter
jefejt's Avatar
Sorry, good old google came through:
You have to make sure the guidetool addin button is ticked in the settings menu (can't quite remember where it's located), then you have to run media center in windowed mode (not minimised).
Problem solved.
jefejt is offline
Reply Home Theater Computers
