New to htpc. Need hardware advice - AVS Forum | Home Theater Discussions And Reviews
Old 10-26-2013, 02:23 PM - Thread Starter
hamann4242's Avatar
Hello
I'm going to build a HTPC. It will be running XBMC in Windows 8. It will be used for 1080p 2D playback and .FLAC audio through HDMI to my receiver(needs to be hdmi 1.4)
Here's the hardware i found suitable, am I correct?:
CPU:Intel Core i3-4340 Haswell, 3,6ghz dualcore with HD 4600 graphics
Cpu coolerScythe Big Shuriken 2 Rev.
RAM:Crucial Ballistix T DDR3-1600 DC - 8GB
Case: SilverStone Grandia SST-GD05B Black
PSU: Corsair CX430M - 430W PSU
HDD: Western Digital WD Green - 3TB
SSD: Samsung 840 EVO SSD - 120GB
Motherboard: ASUS H87M-PRO (C2) - Haswell
hamann4242 is offline
Old 10-26-2013, 06:53 PM
wiley165's Avatar
Location: State of Rhode Island and Providence Plantations
Quoted: 61 Post(s)
Liked: 98
Nice Build.
You don't need the aftermarket CPU Cooler right away. IMO, I would start off with the stock cooler, then decide if you want to upgrade later.
You can also get by with a 4GB (2x2) RAM kit.
wiley165 is online now
Old 10-27-2013, 04:43 AM - Thread Starter
hamann4242's Avatar
Is the motherboard a overkill? I don't need optical audio, since I will use HDMI. So a H81 would maybe be enough?
Or do I need features like Intel RST12 and Intel Smart Response Technology?
Old 10-27-2013, 09:01 AM
wiley165's Avatar
Quoted: 61 Post(s)
Liked: 98
That's a nice Mobo. I personally have the ASUS P8H77-M Pro (Same board previous generation).
I had some problems with the Asus, and I ended up getting a cheaper AsRock H77M mobo during my troubleshooting process.
The AsRock Mobo ended up meeting all my needs, for half the price of the Asus.
After a few RMA's with Asus on that board, when I finally got a working board back, I just used the Asus board for a new Desktop build, and left the AsRock in for my HTPC.
It all comes down to the features you need in the motherboards chipset.
It worked out well enough because I opted to build a separate media server to host all my files, rather than locally on my HTPC. For the server, I opted for a MSI-B75 board.
Here's a decent article that breaks down the features of each chipset:
http://www.pugetsystems.com/labs/articles/Z87-H87-H81-Q87-Q85-B85-What-is-the-difference-473/
Think about your budget, and also consider what you might want to do in the future when making your choice.
Old 10-27-2013, 09:09 AM
wiley165's Avatar
Quoted: 61 Post(s)
Liked: 98
Try to look at quality boards from Asus, AsRock, Gigabyte, and MSI.
I was weary of AsRock, but they really do put together a nice board. Once a subsidiary of Asus, they have since gone on their own, and pack a lot of extras in many of their boards.
I've done many builds with Gigabyte, and never had a problem with any of their boards.
Old 10-27-2013, 09:19 AM - Thread Starter
hamann4242's Avatar
I have used Asus components for 3 pc's without any issues, so I will stick with Asus, even though they are more expensive.
It's not like I have a budget, but i won't spend more than necessary(except when it comes to Asus smile.gif ).
All files will be stored locally, since i live in an apartment and only have 1 tv.
4k will not be a requirement. Only 1080p 2D (but it would be nice to have the option for 3D, when i get a new TV in a few years) and DTS audio for my 7.1 receiver.
