Comcast encrypts HDHomerun no workie - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 10-28-2013, 02:25 PM - Thread Starter
stickboy2k's Avatar
Quoted: 29 Post(s)
Liked: 45
So now I have a HDHomerun which I can't use thanks to Comcast encrypting everything.
Is there anyway around this or do I have to now buy a HDHomerun with a Cable Card slot.
stickboy2k is offline
post #2 of 11 Old 10-28-2013, 02:32 PM
jdcrox's Avatar
Quoted: 78 Post(s)
Liked: 102
You have to buy a cablecard tuner. No workarounds that I am aware of.
jdcrox is offline
post #3 of 11 Old 10-28-2013, 03:01 PM
bryansj's Avatar
Quoted: 1123 Post(s)
Liked: 555
The workaround is to buy an antenna. Otherwise you will need a cablecard tuner.
bryansj is offline
post #4 of 11 Old 10-28-2013, 07:04 PM
gtgray's Avatar
Quoted: 206 Post(s)
Liked: 136
They did this in my market 2 years ago at least. I have an antenna and a cable card. I watch the local on antenna unless there is a service problem... OTA is a better picture than cable. And it so easy to get mad at Comcast I always want the option to tell them to stuff it.
Samsung 78" JS8600, Mits WD-92840 43" Samsung 43ku7000 - Lumagen Radiance XS, Martin Logan Motion 40s, Ascend Sierra 2s
58" Panny Plasma -DVDO DUO, Usher S520, JBL HLS-610, Definitive SM45, MusicHall Marimba
gtgray is offline
post #5 of 11 Old 10-29-2013, 10:49 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
We too, are getting OTA off the air with 3x HomeRun Duals (6 tuners) and CableTV off Ceton InifiniTV6 ETH (6 tuners). This is the best of both worlds. Not subject to local cable franchize blackouts, and get better picture quality.
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
post #6 of 11 Old 10-29-2013, 11:18 AM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
We lost clearQAM on Oct 1. We're too far from the antennas and in a small valley so we're out of luck with OTA. We also already had a CableCard tuner (HDHR3-CC) so we're down to the 3 tuners there.
If you can't get OTA then dump your tuners on eBay.
StardogChampion is offline
post #7 of 11 Old 12-09-2013, 01:58 PM
mrredskin's Avatar
this is happeneing in the Knoxville area in a month. did you run into any issues setting yours up?
mrredskin is offline
post #8 of 11 Old 12-09-2013, 02:11 PM
gtgray's Avatar
Quoted: 206 Post(s)
Liked: 136
Happened in Houston a couple of years ago. The HD Homeruns work just fine with my rooftop antenna. I could never stand QAM Cable with Comcast, they moved things around so much it was pointless. I like having a guide. Get a cablecard tuners my brother has both the SD HD Prime and Ceton tuners. I have a Ceton.... he has had a world of hell with the Cetons. He loves the Prime although he still uses both. I would buy a Prime if they ever shipped a 4 tuner as once promised. My Ceton works but it needs the most pristine signal possible.
gtgray is offline
post #9 of 11 Old 12-09-2013, 04:20 PM
Quoted: 93 Post(s)
Liked: 160
I already had a HDHR3-CC tuner running alongside my HDHR tuner. I didn't have much trouble getting the CC tuner set up. I picked up the CC from my local Comcast office where they put everything into my account. I hooked it all up, inserted the card, installed the HDHR software on an HTPC and then followed the instructions I received with the CC and gave them the numbers on the screen. It mostly worked but I had to call back and have a "hit" sent to the card which I was able to do through the automated phone system. It's worked like a charm since. It's been 2 years.
I wish SiliconDust had a six-tuner single CC tuner. I know Ceton does but if it ain't broke don't break it.
post #10 of 11 Old 12-09-2013, 04:28 PM
rlhowell's Avatar
I am bowing up the judge prime to work with my two hdhre standard.
I am setting the other two up with it a antennas.
Work in progress.
Some will tell
rlhowell is offline
post #11 of 11 Old 12-09-2013, 04:31 PM
rlhowell's Avatar
Sorry. That last post is nonsense. Used m y kindle which edits my words to true junk. I live in Atlanta and have the same problem.
rlhowell is offline
Reply Home Theater Computers
