Maybe a stupid question but - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 10-29-2013, 02:05 PM - Thread Starter
Farish's Avatar
Beginning to build and setup a HTPC with an HD Homerun Prime.
My question is about the channels that come across in SD. I understand that the recording will be done in 480p but will the WMC on upscale the feed to the television? If not is there any possible solution to that issue?
Farish is offline
post #2 of 8 Old 10-29-2013, 02:13 PM
mdavej's Avatar
Quoted: 2130 Post(s)
Liked: 942
Yes. It will typically be 4:3 filling the screen top to bottom with bars on the sides. You can zoom several different ways in WMC to stretch, crop or letterbox as you like. You could use your TV's zoom options as well.
mdavej is online now
post #3 of 8 Old 10-29-2013, 02:18 PM
pittsoccer33's Avatar
Quoted: 648 Post(s)
Liked: 426
i actually think they will be interlaced
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
post #4 of 8 Old 10-29-2013, 02:32 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 401
I believe so as well (480i for SD). WMC will convert everything to whatever your screen resolution is set at. Don't worry about it.
Often, ppl want leave output video to be exactly like input so that you can use external video processors to process them better than WMC (it does a so so job). But this is not possible with WMC.
Foxbat121 is offline
post #5 of 8 Old 10-29-2013, 02:39 PM
leebo's Avatar
Quoted: 527 Post(s)
Liked: 296
Beginning to build and setup a HTPC with an HD Homerun Prime.My question is about the channels that come across in SD. I understand that the recording will be done in 480p but will the WMC on upscale the feed to the television? If not is there any possible solution to that issue?
What exactly is your issue?
Sent from my Nexus 7
leebo is offline
post #6 of 8 Old 10-29-2013, 02:57 PM
mdavej's Avatar
Liked: 942
How can you tell? I'd check if I knew how.
EDIT: Nevermind. 411 Info or MediaInfo should do the trick. I'll give it a try later.
post #7 of 8 Old 10-29-2013, 03:04 PM
Quoted: 648 Post(s)
Liked: 426
I just don't think any cable company sends a progressive feed for sd. Ntsc standards were all interlaced .
411+info might tell you. You could see if you opened a recording up in a program that reads the media info.
post #8 of 8 Old 10-29-2013, 03:07 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 401
WMC debug screen should tell you that. 411 + Info (or Ctrl+D) to start the debug mode. Flip through to the last screen should show you the source video format.
Reply Home Theater Computers
