Lowest Video Card for MadVR ~$100 or so? - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #91 of 114 Old 11-15-2013, 09:25 AM
Sammy2's Avatar
Quoted: 535 Post(s)
Liked: 255
@emcdade, you mentioned earlier about my case being too stuffy. I am not noticing any increase in heat going from the GT 430 to the HD 7850 so I'm good with it.
Sammy2 is offline
post #92 of 114 Old 11-15-2013, 09:27 AM
Sammy2's Avatar
Quoted: 535 Post(s)
Liked: 255
Originally Posted by emcdade View Post
It will be nice when Kaveri APU's come out, first of next year I think?
They are rumored to have HD7750 graphics power on die! The only downside is that it will still use DDR3 memory. That's pretty outstanding for HTPC use, especially very small form factor cases.
Nice! Too bad they didn't go with DDR5 memory though.
Sammy2 is offline
post #93 of 114 Old 11-20-2013, 08:01 AM
cburbs's Avatar
Quoted: 94 Post(s)
Liked: 29
cburbs is offline
post #94 of 114 Old 11-20-2013, 08:23 AM
Sammy2's Avatar
Quoted: 535 Post(s)
Liked: 255
Yes.
Sammy2 is offline
post #95 of 114 Old 11-29-2013, 05:08 PM
cburbs's Avatar
Quoted: 94 Post(s)
Liked: 29
deleted
"You’re KILLIN’ ME Smalls! "
Sony 55EX500 Settings
cburbs is offline
post #96 of 114 Old 12-01-2013, 07:20 PM
cburbs's Avatar
Quoted: 94 Post(s)
Liked: 29
So the card is too tall for my case. I have this case - http://www.newegg.com/Product/Product.aspx?Item=N82E16811204030
Card is 4.61" according to website.
Case says 5.4"....
I would have to remeasure but guessing 1/2" too tall.
Is there another comparable card that might fit in this case?
cburbs is offline
post #97 of 114 Old 12-02-2013, 07:41 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2696
By too tall which direction to you mean ???
Double slot? Or would hit the side of the case ???
Mfusick is offline
post #98 of 114 Old 12-02-2013, 07:43 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2696
Mfusick is offline
post #99 of 114 Old 12-02-2013, 09:25 AM
cburbs's Avatar
Quoted: 94 Post(s)
Liked: 29
I can't put the cover back on.
cburbs is offline
post #100 of 114 Old 12-02-2013, 09:25 AM
cburbs's Avatar
Quoted: 94 Post(s)
Liked: 29
That one is too tall as well.... 5.1"
cburbs is offline
post #101 of 114 Old 12-02-2013, 12:23 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2696
I smell a new case cooking...
Mfusick is offline
post #102 of 114 Old 12-04-2013, 10:31 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2696
This seems like a great deal on a good card (more than enough)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150604
Mfusick is offline
post #103 of 114 Old 12-04-2013, 10:34 AM
Sammy2's Avatar
Quoted: 535 Post(s)
Liked: 255
Not quite as good as the 7850 for $105 AR a few weeks ago. My rebate is already approved and its way!
Apparently it just dropped to $90 AR.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150642
I am on chat with newegg as I type this to see what can be done about that..
Sammy2 is offline
post #104 of 114 Old 12-04-2013, 11:12 AM
Sammy2's Avatar
Quoted: 535 Post(s)
Liked: 255
When you know, you newegg.
$15 gift card for a future purchase which I'm sure I'll never use. tongue.gif
Sammy2 is offline
post #105 of 114 Old 12-04-2013, 11:36 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2696
Well 7870 > 7850 it's nearly twice as powerful. Perhaps more than enough for HTPC only, but I game too biggrin.gif
Mfusick is offline
post #106 of 114 Old 12-04-2013, 12:09 PM
Sammy2's Avatar
Quoted: 535 Post(s)
Liked: 255
That is still a great price on that card for sure!
Sammy2 is offline
post #107 of 114 Old 12-04-2013, 12:18 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2696
I have a 6870 X2 XFX double slot card now that seems to work fine (for MadVR too) so IDK ??? I might hold off for a 79xx card Or the newer version.
Sammy2 likes this.
Mfusick is offline
post #108 of 114 Old 12-06-2013, 01:51 PM
cburbs's Avatar
Quoted: 94 Post(s)
Liked: 29
I am still looking for something to replace my current card with - XFX HD-645X-ZQH2 Radeon HD 6450 1GB 64-bit DDR3 PCI Express 2.1 x16 HDCP Ready Low Profile Ready Video Card but it looks like it can't be much taller than 4".
Also what is Newegg policy on returning open/tested items - do you get al lmoney back or only partial?
Also if the card says - Power Connector
2 x 6 Pin
Does it require two connectors for power? How do you verify what power is required for the Video card?
cburbs is offline
post #109 of 114 Old 12-16-2013, 07:08 AM
cburbs's Avatar
Quoted: 94 Post(s)
Liked: 29
Anyone have any ideas - I came across these two cards -
http://www.newegg.com/Product/Produc...82E16814202012
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150682
cburbs is offline
post #110 of 114 Old 12-16-2013, 03:26 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2696
Those are the replacement cards for the old HD series. The new versions are the "R" series. Yup those would work.
The R7 260X with 2GB would be a good choice, it's the replacement for the HD 7790
Mfusick is offline
post #111 of 114 Old 12-17-2013, 09:22 AM
ianeicher's Avatar
Has anyone seen any testing on how the R series work with MadVR? I think I'd rather get the latest gen is pricing is comparable. I'd be looking to do level 5 at 1080P as a goal.
ianeicher is offline
post #112 of 114 Old 12-17-2013, 09:50 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2696
Assuming you get the equal to an HD series I would not expect it to perform any different. Something that is 7790 level or higher should be fine.
The name change is just a rebadge. There is little reason (none actually) to think it would not work as good as the older HD series it replaces.
Mfusick is offline
post #113 of 114 Old 12-17-2013, 11:54 AM
ianeicher's Avatar
Thanks. You know where a guy could find a cross reference chart? And I don't think it's a rebadge based on Newegg spec sheets. The # of stream processors and memory clocks look different. Does this affect performance or maybe allow to step down to a lower end card to get same MadVR capabilities? I don't know.
post #114 of 114 Old 12-17-2013, 12:10 PM
Andy_Steb's Avatar
Quoted: 31 Post(s)
Liked: 158
the Radeon R7 260X isn't based on any new silicon. It has quite a few things in common with the Radeon HD 7790 launched just this March, but differs from the HD 7790 by running higher clock speeds and double the standard memory amount
http://www.techpowerup.com/reviews/AMD/R7_260X/
Andy_Steb is offline
Reply Home Theater Computers
