Lowest Video Card for MadVR ~$100 or so? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #1 of 114 Old 10-29-2013, 11:59 PM - Thread Starter
jeff lam's Avatar
The last thread like this I saw was over a year old so I wanted to get some updated opinions on what video card will offer the best price/performance and be able to handle all the best or near best settings in MadVR. obviously, it must bitstream HD Audio formats through HDMI to my receiver. There will be no gaming on this machine, only HTPC video playback. But I want the best video quality I can get out of the HTPC.
I was thinking about the GTX 650 as it seems to be a great card for the money. Overkill? Anything better for the same or less money?
jeff lam is offline
post #2 of 114 Old 10-30-2013, 01:56 AM
Nevcairiel's Avatar
Quoted: 43 Post(s)
Liked: 135
I have a GTX 660 and it does the job just perfectly.
The 650 has significantly less shader cores, so it would be much slower. However, if its still enough for madVR i cannot tell you from lack of experience. Some of the advanced madVR algorithms are quite demanding, though.
If your budget allows, you could also go for a GTX 650 Ti to have some more performance headroom. If the 650 is your top limit, it will certainly work, but you might not be able to use all of the advanced features (especially future things being added, like debanding which will be in the next madVR release)
Nevcairiel is offline
post #3 of 114 Old 10-30-2013, 04:31 AM
Sammy2's Avatar
Quoted: 556 Post(s)
Liked: 264
DAMMIT!
Looks like my 2 y.o. GT 430 is just not going to cut it any longer..
Are there any recommendations in the AMD line that are in the price range of the GTX 650 Ti?
Sammy2 is offline
post #4 of 114 Old 10-30-2013, 04:58 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
7770 Radeon is under $99 and enough for all levels of MADVR
7790 is even better ( also under $100 on sale)
Sammy2 likes this.
Mfusick is offline
post #5 of 114 Old 10-30-2013, 06:08 AM
Sammy2's Avatar
Quoted: 556 Post(s)
Liked: 264
Perfect! I will begin to investigate but wonder still how these will perform with the soon to be introduced debanding? If this is for interlaced content it doesn't matter too much because most all, if not all, of my content is 1080p with some 720p.
Sammy2 is offline
post #6 of 114 Old 10-30-2013, 06:23 AM
Nevcairiel's Avatar
Quoted: 43 Post(s)
Liked: 135
Banding can occur in all kind of content, usually a result of too high compression.
post #7 of 114 Old 10-30-2013, 06:30 AM
Sammy2's Avatar
Quoted: 556 Post(s)
Liked: 264
I do 1:1 rips usually but the studios often compress when they master the discs. Too bad that madVR and LAV cannot be in the playback chain for US copy protected CATV content so this forthcoming anti-banding filter can be utilized for that compressed material.
At least CATV is better than Uverse as far as compression goes though.
Sammy2 is offline
post #8 of 114 Old 10-30-2013, 06:36 AM
Sammy2's Avatar
Quoted: 556 Post(s)
Liked: 264
BTW, rather than discuss specific cards, what are the minimum specifications to look for in a card to run this upcoming anti-banding filter?
Sammy2 is offline
post #9 of 114 Old 10-30-2013, 07:04 AM
Elpee's Avatar
Quoted: 69 Post(s)
Liked: 25
Have the same question. Looking for a new video card to replace an old one in my THPC. Thanks for the inputs.
Elpee is offline
post #10 of 114 Old 10-30-2013, 10:24 AM
emcdade's Avatar
Quoted: 147 Post(s)
Liked: 145
Not sure how that would be easier, and only gets more confusing when comparing across Nvidia and AMD offerings. As a baseline, I would want a card with GDDR5 memory.
Refer to ReneTHX's chart here: http://www.avsforum.com/t/1477339/so-youve-built-your-htpc-now-what-is-next-how-to-get-the-ultimate-picture-and-sound-quality-from-your-htpc-madvr-svp-xbmc-mediabrowser-jriver/60
emcdade is offline
post #11 of 114 Old 10-30-2013, 10:35 AM
Sammy2's Avatar
Quoted: 556 Post(s)
Liked: 264
I've read that thread. I need to bookmark it now. Thanks.
I wonder how this will all pan out with the nee anti-aliasing filter?
Sammy2 is offline
post #12 of 114 Old 10-30-2013, 11:06 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
I think something like a 7790 has a bit of headroom (more than enough) so it's a really good choice without breaking the bank. Now that the rebadge models are launching you can pick one of these up for $100
Mfusick is offline
post #13 of 114 Old 10-30-2013, 11:25 AM
Sammy2's Avatar
Quoted: 556 Post(s)
Liked: 264
Any particular brand / model?
Sammy2 is offline
post #14 of 114 Old 10-30-2013, 11:39 AM
emcdade's Avatar
Quoted: 147 Post(s)
Liked: 145
Agreed, low TDP as well compared to the next step up 7850. Excited to see what 20nm process will bring us next year.
I have always had good luck with ASUS. Here's an open box for $100.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121727R
emcdade is offline
post #15 of 114 Old 10-30-2013, 12:00 PM
Sammy2's Avatar
Quoted: 556 Post(s)
Liked: 264
New AR isn't much more and I have an amazon store credit too. Hmm..
Sammy2 is offline
post #16 of 114 Old 10-30-2013, 02:06 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
I like XFX and Asus myself...
Saphire I heard was also quiet.
Mfusick is offline
post #17 of 114 Old 10-30-2013, 02:08 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
http://www.avsforum.com/t/1492107/help-me-build-a-htpc-for-less-than-800-just-movies-and-music/0_100
This thread had some good talk in it:
Originally Posted by renethx View Post
If you are interested in madVR (Jinc) upscaling SD / HD -> FHD, HD 7770 or GTX 650 Ti is minimum (and enough). Quietness is one of the keys in choosing a graphics card. Some of the quietest cards are
Sapphire HD 7770 Vapor-X
ASUS HD7790-DC2OC-1GC5 (fits only an ATX case because of taller heatpipes)
MSI N650Ti TF 2GD5/OC BE
AMD card is straightforward to set up (23.976Hz, switching between full and limited RGB, stereoscopic 3D all work instantly as they should). NVIDIA card needs lots of tweaks (that's why I prefer AMD).
Mfusick is offline
post #18 of 114 Old 10-30-2013, 02:54 PM
Sammy2's Avatar
Quoted: 556 Post(s)
Liked: 264
I have this card crammed in my case right now so I think the taller heat pipes of the HD7790 will fit. I need to find the dimensions and see. Fortunately I did not go with a low profile case when I built my HTPC.
Edit: This is 7.3" x 4.4" and the HD7790 is 8.5" x 5.1" so it is a bit bigger. I'm not sure if I have that much room or not.. I will need to verify by opening up the case, I guess.
Sammy2 is offline
post #19 of 114 Old 10-31-2013, 11:13 AM
Sammy2's Avatar
Quoted: 556 Post(s)
Liked: 264
This Radeon HD 7850 1GB 256-bit GDDR5 will be $105 AR on Shell Shocker in a little while today.. Thoughts?
BTW, my antec NSK 1380 case has a 350W power supply that cannot be upgraded because it is custom fit to the case.
Sammy2 is offline
post #20 of 114 Old 10-31-2013, 11:37 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
I am not sure if the more advanced chip works better for MADVR.
I think the clock speed is 860mhz on those versus 1075mhz on a 7790- not sure how that effects Madvr Performance.
I would tend to think the higher 7800 series card would do well since it's above the 7700 series- but a "50" versus a "90" puts the bottom of the 7800 lineup against the top of the 7700 lineup. I would not imagine the difference would be very great. Much like how a faster or higher mhz single or dual core chip can sometimes be faster at single threaded applications versus a slow quad core. IDK ???
In any event- 7790 is enough (7770 is actually enough with only 1GB) so I am not sure you would get the traditional benefits of the higher card being a non gamer. ?? IDK ?? If the price is right I would imagine it's a good choice. But I would not pay more for it.
Something like a 7870 is what I have my eyes on personally. A good step above the 77xx cards. But I already have a 6870 X2 which is "enough" so IDK? I think I am rambling.....
Mfusick is offline
post #21 of 114 Old 10-31-2013, 12:12 PM
Sammy2's Avatar
Quoted: 556 Post(s)
Liked: 264
Yes that was quite the ramble..
It looks like the price is comparable during the Shell Shocker window between the 7790 and 7850 cards but looking at the specs on newegg's page the 7790 does seem to be a better card, with the exception of the lower stream processors of 896 compared to 1024 for the 7850 with the 7790 having a lower power demand.
One other thing, I don't have an SLi Header on my PSU. Do these cards require it and I'll need an adapter off of Molex?
Sammy2 is offline
post #22 of 114 Old 10-31-2013, 01:08 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
I think a XX90 will need a PSU power plug (or 2)
Some of the low power xx50 cards sometimes power only off PCI slot. You will need to pay attention to the card you get. My 6870 uses dual power, so I would imagine a newer more powerful card certainly would. I know I have seen the 50 series without them, but I never noticed with the 70 or 90 series. I am guessing you need it with a powerful card.
What does the specs say ? I am guessing it has 6 pin power connectors
Mfusick is offline
post #23 of 114 Old 10-31-2013, 01:13 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Mfusick is offline
post #24 of 114 Old 10-31-2013, 01:20 PM
Sammy2's Avatar
Quoted: 556 Post(s)
Liked: 264
From Asus for the 7790:
Power Consumption: up to 150W1 additional 6 pin PCIe power required
I just realized that this is $130 AR but the 7850 is only $105 AR on SS right now.
Sammy2 is offline
post #25 of 114 Old 10-31-2013, 01:22 PM
Sammy2's Avatar
Quoted: 556 Post(s)
Liked: 264
So both the 7790 and 7850 need power but that can be taken off a molex with the right adapter (from monoprice of course)?
Sammy2 is offline
post #26 of 114 Old 10-31-2013, 01:26 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
http://www.newegg.com/Product/Product.aspx?Item=N82E16812887001
This is an option if you get desperate although often times it's better to replace your PSU
You have two IDE power free (I am guessing yes)
Mfusick is offline
post #27 of 114 Old 10-31-2013, 01:33 PM
Sammy2's Avatar
Quoted: 556 Post(s)
Liked: 264
Replacing the PSU in my case means replacing the case as it is integral. I'm not too worried about having enough power as everything else in there is low power.. Low RPM HDD's, SSD, clarkdale CPU, etc. There isn't even an optical drive in the case.
There's no IDE devices in the machine at all.
Case
Sammy2 is offline
post #28 of 114 Old 10-31-2013, 01:36 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182081
50% OFF with private coupon code. That's a bad ass-ed PSU for $50:eek: It would be ideal (if you can fit it)
Silent Fan only kicks on when needed, and it's 94%+ efficient PLATINUM. Japanese capacitors, double ball bearing etc...
Mfusick is offline
post #29 of 114 Old 10-31-2013, 01:37 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Case
You can probably rig it with IDE then. Buy the $5 adapter. (monoprice does not sell them I don't think )
Check to see because some cards come with those adapters. I have a couple floating around. If I find one I'll send it to you if you really need it. I won't use it. All my PSU have the wires.
Mfusick is offline
post #30 of 114 Old 10-31-2013, 01:48 PM
Sammy2's Avatar
Quoted: 556 Post(s)
Liked: 264
Sammy2 is offline
Reply Home Theater Computers
