AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Home Theater Computers (http://www.avsforum.com/forum/26-home-theater-computers/)
-   -   no signal with amd 6670, intel integrated hd works fine on projector (http://www.avsforum.com/forum/26-home-theater-computers/1497462-no-signal-amd-6670-intel-integrated-hd-works-fine-projector.html)
taylor310 10-31-2013 09:38 PM
This is the weirdest thing. I unhook my amd hd 6670 and my i3 clardale intel hd works just fine, but when I put my amd hd 6670 into my computer I get no signal. I am running my PC to a Denon AVR to a projector with a 50 ft hdmi cable. The AMD 6670 will work just fine on a 1080p 23 inch monitor, but i get no signal at all on my projector. I go into info on my projector and it shows a crazy resolution that the PC is not set on. I vnc into the pc and make sure it's 1080p60 and it is but nothing on the screen. Updated to the newest AMD drivers tonight, tried numerous resolutions/refresh rates but i get nothing. Do any of you guys have any idea what could be causing this? I had the AMD 6670 plugged into a 65 inch plasma previously and it worked fine, but now on the projector i get no signal. I really would like to get the AMD working as I enjoy MadVR.
Any help would be greatly appreciated. I'm pulling my hair out here.
Mrkazador 10-31-2013 09:41 PM
40 Attachment(s)
Do you see the bios post screen when booting up? or windows logo?
taylor310 10-31-2013 09:43 PM
Yes I do. In fact when I vnc into the pc I can go into device manager and disable the AMD 6670 and I will get an 800x600 video that outputs to the projector. It's like something in the mix doesn't want to play well with others.
Mrkazador 10-31-2013 10:09 PM
40 Attachment(s)
Is it possible to connect the PC directly to the projector? I wonder if the 50ft HDMI cable is the problem...
taylor310 11-01-2013 08:39 AM
It will be difficult since the projector is ceiling mounted. The home cable has no issues with cables and with the pc if I use Intel hd video adapter. I'll give it a try.
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
