Help, question reg watching live tv on GoogleTv using SiliconDust device - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-01-2013, 07:48 AM - Thread Starter
KG1
KG1's Avatar
Hi,
I have a quick question. I am planning to buy the HDTC-2US as I would like to have transcoding capability.
I currently have a PC upstairs (connected to a projector) and a TV downstairs that I would like to watch live tv and recorded TV on.
I am still trying to figure out what s/w to use to be able to see the guide, start recording the shows, watch recorded shows.
I know I can use Windows Media Center upstairs on my PC, but what about downstairs where I have no PC?
My PC runs Plex Media Server and I have Plex clients running on both my GoogleTV's so I can play any media stored on
my PC on the projector and TV through my GoogleTV's Plex interface.
I don't mind running windows Media Center s/w upstairs to watch live tv (if that is the only option), but I definitely
don't want to add another PC just so i can get to use a TV Guide. I probably will be able to just access the recorded
TV shows through Plex since they will be stored as MP4? So watching recorded content I am thinking should not be that
much of a problem, but watching live tv might be a problem downstairs without a PC. Is this correct?
Here is my full components list:
Upstairs:
Win 7 64bit PC, Denon 3310 A/V receiver, Projector, GoogleTV (Revue), gigabit switch connected to all these components
Downstairs:
PS3, Denon 1613 A/V receiver, GoogleTV (Revue), gigabit switch (this is connected to the upstairs gigabit switch)
Thanks in advance,
KG
I did search around and found some apps (InstaTV, HomeRunTV) that will allow me to watch on Android tablet/phone, but those
won't work with my GoogleTV's.
There is the Tune N View app that works with GoogleTV, but does not have a TV Guide and from what I could find, Plex plugin
also does not work.
KG1 is offline
post #2 of 7 Old 11-01-2013, 08:28 AM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
That's what extenders do. Ceton Echo, Xbox, etc. Get one, then plug it into your Google TV if you must: http://www.thegreenbutton.tv/forums/viewtopic.php?f=22&t=5569
If you aren't married to WMC, then XBMC and a Raspberry Pi will also do the job.
If I were you, I'd also hold out for the HDTC4-2US.
mdavej is offline
post #3 of 7 Old 11-01-2013, 09:13 AM
netant's Avatar
Tune N View - no guide and slow channel change. For HD, you probably need a wired connection to be usable.
InstaTV - guide is a work-in-progress but unless Google update all google tv to 4.2 I doubt InstaTV will work.
SiliconDust will release an Android app with HDTC (with guide I believe). But, same reason for InstaTV, unless Google update all google tv to 4.2, the Android app probably won't work on GoogleTV too. Google TV is a mess. You may be better off buying some Chinese Android TV stick that runs full Android.
netant is offline
post #4 of 7 Old 11-01-2013, 09:30 AM - Thread Starter
KG1
KG1's Avatar
Thanks mdavej, that is great news!, if I get an extender, can I be watching live tv downstairs via the extender, but watch a movie upstairs on the PJ? I think so, but just want to confirm.
KG1 is offline
post #5 of 7 Old 11-01-2013, 09:32 AM - Thread Starter
KG1
KG1's Avatar
Thanks netant, did not realize InstaTV has a guide feature in the works. I know about the SD app, but not sure if that will come with guide.
I am hopeful that with the latest KitKat announcement, all future GoogleTV's will run the full blown version of latest android, which then will bring the InstaTV app back into play for me...
KG1 is offline
post #6 of 7 Old 11-01-2013, 10:03 AM
pittsoccer33's Avatar
Quoted: 648 Post(s)
Liked: 426
Yes you can. I have this same set up
WMC PC that is my dvr and main movie player. It runs Plex server in the background.
Then in my bedroom I have a Logitech Revue with a Linksys DMA2100 extender plugged into it. That way I get the best of everything on one tv input - live tv, recordings, netflix, and access to my archived films
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
post #7 of 7 Old 11-01-2013, 10:13 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
You can add up to 5 simultaneous, and unlimited number extenders to a WMC system for viewing TV and other content other than PC hosting WMC. We have 6 TV's in the house with a single HTPC, and 5 extenders. Each TV is like its own DVR, but you can view stuff recorded on "one TV" on any other TV. Or pause on "one TV" and resume on "another TV"
Edit: Just maek sure your HTPC complies with Microsofts requirements for Extender use.
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
Reply Home Theater Computers
