HTPC Component Advice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-01-2013, 05:04 PM - Thread Starter
MightyGeekMan's Avatar
Hey all,
I'm building a new HTPC for my home theater and, after much research, have decided on the following parts. This is for consumption of movies and music and streaming. No gaming, overclocking or content ripping/creation will be done on this machine.
I'd like to know if any of the HTPC gurus here think I'm missing anything, or if there's anything I should change. I'm planning on purchasing Sunday evening, so I have this weekend to make changes.
GeekMan
dotsonscreen.com
MightyGeekMan is offline
post #2 of 7 Old 11-01-2013, 05:47 PM
Dropkick Murphy's Avatar
Quoted: 71 Post(s)
Liked: 89
That case is huge, are you installing storage drives in there?
Dropkick Murphy is offline
post #3 of 7 Old 11-01-2013, 06:04 PM - Thread Starter
No storage drives needed. I have two 32TB NAS devices which house all my media. I chose the LC 10-E because it will allow good airflow, fits everything nicely and allows for expansion if/when needed. Plus, it will be in an AV closet, so it's size and noise levels aren't really an issue.
GeekMan
dotsonscreen.com
post #4 of 7 Old 11-04-2013, 03:09 PM - Thread Starter
Just a quick update on my build. After mulling it over in my head over the weekend, I've decided to pull the trigger and ordered the following:
I'm planning on making a YouTube video (or series) of the actual building process. Will post here when that happens.
GeekMan
dotsonscreen.com
post #5 of 7 Old 11-04-2013, 04:05 PM
utee05's Avatar
Quoted: 30 Post(s)
Any reason why you went with the kingston memory over g.skill? I have both in separate builds and don't really notice much of a difference. Currently looking at building another htpc and need some memory and mobo. I already have a mobo picked out so memory is the last item.
utee05 is offline
post #6 of 7 Old 11-05-2013, 12:56 PM - Thread Starter
I went with the Kingston RAM only because the G. Skill had very large heatsinks which MAY have caused an airflow/cooling problem if I decided to add an aftermarket CPU cooler later on. It was really just a matter of wanting to keep my upgrade options open. Also, since Kingston is a good RAM name I don't feel like switching will cost me any performance while allowing for a little bit more flexibility if I ever needed it.
GeekMan
dotsonscreen.com
post #7 of 7 Old 11-06-2013, 09:32 AM
utee05's Avatar
Quoted: 30 Post(s)
Thanks for the response. I decided to go with some crucial tactical ram since these are low profile and will allow for an aftermarket cooler.
utee05 is offline
Reply Home Theater Computers
