HD-PVR Rocket Portable Video Recorder - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 11-02-2013, 05:20 PM - Thread Starter
SHS
SHS's Avatar
Quoted: 64 Post(s)
The HD PVR Rocket is small enough to fit in one hand and weighs just 4.6oz or 130grams
This a standalone device that can be carried with you to events, etc to record your game play's and game commentary to, and does not need a PC or Mac and it also support PC connected mode as well.
The features
H264/AVCHD Hardware Encoder
One Touch Rec/Stop Button
HDMI input (Without HDCP)
HDMI No Delay pass-through output
Component input
S/Video input
Composite input
RCA Stereo Audio input
Built-in Microphone Input with +20db boost
Built-in Audio Mixer with adjusting Mic Control
Touch screen control Mic Volume Up/Down, Mic oN/Mute, +20dB, Lock
USB 2.0 Type A Front Port for plug a thumb flash drive in for record your game play
USB 2.0 Type B Rear Port for PC/Power (Power is pull right from the USB Port work with 2.0/3.0 bus to power the device)
HDMI Cable
PS3 Component cable
USB Y Adapter cable for PC and Red 5v Power Only
Max Bitrate 18 Mbits/sec or 2.3 Mbytes/sec
Resolution formats
1080p60p (recorded as 1080p30)
1080p50p (recorded as 1080p25)
1080i60
1080i50
720p60
720p50
480p60
480i60
576p50
576i50
Recoding Container Format: MP4 in standalone mode, TS in PC connected mode
Hauppauge provides a Windows application called Hauppauge Capture, The recordings made in the stand-alone mode are compatible with a Mac for
import into iMovie.
A 16 Gbyte USB thumb drive, when plugged into the HD PVR Rocket, can record 4 hours of video game play at an HD resolution of 1080p
HD PVR Rocket will be available at retailers throughout Europe/North American starting November 15. The suggested retail price is €169/$169
FAQ
USB Flash Drive Max Size that has beem tested so far is 32GB.
Both USB 2.0 and 3.0 Flash drive can be used
External hard drive support Yes, but it needs to be a powered hard drive.
SHS is offline
post #2 of 17 Old 11-21-2013, 02:59 PM
SoundsGood's Avatar
Nice.
My son would love this thing. Anyone know how this compares to the similar "Avermedia Live Gamer Portable" device?
SoundsGood is offline
post #3 of 17 Old 11-21-2013, 03:43 PM - Thread Starter
SHS
SHS's Avatar
Quoted: 64 Post(s)
That I don't know but here any Video I did with it
http://www.youtube.com/watch?v=00rW0JGyyWA
SHS is offline
post #4 of 17 Old 11-22-2013, 06:24 AM
SoundsGood's Avatar
Thanks. Looks good.
I'm still curious about how it might compare to the AVerMedia unit. I'm not sure which one to go with.
post #5 of 17 Old 03-26-2014, 02:33 PM
nikknightt's Avatar
Quoted: 72 Post(s)
Liked: 27
Have you guys figured out how to capture 5.1 ac3 via HDMI?
Is there any difference with the Best Buy version?
model 01530: HD PVR Rocket special Best Buy edition
model 01540: HD PVR Rocket and English manual
Any issues editing 18mbps files with VideoRedo?
nikknightt is offline
post #6 of 17 Old 03-27-2014, 06:56 AM - Thread Starter
SHS
SHS's Avatar
Quoted: 64 Post(s)
There is no diff what so ever in the two model
Sorry but it doesn't record AC3 nor can it capture 5.1
SHS is offline
post #7 of 17 Old 03-28-2014, 06:35 AM
cpalmer2k's Avatar
Quoted: 286 Post(s)
Liked: 37
I haven't used the AverMedia game recording unit, but I did use their larger version of it that had a hard drive in it for capturing Component video. I found that the files recorded on it wouldn't open with any other programs or edit correctly with any software that I have. VideoReDo gets confused by them, as does TMPGEnc Authoring Works. I wouldn't recommend it.
VideoReDo can handle the 18mbps stream files, BUT as we discussed in the 1212 thread it appears that the Hauppauge captures in a slightly unusual format that it struggles with. Sometimes the files will "stop" when you save your edits and won't continue. You can do the "Quickstream Repair" on them and correct the problem (usually), but it's an added annoyance.
cpalmer2k is online now
post #8 of 17 Old 12-07-2015, 10:07 AM
dare2be's Avatar
Surprised there hasn't been much discussion on this unit. Any owners care to share experiences with using it? Particularly, I'm looking to find out how easy it is to set the capture settings in standalone mode. I would be recording from my Dish STB using component cables in most likely 720p.
dare2be is offline
post #9 of 17 Old 12-07-2015, 11:12 AM - Thread Starter
SHS
SHS's Avatar
Quoted: 64 Post(s)
It eazy to setup
1: Update the frimware with USB flash drive or any PC/laptop to the latest ver
2: Plug in your Component Cables
3: You can used a USB flash drive I know how big you can go most people I know just used reg 500GB up to 2TB 7200rpm harddrive with self power docking station for harddrive.
If want change any option you will need plug in to PC or Laptop and install Hauppauger Tool form there you can change the bitrate and any other option ocen it save the setting it auto work in stand mode as well.
SHS is offline
post #10 of 17 Old 12-07-2015, 11:25 AM
dare2be's Avatar
Originally Posted by SHS View Post
It eazy to setup
1: Update the frimware with USB flash drive or ny PC/laptop to the latest ver
Thanks, do you know if the settings changes will stay even after it is powered off and used later in standalone mode? Yes, I plan on using a small USB HDD (500GB or so) for capturing, and then edit/convert the files on my desktop. I'm guessing there is no record/pause function to strip commercials (start/stop would create separate files), so I would need to do the commercial editing on the computer?
dare2be is offline
post #11 of 17 Old 12-07-2015, 11:32 AM - Thread Starter
SHS
SHS's Avatar
Quoted: 64 Post(s)
Yes it store it to the on board flash setting
That right there is no record/pause function to strip commercials
SHS is offline
post #12 of 17 Old 03-02-2017, 01:49 PM
dare2be's Avatar
Finally pulled the trigger and got myself one of these. So far the only thing I can't figure out (if it is even possible) is to record at 1280x720 30fps in standalone mode. All of my test recordings have been at 60 fps, even though my component source is 720p 30fps.
dare2be is offline
post #13 of 17 Old 03-02-2017, 02:01 PM - Thread Starter
SHS
SHS's Avatar
Quoted: 64 Post(s)
720p has allows been 60fps as there is no 720i 30fps nor 720p 30fps
SHS is offline
post #14 of 17 Old 03-02-2017, 10:02 PM
dare2be's Avatar
I hope you mean on the Rocket as there surely is 720p30 from/on other devices. My set top box, my dash cam, etc.
dare2be is offline
post #15 of 17 Old 03-03-2017, 05:16 AM - Thread Starter
SHS
SHS's Avatar
Quoted: 64 Post(s)
No Cable nor any Satellite set top box not even any game consoles dose 720p 30fps the way only to get 30fps was with 480i and 1080i with a TV Cable and Satellite set top box.
You Dash Cam may do that but the more FPS, the more fluidity of motion the video is as 60fps how ever 1080p 60fps is the new standard
SHS is offline
post #16 of 17 Old 03-03-2017, 06:21 AM
dare2be's Avatar
I guess I was thinking of all the 720p content I've watched or downloaded from network websites, Youtube, Amazon, etc. It is all encoded at 24 or 30fps, which is what I was expecting from my own recorded content.
dare2be is offline
post #17 of 17 Old 03-03-2017, 10:19 AM
dare2be's Avatar
Anyway, the Rocket is working out well. Recording 720p at 9mbps, losslessly cut out commercials using Avidemux and re-encoded to 2mbps using Vidcoder 2-pass encoding. Did 5 hour-long episodes yesterday alone. Was concerned whether overheating would be an issue but it worked like a charm. I did give it 15 minutes between recordings to cool down.
dare2be is offline
Reply Home Theater Computers
