play mkv file with lpcm 6 channel sound - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-05-2013, 12:24 AM - Thread Starter
traykov77's Avatar
Quoted: 14 Post(s)
Hello, I download a movie which is mkv file with lpcm 6 channel sound. When I play the movie with powerdvd 13, total media player 5 or potplayer ( I have receiver Sony STR-dn1040 connected with hdmi 1.4 to videocart ATI 7730) the receiver shows PCM. I use LAV audio and video codecs with Potplayer. How can I bitstream this file to receiver?
traykov77 is offline
post #2 of 4 Old 11-05-2013, 12:29 AM
springmaker's Avatar
PCM is what your receiver should say lpcm isnt bitstreamed because its unpacked full audio allready.
springmaker is offline
post #3 of 4 Old 11-05-2013, 02:22 AM - Thread Starter
traykov77's Avatar
Quoted: 14 Post(s)
Is it normal to have active volume control on the PotPlayer, PowerDVD and Total Media Player for this mkv file, when I watch mkv with dts-hd or dolby true sound the volume control in the players is not active (I have to turn up or down volume control of the receiver to change power of sound), but now I have active volume control on the players for this mkv file with LPCM sound?
post #4 of 4 Old 11-05-2013, 02:34 AM
Yes because when you bitstream dts master audio or dolby true you are sending something like a zipped file to the receiver which unzips it so when you send lpcm your sending sound that doesnt need unzipping so you can adjust the volume.Powerdvd tmt can unzip the file for you and send it as lpcm the sound should be the same quality handy if you have older receiver that doesnt support dts master etc.
Reply Home Theater Computers
