Projector Flicker / Dim on HTPC only - AVS Forum | Home Theater Discussions And Reviews
Old 11-06-2013, 04:01 PM - Thread Starter
mginster's Avatar
Setup:
- Epson 3010
- Denon 2312CI
- Self built HTPC with newer ATI HD card capable of DD-HD/DTS-HD, etc, via HDMI.
- HDMI Cables. PC to Receiver - Standard 1.4b 6ft. Receiver to projector - Premium monoprice 25ft.
Issue:
Projector flickers / dim's slightly on HTPC inputs sometimes (not consistent). The flicker can be explained like a dimmer is on the projector bulb being turned up and down slightly.
Weird side note:
Turning off the ceiling fan in the room causes the projector to go black for about 4 seconds, then comes back as normal. It only does this with the HTPC.
Already attempted:
- Changed source to other devices (Uverse receiver / Xbox 360). Issue is only seen on HTPC.
- Changed receiver inputs to other known working ones (Uverse / Xbox). Still exists.
- Changed HDMI cables to other known working (Uverse one). Still exists.
This has allowed me to narrow it down to something with the signal the PC is sending / power issue with the PC.
Where should I go from here? Most likely culprits...GPU, PSU, put a power conditioner on the PC, etc.
mginster is offline
Old 11-07-2013, 01:01 PM
Roussi's Avatar
Quoted: 45 Post(s)
Liked: 36
Looks like a dynamic contrast issue; try turning it off both on the HTPC and the projector.
Roussi is offline
Old 11-07-2013, 01:33 PM
Andrew Hornfeck's Avatar
Quoted: 30 Post(s)
Go into the CCC and turn off the post processing items like contrast, anti-aliasing...  since it's a PC issue looking at the video cards settings seems the likely issue.
Andrew Hornfeck is offline
Old 11-08-2013, 01:42 PM - Thread Starter
mginster's Avatar
I will start messing with the gpu settings tonight.
Anyone have any idea why this occurs though?
Weird side note:
mginster is offline
Old 11-08-2013, 02:16 PM
davidtt485's Avatar
Liked: 34
my guess would be ground or voltage spikes with the htpc on the same circuit as the fan
davidtt485 is offline
Old 11-08-2013, 02:28 PM
Axel's Avatar
Quoted: 73 Post(s)
Liked: 24
mginster;
Do you also see flicker with the ceiling fan off?
_____
Axel
Axel is offline
