Low Profile Video Card - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 41 Old 03-22-2014, 12:11 PM
Shark007's Avatar
Quoted: 67 Post(s)
Liked: 69
Originally Posted by ES_Revenge View Post
Also confusing things is the fact that "Curacao" (in the 270/270X) is essentially the same thing as Pitcairn--why'd they go and rename that?!?
Mind boggling.
I own a PowerColor R9 270X (Devil) and it has a Pitcairn chip.
Use Shark007 Codecs and retain your sanity.
Shark007 is offline
post #32 of 41 Old 03-22-2014, 12:18 PM
ES_Revenge's Avatar
Quoted: 410 Post(s)
Liked: 133
Right, which is also known as (or now known as) Curacao.
http://www.tomshardware.com/reviews/radeon-r9-280x-r9-270x-r7-260x,3635-3.html
"AMD wants to introduce its R9 270X, based on an ASIC it’s calling Curacao (but is every bit similar to Pitcairn on paper)..."
ES_Revenge is offline
post #33 of 41 Old 03-22-2014, 12:19 PM
Shark007's Avatar
Quoted: 67 Post(s)
Liked: 69
On my system, GPU-Z reports Pitcairn
Shark007 is offline
post #34 of 41 Old 03-22-2014, 12:39 PM
ES_Revenge's Avatar
Quoted: 410 Post(s)
Liked: 133
LOL I don't doubt you...at all. What I'm saying is, despite the name change, Curacao is Pitcairn. There may be some clock differences on the newer cards or something but that's no different than clock differences on the same model number card that exist from manufacturer to manufacturer or from model to model even (like Black Edition, OC edition, etc.).
Are you using the latest version of GPU-Z? The latest version should indicate an R9 270/270X as Curacao but they may have decided not to bother.
In short Curacao is] Pitcairn.
The latest version of GPU-Z even mentions an item that shows them that way:
"•Added CHiL8214 voltage monitoring for Pitcairn/Curacao cards"
post #35 of 41 Old 03-22-2014, 12:46 PM
Shark007's Avatar
Quoted: 67 Post(s)
Liked: 69
Shark007 is offline
post #36 of 41 Old 03-22-2014, 09:16 PM
Murilo's Avatar
Quoted: 120 Post(s)
Liked: 29
So does anyone know where one can find a good low profile amd card right now, i cant find any outside the R7 250 (wouldnt want to go lower then that), but newegg reviews of this one http://www.newegg.ca/Product/Product.aspx?Item=N82E16814150682 claim it sounds like a jet engine taking off.
Cant find this one anywhere.
http://www.guru3d.com/news_story/club_3d_radeon_r7_250_low_profile_and_r7_250x_graphics_cards.html
Murilo is offline
post #37 of 41 Old 03-22-2014, 09:22 PM
Murilo's Avatar
Quoted: 120 Post(s)
Liked: 29
Or is the easiest solution going to be i have to gut my case, buy a bigger one, and get a 7770?
Im not fairly well versed with htpc's only been using them for a year.
Murilo is offline
post #38 of 41 Old 07-13-2014, 03:45 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2681
is the 750ti available in a reduced size card ?
Mfusick is offline
post #39 of 41 Old 07-14-2014, 07:32 PM
LexInVA's Avatar
Quoted: 505 Post(s)
Liked: 205
Nope. Only 10/20/30/40 cards get low-profile builds. The most powerful low-profile Nvidia card currently available is a 2GB GDDR-equipped 740 GT.
LexInVA is online now
post #40 of 41 Old 10-21-2014, 01:48 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2681
I swear I've seen them...
Mfusick is offline
post #41 of 41 Old 10-21-2014, 01:56 PM
Toys7505's Avatar
Quoted: 69 Post(s)
Liked: 26
Gigabyte makes one....GTX 750ti...low profile
http://www.newegg.com/Product/Produc...-680-_-Product
Toys
Denon AVR-3311CI, Denon DVP-602CI, B&K Reference 200.7 S2, Belkin PF60
Sony BDP-S5000ES, Silverstone HTPC (6 Tuner DVR & 10 TB Media)
PSB Stratus Minis, PSB Stratus C6, PSB Alpha S surround, James Subwoofer EMB-1200
Sharp LC-70LE755U, Harmony 880 Remote
Toys7505 is offline
Reply Home Theater Computers
