Possible to merely "copy" an MKV's encoding settings? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-13-2013, 07:10 PM - Thread Starter
coldblackice's Avatar
Is it possible to merely "copy" an MKV's encoding settings found in its file information and use those same settings to rip from the original source again, resulting in an MKV of the same quality?
For example --
Person A and Person B both have the same exact bluray that they want to rip.
Person A rips the bluray into an MKV. Person B wants to mimic the quality of Person A's ripped MKV, so Person B looks in the A's MKV's info, finds the settings:
-Writing application (mkvmerge v5.8.0)
-Writing library (libebml v1.2.3 + libmatroska v1.3.0)
-Writing library (x264 core 125 r2200 999b753)
-Encoding settings (cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x133 ...)
-Bitrate (5000Kbps)
And then seeks to use the same programs and settings on his rip of the bluray.
Would this work? In other words, is the encoding information that's stored in A's MKV enough for someone to mimic themselves and get the same quality rip? Or is there some "magic" or "flourish" that wouldn't show up in an MKV's info, which could drastically vary the quality of the rip?
coldblackice is offline
post #2 of 7 Old 11-14-2013, 05:36 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 416
Typically, a rip is a direct lossless copy of the movie on the disc. There should be no quality differences.
The only times you see quality differences is when you re-compress the video to save space. Rippers like MakeMKV only does lossless rip. I know some programs like Clone BD will re-compress the video to fit certain storage space.
In the case of re-compressed video, MKV metadata alone if not enough to tell what the encoding parameters are. Far from it.
Foxbat121 is offline
post #3 of 7 Old 11-14-2013, 10:54 AM
bulls's Avatar
Quoted: 152 Post(s)
Liked: 88
cold: always wondered that but i've never tried
fox:
"rip" does not mean lossless.
from their own website: " MakeMKV is a format converter, otherwise called "transcoder"." = NOT lossless, and as far as i remember from the DVD days, transcoders = suck . (just like other softwares it might have options to keep audio/video untouched but whatever)
display - vizio p65
AVR x4300h +lepai 2ch amp = 7.2.4
L/C/R - Chane 2.4, SURROUND - dayton 3in cubes *temporary
BASS - 2x Seaton F18, MBM - 2x Behringer 1200
2100 ft^3
bulls is online now
post #4 of 7 Old 11-14-2013, 02:47 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 416
You are totally wrong on this. Enough said. Go research.
StinDaWg likes this.
post #5 of 7 Old 11-14-2013, 02:59 PM
Sammy2's Avatar
Quoted: 550 Post(s)
Liked: 262
Yes. Completely wrong. Do you have a link?
Sammy2 is online now
post #6 of 7 Old 11-14-2013, 04:03 PM
Gorath's Avatar
All MakeMKV does is take the video file(s) and the audio file(s) from the BluRay or DVD and put them in a .mkv container. It doesn't do any compression.
I think what you are thinking of having is something like "AccurateRip" that is used to verify the accuracy of an audio CD rip.
Gorath is offline
post #7 of 7 Old 11-14-2013, 04:39 PM
bulls's Avatar
Quoted: 152 Post(s)
Liked: 88
twilight zone
display - vizio p65
2100 ft^3
bulls is online now
Reply Home Theater Computers
