Best 3D ISO player?? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1 of 44 Old 11-16-2013, 12:25 PM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
So now I have a 3D TV and am dabbling in 3D which MPC-HC doesn't do.
I'd like a similar solution in MBC that launches the correct player for 3D
I have been checking out TMT5 and the playback is pretty good for 3D but the interface on that is crap. I cannot believe that it doesn't have a 10 foot interface and work well with a remote. It also doesn't mount an iso directly nor does it exit smoothly (or at all) back to MB when done with playback.
Any suggestions?
Sammy2 is offline
post #2 of 44 Old 11-16-2013, 02:20 PM
kokap's Avatar
TMT5 has a MCE version (uMCEPlayer5.exe). This version is convenient enough for remote control.
CyberLink PowerDVD has Cinema mode which is also convenient for remote control.
About "best 3D ISO player "...
I have TMT, PowerDVD, WinDVD, Nero and Stereoscopic Player. The most popular players are TMT and PowerDVD.
TotalMedia Theatre:
1. TMT has issues with auto frame rate (auto refresh rate). TMT does not distinguish between 23.976 fps and 24.000 fps.
2. MCE version of TMT6 is very buggy.
PowerDVD:
1. Media Library is useless.
2. "Auto resume" option often does not work.
3. BDMV folder must have all standard subfolders.
I prefer PowerDVD.
BTW I think the worst player is Nero Blu-ray Player: it has too many drawbacks.
kokap is offline
post #3 of 44 Old 11-16-2013, 03:45 PM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
As I am only going to put 3D in iso and use that as a file type to use one of these 3D players I won't be needing it to do much else.
I will continue to use MPC-HC with madVR and LAV for all other content.
So launching TMT from WMC is possible but not from with in MB3? There goes unification again! Blah!
Sammy2 is offline
post #4 of 44 Old 11-16-2013, 04:03 PM
kokap's Avatar
I don't know about MB3, but TMT (and TMT MCE version) can be launched from XBMC, MediaPortal, MyMovies and so on.
kokap is offline
post #5 of 44 Old 11-16-2013, 04:22 PM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Two things.
First off, TMT shows on the WMC menu strip and will play an iso if already mounted. This doesn't play full screen.
Secondly, launching uMCEPlayer5.exe from MB3 Classic after forcing iso file type to use this player in MB3 Configurator results in no playback even if the iso has been previously mounted.
Currently the only luck I've head is using TMT5 which is an absolutely horrendous interface. What were they thinking?
Sammy2 is offline
post #6 of 44 Old 11-16-2013, 04:40 PM
kokap's Avatar
Hah, you can use a script that mounts ISO image, launches TMT and unmounts ISO image.
For example I use the following script for XBMC:
Code:
@echo off
"c:\Program Files\DAEMON Tools Lite\DTLite.exe" -mount scsi, 0, %1
"c:\Program Files\ArcSoft\TotalMedia Theatre 5\uMCEPlayer5.exe" G:\
"c:\Program Files\DAEMON Tools Lite\DTLite.exe" -unmount scsi, 0
exit
kokap is offline
post #7 of 44 Old 11-16-2013, 05:44 PM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Code:
@echo off
exit
Okay so how do you execute this with a MCE or Harmony remote?
Also, I use Elaborate Bytes Virtual Clone Drive so I would just substitute in the scrip or probably get daemon tools to do it instead because the switches might be different. Once it unmounts does control return to XBMC for you? I want to select an iso that is a 3D BR in Media Browser but have it launch the player then release the player and return to MB afterwards.
Sammy2 is offline
post #8 of 44 Old 11-16-2013, 05:53 PM
bryansj's Avatar
Quoted: 1123 Post(s)
Liked: 555
Originally Posted by Sammy2 View Post
Two things.
You don't associate ISO with TMT. You set Blu-ray discs to autoplay with TMT. When MB mounts the ISO it should correctly start playing. Associate Blu-rays with MB.
However, all that said is why I ended up switching to MyMovies. MB2 kept having trouble consistently launching Blu-rays or 90% of the time had trouble returning to MB once finished. I was redoing my entire HTPC's software and server and decided to try MyMovies.
bryansj is online now
post #9 of 44 Old 11-16-2013, 06:10 PM
kokap's Avatar
Sammy2
I associated ISO file extension with the script in special XBMC configuration file. When I press "Enter" button on my MCE remote - the script mounts ISO and launches selected movie. smile.gif
Yes, of course.
kokap is offline
post #10 of 44 Old 11-17-2013, 08:22 AM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Two things.
Is this in the MB Configurator? I am not sure how to do this as MB doesn't really have its own player but rather is a media organizer.
I get the rest of it. I set MB to mount iso in the configurator and also set TMT to autoplay Blu-ray discs.
Sammy2 is offline
post #11 of 44 Old 11-17-2013, 08:27 AM
bryansj's Avatar
Liked: 555
I haven't used MB in awhile, but it was in the external player configurator. Just saying that associated .iso with TMT isn't the solution, you associate Windows Auto-play with playing Blu-rays with TMT. When MB mounts the .iso it will start playing in TMT. At least that is how it used to work with MB2. I haven't touched MB3 since moving to MyMovies.
post #12 of 44 Old 11-17-2013, 08:33 AM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Code:
@echo off
exit
Sammy2
Yes, of course.
While I understand the concept of what you are doing there isn't enough specifics here to actually implement it.
Sammy2 is offline
post #13 of 44 Old 11-17-2013, 08:50 AM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Okay that is what I understood but I need to try it out now. I am going to set everything but Blu-ray to use MPC-HC as the player and then for Blu-ray iso it should just load TMT.. Yeah the exiting back to MB3 is going to be a little tricky I think.
Sammy2 is offline
post #14 of 44 Old 11-17-2013, 09:08 AM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Okay. That worked but it loaded the WMC TMT player, which is fine with the exception that it isn't full screen, it has a blue WMC boarder around the entire thing. Upon hitting stop, it returns to the TMT menu within WMC and one press of the back button on the remote takes it back to MB. I can handle that.
Sammy2 is offline
post #15 of 44 Old 11-17-2013, 09:24 AM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Okay, TMT probably blocked capturing the screen but when I play back this way I am getting the following blue borders around the playback window. I do have TMT set for full screen playback but there wasn't a setting for this in the WMC TMT player.
Sammy2 is offline
post #16 of 44 Old 11-17-2013, 09:37 AM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I'm thinking that this or this might help because I have the blue borders in MB3 as in MB2.6 but never worried about it because MPC-HC just went to full full screen. This fix is for MB but I wonder if it helps with TMT too or if anyone knows. I should search the MBT thread I think.
Sammy2 is offline
post #17 of 44 Old 11-17-2013, 12:19 PM
bryansj's Avatar
Liked: 555
I've never seen the screen display as you are showing. You can try hitting Info and then navigate to the right to Settings. You have to set the WMC TMT settings separate to the desktop TMT settings.
post #18 of 44 Old 11-17-2013, 12:42 PM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I think I went through the TMT5 WMC settings and didn't see anything for scan or zoom but I will try yet once again. It could be a scanning issue in CCC too.
Sammy2 is offline
post #19 of 44 Old 11-17-2013, 02:01 PM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
This is a WMC issue. If I set it to be a Monitor or Flat Panel instead of a Television the scanning is correct for TMT but for Live/Recorded TV the perimeter is now lost. I suppose I will have to decide which is important or find another way to playback 3D content.
Sammy2 is offline
post #20 of 44 Old 11-17-2013, 02:15 PM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
So, I'm thinking is there a way to load the TMT stand alone player from within MB3 for iso rips? This would avoid the issue with scanning altogether because that player works fine..
Sammy2 is offline
post #21 of 44 Old 11-17-2013, 06:09 PM
pittsoccer33's Avatar
Quoted: 648 Post(s)
Liked: 426
http://www.avsforum.com/t/1455591/media-browser-3-is-coming/600#post_23887288
Originally Posted by pittsoccer33 View Post
However the one that sets to zero overscan brings the on screen elements closer in to the middle - the minimize, maximize, close, and the transport controls in the lower right hand. instead of being on the outer edge of the screen they are an inch or more in.
This is something you have to fix in the registry.
I don't use those controls very often so although it may look strange I heardly see it and when I do I don't worry about it. Stuff like this doesn't distract from the appliance status of my HTPC.
This is one of the registry problems in WMC that you said you don't care about
go to HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Media Center\Settings\MCE.PerUserSettings
and change the Margin Saved value to 1.
while youre there you might as well fix all the other margins by changing them to 0
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
post #22 of 44 Old 11-17-2013, 06:31 PM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Yeah. I know. I haven't been doing 3D and it hasn't been an issue for me before but I guess it is now.
Sammy2 is offline
post #23 of 44 Old 11-17-2013, 07:02 PM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
All fixed up now. Thanks for the tip. I guess TMT 5 is it for 3D.
Next question. I have version 5.0.1.87 but it is prompting for an update. Will this bring cinavia to my doorstep?
Sammy2 is offline
post #24 of 44 Old 11-17-2013, 08:15 PM
utee05's Avatar
Quoted: 30 Post(s)
Thanks for all of this info. I am currently setting up my htpc to play 3D iso as well since I recently got a w1070.
I had the blue borders issue when playing back with TMT within MCE so i will have to look at the registry edits. What other registry edits are needed? Any more info on this would be helpful.
utee05 is offline
post #25 of 44 Old 11-17-2013, 08:21 PM
bryansj's Avatar
Liked: 555
Yes, it will bring Cinavia. You would need AnyDVD HD to block the Cinavia detection in TMT if you upgrade your v5 or move to v6.
post #26 of 44 Old 11-17-2013, 08:56 PM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
If you are wanting full range RGB output usung nVidia there's one for that too but madshi's script will do it for you.
Sammy2 is offline
post #27 of 44 Old 11-17-2013, 08:59 PM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
No reason to upgrade then. Funny how it says some files won't play unless you apply the update when in fact some files won't play after 20 minutes if you do unless AnyDVD HD is running in the background.
Sammy2 is offline
post #28 of 44 Old 11-18-2013, 05:35 AM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
EDIT: Moved TMT 5 question to this post.
Sammy2 is offline
post #29 of 44 Old 11-19-2013, 12:48 PM
utee05's Avatar
Quoted: 30 Post(s)
Which script is that? I haven't tinkered with my htpc in a while as most things appear fine for me other than the blue border fix that you pointed out. Thanks for the info on that btw.
utee05 is offline
post #30 of 44 Old 11-19-2013, 01:31 PM
Quoted: 648 Post(s)
Liked: 426
http://www.hack7mc.com/2009/06/fixing-media-centers-poor-black-levels.html
Theres a good post on the black level issues. If you are using Arcsoft as your player I don't think that pertains to you.
Reply Home Theater Computers
