Can I use the IR receivers that comes with cheap generic PC Remote Controls with my URC WR7? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-20-2013, 04:02 PM - Thread Starter
faire's Avatar
I use my URC WR7 universal remote control to manage receiver, lcd, dvr, xbox, etc.. But I also want to use it to control my HTPC. As far as I understand, my HTPC needs a IR receiver, am I right? Those IR receivers that comes with cheap remote controls for PC would work with my control ? Or what exactly do I need?
faire is offline
post #2 of 7 Old 11-20-2013, 04:43 PM
bryansj's Avatar
Quoted: 1123 Post(s)
Liked: 555
You need an IR receiver. The HP Media Center IR Receiver is most recommended. If your remote doesn't have the MCE codes included then you can use Eventghost to map the commands to any IR input you wish.
bryansj is offline
post #3 of 7 Old 11-20-2013, 05:12 PM - Thread Starter
faire's Avatar
If I can't get the HP IR, any other would work?
faire is offline
post #4 of 7 Old 11-20-2013, 05:20 PM - Thread Starter
faire's Avatar
Also, i have a usb receiver that listen to my XBOX joystick, so i can play pc games using the xbox control. Can I hack that receiver so that it can listen to my universal remote control?
faire is offline
post #5 of 7 Old 11-20-2013, 06:18 PM
bryansj's Avatar
Liked: 555
The HP receiver is $15 shipped. The Xbox USB receiver uses a proprietary RF, not IR.
You can get a different IR receiver, but it may or may not support the MCE codeset. Some IR receiver use a custom IR codeset and not the MCE standard "eHome" device.
bryansj is offline
post #6 of 7 Old 11-20-2013, 07:18 PM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
Depends on how cheap. The $6-$7 ones use a crazy, practically unlearnable protocol and are missing some important WMC commands, so avoid those. The $12-$25 ones work fine. They're either MCE or Ortek protocol, both of which work very well. The HP already mentioned is great, but if your URC doesn't have codes already, then you have no remote to learn them from, so that's a risk. Those work best for remotes known to have a full set of MCE codes built in. Post a link and we can probably tell you if it's any good.
mdavej is online now
post #7 of 7 Old 11-20-2013, 07:19 PM - Thread Starter
faire's Avatar
Sorry, where? Im in Chile, hopefully they ship overseas
faire is offline
Reply Home Theater Computers
Urc Wr7 Universal Remote Control For Up To 7 A V Components With 4 Favorite Channel Buttons
