Moved my HTPC from 50" Sammy to 60" Panny and now screen doesnt fit right? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 11-20-2013, 04:33 PM - Thread Starter
bdobs's Avatar
I basically built my HTPC a couple years ago using Assasian's guide . Intel i3 Sandy using the integrated graphics card. Hooked it up to my 50" Sammy plasma and it was perfect. I recently moved and bought a second TV(60" Panasonic ST60). I hooked my HTPC up to it last night and I can't seem to get the screen to fit.
The computer is projecting too large on the screen and the top, bottom and sides are cut off. I tried going through the Intel graohics setting and still no luck. I tried custom aspect which helped a little, but it wont let me scale smaller than 95%. I tried to go to 90% and when I clicked apply it just goes back to 95%.
Any ideas?
bdobs is offline
post #2 of 8 Old 11-20-2013, 04:57 PM
Dropkick Murphy's Avatar
Quoted: 71 Post(s)
Liked: 89
Make sure the picture size on your TV is set to FULL - Size 2 (Size 1 is overscanned and that may be your problem).
bdobs and pittsoccer33 like this.
Dropkick Murphy is offline
post #3 of 8 Old 11-20-2013, 06:06 PM
gewbert's Avatar
Liked: 27
I have mine set to Size 1 and turn overscan off. Works for me.
Sammy2 likes this.
gewbert is offline
post #4 of 8 Old 11-20-2013, 06:53 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I just went through this. Maybe take a look here if you have an AMD GPU.
You may want to take a look at this too.
Sammy2 is offline
post #5 of 8 Old 11-21-2013, 11:36 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
@bdobs, did you ever get this resolved?
Sammy2 is offline
post #6 of 8 Old 11-21-2013, 11:38 AM - Thread Starter
bdobs's Avatar
Not yet, will be looking into your solutions this evening. Just moved in and the wife had me hanging pictures ALL NIGHT eek.gif
I will be reporting back!
bdobs is offline
post #7 of 8 Old 11-22-2013, 08:31 AM - Thread Starter
bdobs's Avatar
Size 1 and over scan off did the trick!! Thanks all
bdobs is offline
post #8 of 8 Old 11-22-2013, 09:43 AM
gewbert's Avatar
Liked: 27
Glad to hear!
gewbert is offline
Reply Home Theater Computers
