AMD 3840x2160 (4K) output problems - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-22-2013, 02:27 AM - Thread Starter
sanderdvd's Avatar
Quoted: 162 Post(s)
Liked: 30
I have a 4K display device (Sony VPL-VW1000ES 4K projector) with a Club3D Royal King HD7950 card (running latest driver). I configured my ATI control panel to output 3840x2160 (4K)@23Hz.
The problem is that I get 'faults' when I play blu-ray (or any content). Sometimes I have no glitches for 30 minutes or so but then it suddenly pops up (eg. during scene changes or sometimes during scene pannings).
It is pretty hard to describe the actual problem but think about a video cable that is 'loose'. The picture just 'distorts' for some seconds. You see 'bright green/blue distortion lines'. The problem goes away when outputting 1080p from the card.
The problem is not software playback related because it is there with XBMC, MPC-HC, Windows Media Player etc etc. It is also not renderer related because it is there with the madVR renderer but also with eg. the EVR renderer.
So there is something wrong but I have no clue what. Is there someone who can help me on my way?
sanderdvd is offline
post #2 of 3 Old 11-22-2013, 06:08 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Could be your HDMI cables?
I know many issues can pop up due to cables at high resolution that are not an issue at lower resolutions. I believe you need HDMI 2.0 spec ?
Or do you run something like display port ? I don't even know ?
It does sound like a cable issue or a driver issue if it's present across multiple players.
I'd avoid the AMD "beta" drivers and go for the full releases. Your not chasing frames in battlefield4, you are chasing stability.
You could try swapping out the GPU card too but that might be costly ...
Mfusick is offline
post #3 of 3 Old 12-05-2013, 01:11 AM
Manni01's Avatar
Quoted: 2704 Post(s)
Liked: 2190
@sanderdvd: @23hz you don't need hdmi 2.0, but if you have long cables, you might reach their limit. Try with a shorter cable (3-6 feet) and also try changing the pixel format in catalyst. If video is your priority, try to switch to YCbCr422 and see if that helps, as you don't need 444 unless you play video games or do some photoshoping.
Manni01 is offline
Reply Home Theater Computers
Sony Vpl Vw1000es Projector
