Windows 8.1, no Movies showing up in WMC Movie library - AVS Forum | Home Theater Discussions And Reviews
Old 11-24-2013, 04:09 PM - Thread Starter
Nethawk's Avatar
Liked: 118
Hi,
Much to my surprise I'm really liking Windows 8.1. I decided to install 8.1 pro after a [new] Samsung 840 Pro SSD meltdown and took to it immediately. I installed WMC and have recorded TV working fine with internal tuner. However I cannot get any of my .mkv files to show up "There are no items in this library yet...", despite adding and removing the same folder multiple times. I've also tried another HDD and folder by copying files over, still no luck.
I followed assasin blog (way out of date, unfortunately) and installed Lav codecs and splitter because it was more simple, with my Win7 machine I had previously used Shark codecs. But this shouldn't have anything to do with files not going into the library, should it?
Thanks in advance.
Nethawk is offline
Old 11-24-2013, 04:28 PM
Shark007's Avatar
Quoted: 80 Post(s)
Liked: 73
Yes, there are many things my releases do that go beyond simply allowing file playback. I suggest you try the 'STANDARD' codecs releases which are little more (codec wise) than a wrapper for the LAV codecs.
Use Shark007 Codecs and retain your sanity.
Shark007 is offline
Old 11-24-2013, 04:46 PM - Thread Starter
Nethawk's Avatar
Liked: 118
Thanks, I'll try your codec pack next. From distant memory I recall that WMC would still show titles in the library but with an error message indicating it could not playback mkv files. My gut is telling me that this is a WMC issue but it's not making much sense.
I'll report back.
Nethawk is offline
Old 11-24-2013, 04:48 PM
Shark007's Avatar
Quoted: 80 Post(s)
Liked: 73
after installation, select the [x] SUGGESTED settings checkbox and you should be all set.
Shark007 is offline
Old 11-24-2013, 05:09 PM - Thread Starter
Nethawk's Avatar
Liked: 118
Thanks Shark, why I ever decided to go with any other solution is beyond me, as usual your solution is the best. All is well.
Nethawk is offline
Old 11-24-2013, 05:30 PM
Shark007's Avatar
Quoted: 80 Post(s)
Liked: 73
you are welcomed.
Shark007 is offline
