WHS, disk with OS is failing How to replace - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 11-28-2013, 06:00 PM - Thread Starter
rlhowell's Avatar
I have the original WHS with failing hdd with os on it. I am out of space and must add drives and remove the failing one. I seem to remember their is some catch. Just how difficult is this? I know how to add the hdd but replacing the os disk is the issue.
Bob Howell
PS: I built this myself with a MSI AMD 939 board about 2009 or so.
rlhowell is offline
post #2 of 19 Old 11-28-2013, 07:21 PM
fibertech's Avatar
Have you thought of upgrading to WHS11? I am very happy that I did and it wasn't very hard.
fibertech is offline
post #3 of 19 Old 11-28-2013, 07:53 PM - Thread Starter
rlhowell's Avatar
Sure but it too is soon going to be obsolete. I was planning to wait .
rlhowell is offline
post #4 of 19 Old 12-01-2013, 07:50 PM - Thread Starter
rlhowell's Avatar
I have a 2T hdd arriving Monday. Anyone help me wit this?
Bob
rlhowell is offline
post #5 of 19 Old 12-01-2013, 08:17 PM
jbcain's Avatar
Liked: 64
Pull it and clone it
jbcain is offline
post #6 of 19 Old 12-02-2013, 08:57 AM - Thread Starter
rlhowell's Avatar
Can you direct me to steps?
rlhowell is offline
post #7 of 19 Old 12-02-2013, 09:23 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I would upgrade OS or clean install. What exactly do you need from the original OS ??
Mfusick is offline
post #8 of 19 Old 12-02-2013, 06:33 PM - Thread Starter
rlhowell's Avatar
WHS is no longer supported, so I CAN'T REINSTALL THE O S , by my understanding. I would have to buy WHS 2011 . I might be able to clone if I KNEW how.
rlhowell is offline
post #9 of 19 Old 12-02-2013, 06:54 PM
ams123's Avatar
Quoted: 24 Post(s)
Why do you think you can't install the OS. No longer supported just means no more security updates. You can still install it.
ams123 is offline
post #10 of 19 Old 12-02-2013, 07:30 PM - Thread Starter
rlhowell's Avatar
It sounds like the hard way, but maybe not. How do I preserve my data or will I be starting from scratch. I've a collection of movies and music.
rlhowell is offline
post #11 of 19 Old 12-02-2013, 08:27 PM
Andy_Steb's Avatar
Quoted: 31 Post(s)
Liked: 158
WHS v1 uses DiskID's to to track drives for drive extender. I wouldn't recommend cloning.
Andy_Steb is offline
post #12 of 19 Old 12-03-2013, 06:07 AM - Thread Starter
rlhowell's Avatar
Other suggestions?
rlhowell is offline
post #13 of 19 Old 12-03-2013, 06:09 AM - Thread Starter
rlhowell's Avatar
Are all the updates still posted?
rlhowell is offline
post #14 of 19 Old 12-03-2013, 07:37 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Why would you lose your data if you upgrade your OS ? Your data is on your OS drive ? Anything on your hard drives now (data drives) would still be there with a new OS on a new drive. I would install a new OS install to a new HDD, and then install all the old drives as data drives (even the old OS drive) and copy over what you need from there.
Mfusick is offline
post #15 of 19 Old 12-03-2013, 09:43 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 397
He probably has OS drive partitioned to store data as well. You can remove the partition from the drive pool before you rip the hard drive out. This way, the WHS OS will migrate the data out to another drive (assume you have enough space there). Otherwise, you will have to manually copy the data out. You will probably loss the backups once you re-installed the WHS v1 (I did that once) but network shared folders should be ok.
As for WHS2011 upgrade, make sure your current server can support x64. My old server can't. So I ended up build a new PC for WHS2011.
Foxbat121 is online now
post #16 of 19 Old 12-03-2013, 12:18 PM - Thread Starter
rlhowell's Avatar
As I read these responses I see I can disconnect the data drives; put in a new os drive and try reinstalling whsv1 or whs2011, which ever. All mods and fixes for both are posted.
Then I hookup the data drives and, wala, I now have my old date and a new os install.
Sounds simple, but is it?
Will it work?
I am happy with whsv1, but have not figured out how to backup data.
I am up in the air about upgrading to whs2011; but have found no reason to push me to it.
Have 4 yr old Gigabyte GA MA770 DS3 and 50 2x/64 processor, I could use to upgrade the old 939 with 2x64 processor model.
The problem here is, how to move data over. I did not know I could just re hookup the old drives and they would sort themselves out. Is that true?
I can not find much about this on the sites I know of. I am looking for a site with steps to follow, so I can pick out a solution I can handle.
How long is whs2011 going to be viable. doesn't support end next yr?
rlhowell is offline
post #17 of 19 Old 12-03-2013, 03:32 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Yup. That is what I would do. Your data drives should be fine and data should remain on them.
Mfusick is offline
post #18 of 19 Old 12-03-2013, 06:40 PM
Andy_Steb's Avatar
Quoted: 31 Post(s)
Liked: 158
If your new drive is the same size as the old drive then use clonezilla to clone. Clonezilla is reportedly able to clone the DiskIds.
If your drive is a different size then you will run into other problems with volumes and offsets. It still can be done, but it is not something for a beginner.
If you try a restore from DVD with your data drives attached. Be very careful and read everything twice before hitting enter. One option will restore an operating system and restore all the shares from the attached disks. The other option will install a new operating system on your new drive then format all attached disks. Causing you to loose all data
Another option is to do a clean install with your data drives removed. Once you have WHS up and running put a data drive in and start shuffling data around until it is empty. Once it is empty you add it to the pool and continue on to the next disc. If you go with a clean install, I would suggest WHS2011. Get away from drive extender.
post #19 of 19 Old 12-05-2013, 08:52 AM - Thread Starter
rlhowell's Avatar
Well my WHS healed its self yesterday, so no more need to reload os. I don't see a big need to upgrade to whs2011.
I do need to add more hdd's and am out of space. I have 3 -5.25 bays open in my Antec 180 case and have seen box mounts to convert to hdd slots, but now I can't find them on New Egg etc.
Can someone point me to one?
Thanks for all the suggestions. I now have a plan ready for the next crash.
Bob Howell
rlhowell is offline
Reply Home Theater Computers
