Can't configure TV or Monitor in WMC - AVS Forum | Home Theater Discussions And Reviews
Old 12-09-2013, 06:26 PM - Thread Starter
anmg's Avatar
Quoted: 65 Post(s)
I am trying to set up an HTPC. In WMC I go to settings, general, WMC setup and there is no option to configure a TV or Monitor. I seems to be missing. I see TV signal setup and audio setup only. Any help would be appreciated.
anmg is offline
Old 12-09-2013, 07:34 PM
djsinco's Avatar
Where are you seeing those options? If it is on your TV, then proceed.
WMC only asks about whether it is a flat panel, etc, but the optimization will take care of this anyway.
djsinco is offline
Old 12-09-2013, 08:09 PM - Thread Starter
anmg's Avatar
Quoted: 65 Post(s)
It's on my computer monitor. I will eventually be using a projector, but for now I can't even get to the point where it asks if I have a flat panel. I go to settings, then general, then to windows media center setup. At this point I should see configure tv or monitor but that choice is not there it's missing. I only see set up internet connection, set up tv signal, set up your speakers, run setup again and install PlayReady. Configure TV or Monitor is not there.
anmg is offline
Old 12-09-2013, 08:34 PM
djsinco's Avatar
Have you tried uninstalling WMC, and then reinstalling it?
Here is how:
Control Panel > Programs and Features > Turn Windows features on or off > Media Features > Windows Media Center
djsinco is offline
Old 12-09-2013, 08:50 PM - Thread Starter
anmg's Avatar
Quoted: 65 Post(s)
Ok, I turned it off and on. Still same result, configure tv or monitor is still not there. Thanks for the suggestion. Any other idea?
anmg is offline
Old 12-10-2013, 08:25 AM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
What's your display? One or more than one?
What type of connection from the PC to the display?
What's your GPU?
What's your OS?
Is this a clean install?
XBR-65Z9D | AVR-X2200W | UBD-K8500 | JRMC HTPC w/9 cable tuners | Fluance SV 7.1 + eD A3-300
hammerdwn is online now
Old 12-10-2013, 08:59 AM - Thread Starter
anmg's Avatar
Quoted: 65 Post(s)
What's your GPU?
What's your OS?
My display is a flat screen Acer computer moniter 16:9 - After I'm done with setup I will be using a Sony projector in my home theater.
Only one monitor
Connection is HDMI
GPU is i7-4770K Haswell
OS is Windows 7 pro
It is a clean install
Thanks for your help. What's your diagnosis?
anmg is offline
Old 12-10-2013, 09:22 AM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
Ok, I turned it off and on. Still same result...
Did you reboot after disable/uninstall? Are you getting the guide, able to tune to Tv channels, have audio/video? Unless others chime in all I can suggest is wipe OS and re-install Windows... Try posting over at TGB
Old 12-10-2013, 09:45 AM - Thread Starter
anmg's Avatar
Quoted: 65 Post(s)
I tried to reboot after uninstalling WMC. Still no go. I don't want to use the TV function, don't have a TV card. I don't really want to go through a windows reinstall if I can fix this. Anyone else have a suggestion?
anmg is offline
Old 12-10-2013, 10:03 AM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
So what are you using WMC for exaclty? If you don't have a Tv tuner card then that may be the whole reason why the option to "configure your Tv or monitor" is not listed. All it really does is change how much overscan is used for the WMC OSD/Menus, set 4x3 or 16x9, set or change the video resolution/timing for video playback, then runs through a some simple test patterns so you can adjust the video controls of your monitor. Do you really need to do any of that?
Old 12-10-2013, 12:21 PM - Thread Starter
anmg's Avatar
Quoted: 65 Post(s)
I just want to make sure wmc is not broken before I spend many hours setting up my HTPC. I'm only using it as an engine for media browser and xmbc. I will only be playing movies.
anmg is offline
Old 12-10-2013, 06:07 PM - Thread Starter
anmg's Avatar
Quoted: 65 Post(s)
Does anyone have any idea on this? It's driving me crazy! I just installed windows yesterday and everything went fine during the install. I tried doing system restore prior to first opening WMC. I tried to switch from hdmi to vga. Still no go.
anmg is offline
Old 12-10-2013, 06:52 PM
pittsoccer33's Avatar
Quoted: 648 Post(s)
Liked: 426
its not under setting--> general. its under settings --> tv
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is online now
Old 12-10-2013, 07:16 PM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
On my machines it can be found in two places- under Tv AND under General>WMC Setup
Old 12-10-2013, 07:41 PM - Thread Starter
anmg's Avatar
Quoted: 65 Post(s)
I don't have a tv card so I can't get it under
I can't get it under tv, I don't have a tv tuner card. I only want to use wmc for movies.
It just doesn't show at all under General>WMC Setup. I see it your screen but on mine the configure line is not there.
anmg is offline
Old 12-10-2013, 07:49 PM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
My laptop does not have a Tuner but I still have Settings > TV.
Did you successfully complete Install Play Ready?
Did you try Settings > General > WMC Setup > Run Setup Again ?
Old 12-10-2013, 07:55 PM - Thread Starter
anmg's Avatar
Quoted: 65 Post(s)
I tried run setup a again. No luck. Where can I get to Play Ready?
anmg is offline
Old 12-10-2013, 07:58 PM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
Originally Posted by anmg View Post
...Where can I get to Play Ready?
...I only see set up internet connection, set up tv signal, set up your speakers, run setup again and install PlayReady...
Old 12-10-2013, 08:15 PM - Thread Starter
anmg's Avatar
Quoted: 65 Post(s)
Ok, I see sorry. I installed play ready but still doesn't change anything. I was trying to copy the active window so I could show you mine like you did. How do I do that so I can post it.
Thanks again for your help.
anmg is offline
Old 12-10-2013, 08:38 PM - Thread Starter
anmg's Avatar
Quoted: 65 Post(s)
This is what I see. I only have 5 options, there should be 6.
anmg is offline
Old 12-10-2013, 08:41 PM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
Wonder why "Install Play Ready" is still there? It should be gone after you complete the play ready install (at least on my machines they are)....
Old 12-10-2013, 08:47 PM - Thread Starter
anmg's Avatar
Quoted: 65 Post(s)
I took the picture before I installed it. It is gone now. I only have 4 options not 5.
anmg is offline
Old 12-10-2013, 09:02 PM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
Close WMC then try this Reset WMC process
Old 12-10-2013, 09:39 PM - Thread Starter
anmg's Avatar
Quoted: 65 Post(s)
I tried it. Rebooted. Same problem.
I ran sfc /scannow from a command prompt to check windows integrity. No problem with windows. Do you think it's time to call Microsoft? Are they good on support with this kind of stuff or will they just say to reinstall windows? I tried posting on GTB. No one there is offering any other solutions.
anmg is offline
Old 12-10-2013, 09:43 PM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
Sorry I'm out of ideas. You could have re-installed Windows several times by now smile.gif
Old 12-10-2013, 09:48 PM - Thread Starter
anmg's Avatar
Quoted: 65 Post(s)
You are right! Thanks
anmg is offline
