Critique my HTPC build plan - Page 15 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
Old 06-18-2014, 07:21 PM
sharp360's Avatar
Originally Posted by Larry M View Post
Anyone have experience racking a Silverstone GD08?<br><br>
I see the rack ears for my case are <a href="http://www.silverstonetek.com/product.php?pid=346" target="_blank">http://www.silverstonetek.com/product.php?pid=346</a><br><br>
According to Silverstone, "The main function of the RA02 is to aid in securing your SilverStone desktop products to a rack storage, please DO NOT make RA02<br>
as the sole supporting structure for the whole case, you should still use a rackmount tray or sliding rail to help with weight support"<br><br>
Does anyone know exactly which MA shelf I should be using?
As stated the rack ears are just for extra stability. I didn't use them in my rack. I did find a nice 4u rack shelf from middle Atlantic (U4V) that offered good ventilation. Especially for the fans in the back right side of the case. A lot of other shelves didn't provide as much breathing room.
Link for shelf
http://www.cdw.com/shop/products/Mid...sSRdzWamDw_wcB
My Theater build
http://www.avsforum.com/avs-vb/showt...9#post21268949
xboxone gamertag: MASTERpTWINKIE
PS3: zaczimer
sharp360 is offline
Old 06-18-2014, 07:52 PM - Thread Starter
Larry M's Avatar
Quoted: 29 Post(s)
Liked: 45
Link for shelf
Larry M is offline
Old 06-25-2014, 12:22 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
That is a nice RACK. How much did you pay for that ?
Mfusick is offline
Old 06-25-2014, 07:49 PM
WaterBoyz's Avatar
Are you asking about these?
Larry M likes this.
I'm old.
Was trained on vacuum tubes.
Most everything I've worked on is in the museum or on the History Channel.
WaterBoyz is offline
Old 06-26-2014, 05:11 AM - Thread Starter
Larry M's Avatar
Quoted: 29 Post(s)
Liked: 45
My rack was quite a bit less expensive than that rack, plus I got mine used.
What makes them really expensive are all the accessories
dfkimbro likes this.
Larry M is offline
Old 06-26-2014, 06:18 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Those probably cost about $8500. Easier to find and a lot more retailers than Larry's rack....
Mfusick is offline
Asrock Z87m Extreme4 Lga1150 Intel Z87 Chipset Ddr3 Quad Crossfirex Quad Sli Sata3 Usb3 0 Microatx M , Asrock , Silverstone Black Milo Series Ml05b Mini Itx Media Center Htpc Case , Rosewill , Seagate , Seagate Hard Drives , Seagate Stbv4000100 4tb Expansion Desktop Drive , Mediabrowser 3 , Mediabrowser
