Bitstreaming of DTS-HD MA and Dolby TrueHD from Windows HTPC not working - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 2 Post By Foxbat121
post #1 of 19 Old 12-21-2013, 10:47 PM - Thread Starter
jaydee77ca's Avatar
Quoted: 39 Post(s)
Liked: 24
I am hoping someone can help me get bitstreaming of DTS-HD MA and Dolby TrueHD working on my HTPC. When I play an m2ts file with a DTS-HD MA audio track (like one from here for example) my receiver does not show the DTS-HD MA icon. I've confirmed that my receiver can decode DTS-HD MA as I have my PS3 connected to it and when I play a BluRay with a DTS-HD MA track the icon does appear.
Here is the relevant info:
  • Motherboard: Gigabyte H61N-USB3
  • CPU: Intel Celeron G1620
  • OS: Windows 7 Ultimate 64-bit
  • Player: Plex Home Theater
  • Receiver: Pioneer VSX-820
The HTPC is connected to the receiver via HDMI. The TV is connected to the receiver via HDMI. The video is passed through from the receiver to the TV.
On the HTPC when I go to the Properties of the VSX-820 playback device and look under Supported Formats tab it only lists the following:
  • DTS Audio
  • Dolby Digital Plus
  • Dolby Digital
I can't figure out why the PC is not showing DTS-HD MA and Dolby TrueHD in the list. I've tried re-installing drivers, etc. and nothing seems to work. Any help would be greatly appreciated!
jaydee77ca is offline
post #2 of 19 Old 12-22-2013, 12:22 AM
jbcain's Avatar
Liked: 64
you need to go into audio settings in PHT and use WASAPI
jbcain is offline
post #3 of 19 Old 12-22-2013, 12:31 AM - Thread Starter
jaydee77ca's Avatar
Quoted: 39 Post(s)
Liked: 24
I am using WASAPI in Plex. I've also tried VLC but it doesn't work either frown.gif
Sent from my SGH-I747M using Tapatalk
post #4 of 19 Old 12-22-2013, 01:02 AM
jbcain's Avatar
Liked: 64
what bitrate did you select in windows speaker config
jbcain is offline
post #5 of 19 Old 12-22-2013, 02:18 AM
steelman1991's Avatar
Quoted: 211 Post(s)
Liked: 116
Not certain your CPU has HD Audio (DTS MA/True HD) as part of its spec - least not that I could fine. Might need to invest in a different CPU or a seperate GFX card, with the capability.
Unless something has changed recently VLC doesn't support HD Audio, so testing with it is really pointless. Try playing the file with mpc-hc (new builds come with LAV filters pre installed, set them up to decode the HD Audio codecs and test with a file).
steelman1991 is offline
post #6 of 19 Old 12-22-2013, 03:06 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Or you could try shark007 codec pack and try WMC. Set up LAV audio for bitstreaming
Mfusick is offline
post #7 of 19 Old 12-22-2013, 05:54 AM
TimA's Avatar
Quoted: 18 Post(s)
Liked: 29
I recommend getting the latest released version of MPC-HC. The LAV filters are included and MPC-HC Advanced Setup guide will walk you through the audio setup. For now, ignore advanced video stuff (XySubfilter, MadVr, Reclock, etc). It may look complicated but it should only take a few minutes. MPC-HC is my go to movie playback application since the playback filters are built-in and it always works.
http://www.avsforum.com/t/1357375/advanced-mpc-hc-setup-guide
TimA is offline
post #8 of 19 Old 12-22-2013, 06:38 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
OP,
You need update your graphics driver (download directly from Intel) to make those HD audio formats show up. Without those audio formats show up in there, it doesn't matter what software you use, you won't get HD audios.
Mfusick and lulimet like this.
Foxbat121 is online now
post #9 of 19 Old 12-22-2013, 08:32 AM
Quoted: 211 Post(s)
Liked: 116
Foxbat - does that CPU support HD Audio though, couldn't find any reference to it on the intel spec page - if not updating dirvers aren't going to help.
post #10 of 19 Old 12-22-2013, 11:58 AM - Thread Starter
jaydee77ca's Avatar
Quoted: 39 Post(s)
Liked: 24
@Foxbat121 That is what I was thinking. I think I only updated the drivers from the Gigabyte site. I'll try updating the Intel graphics drivers direct from the Intel site and report back.
post #11 of 19 Old 12-22-2013, 12:20 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
I have no idea either. But either way, install the latest driver from intel and you will find out.
post #12 of 19 Old 12-22-2013, 12:33 PM
cburbs's Avatar
Quoted: 94 Post(s)
HD audio playback is a standard specification for this MB. Probably needs the latest drivers.
"You’re KILLIN’ ME Smalls! "
Sony 55EX500 Settings
cburbs is online now
post #13 of 19 Old 12-22-2013, 05:01 PM - Thread Starter
jaydee77ca's Avatar
Quoted: 39 Post(s)
Liked: 24
I have been trying to update the drivers all day. I keep getting a blue screen of death at boot when connected via HDMI to the receiver. I tried installing the drivers while connected to my dell LCD monitor and they worked fine. But as soon as I boot with HDMI connected I get the blue screen again. >frown.gif
post #14 of 19 Old 12-23-2013, 08:27 AM - Thread Starter
jaydee77ca's Avatar
Quoted: 39 Post(s)
Liked: 24
Ok, so after much gnashing of teeth I think I finally have the Intel display drivers updated. I was not able to get the latest ones from Gigabyte to work, nor the latest ones from Intel. However, I found an older set on Softpedia that seem to have installed without issues. I am happy to report that the problem is now solved! Dolby TrueHD and DTS-HD appear in the Supported Formats list and when I play the sample trailers in both MPC-HC and Plex the receiver shows DTS-HD and Dolby TrueHD! Thank you all for your help!
post #15 of 19 Old 12-23-2013, 08:31 AM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
Link for reference will help others out if they have a similar issue.
oman321 is offline
post #16 of 19 Old 12-23-2013, 10:14 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
There maybe a hardware compatibility problem, e.g. the memory modules don't work well with the motherboard. I have never encountered any intel driver cause BOSD or crash issues. I do encounter memory modules that cause system instability couple times. Good to have a MicroCenter store nearby so that I can swap to a different brand of memory really quick..
post #17 of 19 Old 12-23-2013, 05:37 PM - Thread Starter
jaydee77ca's Avatar
Quoted: 39 Post(s)
Liked: 24
These are the ones I installed from Softpedia:
Gigabyte GA-H61N-USB3 (rev. 1.0) Intel VGA Driver 15.22.4.64.2418 for Vista64, Win7 x64
The 15.33.8.3345 version on the Gigabyte website gave me BSOD whenever I plugged in HDMI. As did the latest from the Intel site.
post #18 of 19 Old 07-14-2014, 09:37 PM
jmleese's Avatar
Old topic, I know, but it seems like there are a number of people who have issues with getting true DTS or DD - whatever version you prefer, to properly output to their AVR.
I can recommend DVDFab's Media Player as a solution that worked perfectly for me being able to output a lossless stream. Even better, was the fact that it will play content in HD Master Audio and the like without triggering Cinevia - which I was constantly having an issue with whenever trying to play a lot of the same content via my BR player, XBone, Roku, and other devices that have, and can stream media off different types of storage, like USB, for example.
Hope this helps either the OP or anyone else who runs into the same annoying predicament!
jmleese is offline
post #19 of 19 Old 07-14-2014, 09:52 PM
Dark_Slayer's Avatar
Quoted: 655 Post(s)
Liked: 434
Can't say that it would unless DVDfab wants to also go ahead and make an entire frontend replacement (WMC, XBMC, MB3, Plex, etc). Typically the only reason anyone here looks around for different players that install their own codecs is for a sanity test, or just to say "I also tried on this and it didn't work" . . . the end goal is always to get everything working right in the desired frontend
Dark_Slayer is offline
Reply Home Theater Computers
