Can I use a 4TB hdd as my C drive? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 12-24-2013, 04:07 PM - Thread Starter
Reiter's Avatar
My current drive is acting up and I have a 4tb external drive that I haven't opened yet, if I remove it from the enclosure, can I use it as a C drive? I'll be using 64bit Win8.
Reiter is offline
post #2 of 7 Old 12-24-2013, 04:59 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
You can but you are better off getting a new SSD for your OS drive. That's my advice.
Mfusick is offline
post #3 of 7 Old 12-24-2013, 05:27 PM
Mrkazador's Avatar
Quoted: 258 Post(s)
Liked: 386
If you want to use a drive larger than 2TB for your boot drive, a motherboard with UEFI is needed.
Mrkazador is online now
post #4 of 7 Old 12-24-2013, 06:13 PM
marcw2's Avatar
Is this just a media sever or will you use it as a everyday PC?. If just a media sever you will not need a ssd for the os, you will not be driving the os so hard that it will need the speed of ssds. You should partition the drive into 2 drives so if need to rebuild, all data in the second drive should not be touched and only touch the os.
marcw2 is offline
post #5 of 7 Old 12-24-2013, 07:05 PM - Thread Starter
Reiter's Avatar
It's my HTPC. I have around 50TB of movies/tv shows and I use it for occasional gaming via Steam. So far, I hadn't had any issues with load times that have bothered me.
I don't have any data that I can't replace so I'm not concerned with RAID or anything like that, so I'd rather not partition. I was mainly thinking that I could use the 4tb drive I already had to save some money and use the extra space to download all of my Steam games on one drive for use with Big Picture mode.
It's used for XBMC 90% of the time though.
Reiter is offline
post #6 of 7 Old 12-24-2013, 07:25 PM
assassin's Avatar
Quoted: 87 Post(s)
Liked: 246
Although I personally prefer a ssd for my os there is nothing "wrong" with using a 4tb hard drive instead depending on your goals.
Tonight I am updating my in-laws htpc (i3 2100 which is now nearly 3 years old). As I type this while it's updating we are watching Monsters University mkv full bluray rip with the kids.
Looks great. Sounds great. Works great. They have never complained. Not quite as snappy as my htpcs but completely acceptable, imo, for basic playback and use.
assassin is offline
post #7 of 7 Old 12-25-2013, 08:09 AM
cybrsage's Avatar
Liked: 154
Provided your motherboard is new enough to support booting to a drive greater than 2TB, as Mrkazador said, you will be fine. I personally highly recommend an SSD instead. I have a 250GB one in my gaming machine and have several games, plus the OS and all the assorted other things (flash, java, etc) and still have a LOT of space left.
cybrsage is offline
Reply Home Theater Computers
