Makemkv - 7.1 Sound - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 12-24-2013, 11:02 PM - Thread Starter
bbibb's Avatar
Quoted: 16 Post(s)
Hi all,
I have been experimenting with Makemkv for ripping blu-ray dvds to a hard drive.
I cannon seem to get the 7.1 sound to work in the resulting file.
When I playback with Windows Media Player, my receiver says the sound is Dolby Digital 5.1.
When I playback with Windows Media Center, the receiver says the sound is PCM 2 channel.
Any suggestions?
Thanks for your help.
Brady
bbibb is offline
post #2 of 21 Old 12-24-2013, 11:04 PM
assassin's Avatar
Quoted: 79 Post(s)
Liked: 242
Are you sure the source has a 7.1 audio track? Not all of them do.
assassin is offline
post #3 of 21 Old 12-25-2013, 09:32 AM - Thread Starter
bbibb's Avatar
Quoted: 16 Post(s)
Yes. The source is 7.1. I fell in love with 7.1 and am always checking this out. There is a scene in this movie where a horse is on the roof of a house. It sounds like the thing is right above your head. Amazing.
Makemkv shows a checkbox for the DTS HD Audio, and I made sure that was checked.
Brady
bbibb is offline
post #4 of 21 Old 12-25-2013, 09:37 AM
assassin's Avatar
Quoted: 79 Post(s)
Liked: 242
Use the program mediainfo to look at the mkv file and see what audio track was ripped.
assassin is offline
post #5 of 21 Old 12-25-2013, 10:37 AM - Thread Starter
bbibb's Avatar
Quoted: 16 Post(s)
Brady
bbibb is offline
post #6 of 21 Old 12-25-2013, 12:59 PM - Thread Starter
bbibb's Avatar
Quoted: 16 Post(s)
It looks like the .mkv file is storing the proper format, but it does not seem to play via WMC or Windows Media Player?
Brady
bbibb is offline
post #7 of 21 Old 12-25-2013, 01:09 PM
assassin's Avatar
Quoted: 79 Post(s)
Liked: 242
What are you using for htpc playback? Are you using lav with wmc? What receiver are you using and how is it connected to your htpc?
assassin is offline
post #8 of 21 Old 12-25-2013, 01:44 PM
sippelmc's Avatar
Quoted: 77 Post(s)
Liked: 68
It sounds like WMP/WMC is downsampling on its way to the AVR.
I think only Win8 has 7.1 built in. What OS are you on?
In any event, the most likely fix is to get LAV filters and bitstream the content to your AVR (which I assume can handle 7.1).
sippelmc is offline
post #9 of 21 Old 12-25-2013, 09:56 PM - Thread Starter
bbibb's Avatar
Quoted: 16 Post(s)
Thanks for the input.
I installed LAV. Don't know how I missed this. I follow Assassin's guides pretty close.
Now when I play the .mkv movie with Windows Media Player, the receiver shows DTS 7.1.
BUT when I play the movie with Windows Media Center (the preferred route), the receiver shows PCM 2 channel.
My HTPC is connected to an Onkyo TX-NR818 with an HDMI cable. The HTPC is running Windows 7 Home premium, 67 Bit OS.
I also have a Blu-ray player connected to the Onkyo. This seems to play 7.1 fine.
Any additional insight you may have would be greatly appreciated.
-Brady
Brady
bbibb is offline
post #10 of 21 Old 12-26-2013, 10:45 AM
sippelmc's Avatar
Quoted: 77 Post(s)
Liked: 68
What player are you using in WMC? External or internal? It sounds like you are 99% there, we just gotta get bitstreaming through WMC to run.
sippelmc is offline
post #11 of 21 Old 12-26-2013, 11:14 AM
qz3fwd's Avatar
Quoted: 319 Post(s)
Liked: 135
-Brady
the 67 bit OS is your problem.
seriously though doesnt wmc bypass all non microsoft directx filters and use its own filter graphs during playback?
qz3fwd is offline
post #12 of 21 Old 12-26-2013, 12:21 PM
Shark007's Avatar
Quoted: 81 Post(s)
Liked: 73
The easiest solution when using the Windows players is to remove LAV and install the Shark007 Codecs.
During installation, select the [x] SUGGESTED settings checkbox and on the Audio TAB, set HDMI in both GUI's (32bit and 64bit)
You'll also need 2 installations, The 32bit Codecs and the x64Components addon.
Download url's to current versions can be found on the Setup and usage page.
Not when it is setup to use external filters (LAV) properly; which is what the Shark007 Codecs will do for you.
Use Shark007 Codecs and retain your sanity.
Shark007 is offline
post #13 of 21 Old 12-26-2013, 12:32 PM
captain_video's Avatar
Quoted: 510 Post(s)
Liked: 336
Try using XBMC for playback. If the movie has 7.1 audio it should play via XBMC with no problems.
captain_video is online now
post #14 of 21 Old 12-26-2013, 12:46 PM
assassin's Avatar
Quoted: 79 Post(s)
Liked: 242
Agreed.
assassin is offline
post #15 of 21 Old 12-26-2013, 10:57 PM
Tong Chia's Avatar
Did you extract the DTS core (aka regular DTS) track in addition to the DTS HDMA track?
DTS HDMA is DTS core + the delta to restore lossless playback for it to work properly.
Tong Chia is offline
post #16 of 21 Old 12-27-2013, 05:52 AM
lefthandluke's Avatar
Quoted: 137 Post(s)
Liked: 266
is there a list of movies that are 7.1...?
at the zenith of his nadir...
lefthandluke is offline
post #17 of 21 Old 12-27-2013, 09:49 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 398
The list will be too long and meaningless.
OP's problem is software player side of things. To bitstream or playback 7.1 audio needs proper setup and configuration on each playback software. Not all players support full 7.1 lossless playback. It is never an easy task on a PC.
Get a free DTS-HD MA decoder is also another issue. Most of them are embedded into the commercial pay software. Without it, you will only be able to decode the 5.1 DTS core, not the 7.1 lossless.
Foxbat121 is online now
post #18 of 21 Old 12-27-2013, 01:50 PM
Tong Chia's Avatar
post #19 of 21 Old 12-30-2013, 11:30 AM - Thread Starter
bbibb's Avatar
Quoted: 16 Post(s)
I uninstalled LAV and installed Shark 32 + 64. I set the options you suggested. Works!
Thanks a bunch.
Brady
bbibb is offline
post #20 of 21 Old 12-30-2013, 11:36 AM - Thread Starter
bbibb's Avatar
Quoted: 16 Post(s)
Here is the listing I use: http://www.blu-raystats.com/Stats/Stats.php
Select the Audio dropdown, choose 7.1, then click the "Filter" button on the right.
Hope this is helpful.
Brady
bbibb is offline
post #21 of 21 Old 12-30-2013, 02:21 PM
Shark007's Avatar
Quoted: 81 Post(s)
Liked: 73
Thanks a bunch.
you're welcomed. I work hard at making this easy.
fitbrit likes this.
Shark007 is offline
Reply Home Theater Computers
