AMD CPU - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 12-30-2013, 11:07 AM - Thread Starter
Kevin-14's Avatar
Hello,
I am trying to upgrade my system to play Blue Ray,1080p streaming videos, Netflix HD, etc
My current configuration is old machine AMD E-450 (X1430G) connected to 55 inch LG TV via Yamaha htr-4065
I am not able to decide which processor/motherboard should I upgrade to AMD A10 6800K or A8 6600K  or FX 6350.
I don't know which of these processor would be able to play HD video or should I be also looking at adding a graphics card and if which one.
Thank you for your advise.
Kevin-14 is offline
post #2 of 16 Old 12-30-2013, 03:01 PM
bimmerfreak0's Avatar
Quoted: 12 Post(s)
A8 would be sufficient IMO. However, this thread really needs to be moved out of the "deals" section and into the main thread.
bimmerfreak0 is offline
post #3 of 16 Old 12-30-2013, 03:02 PM
Quoted: 12 Post(s)
It's an FM2 socket by the way. I'd hold off as FM2+ is being released in January 2014.
post #4 of 16 Old 12-31-2013, 09:50 AM - Thread Starter
Kevin-14's Avatar
Thank you.
I don't know how to move this thread out of "deals"
Kevin-14 is offline
post #5 of 16 Old 01-01-2014, 12:36 AM
cybrsage's Avatar
Liked: 154
I let the mods know.
cybrsage is offline
post #6 of 16 Old 01-01-2014, 05:45 AM
TrevorS's Avatar
A8 is easily sufficient, I went A6 which should also have no problem doing the job. I suggest getting an FM2+ board for future upgradability. I also suggest spending some time learning about the processors and their capabilities. As in, if you don't need a Haswell i7-4770, then don't buy one!
TrevorS is offline
post #7 of 16 Old 01-01-2014, 06:05 AM
mightyhuhn's Avatar
Quoted: 731 Post(s)
Liked: 250
an e-450 should be fine for this just make sure dxva is working.
mightyhuhn is online now
post #8 of 16 Old 01-01-2014, 06:18 AM
DanPackMan's Avatar
Quoted: 232 Post(s)
Liked: 381
For playing local video, yes, but it might not be good for some streaming and Netflix, which are not always able to use hardware acceleration. I have an AMD 450 with Radeon HD 6320, similar to the OP, and have had no problems playing 1080p local LAN files or in streaming 720p content from the internet. Have not tried 1080p streaming from the internet, or Netflix.
DanPackMan is offline
post #9 of 16 Old 01-01-2014, 10:58 AM
rc05's Avatar
Quoted: 152 Post(s)
Liked: 87
The Netflix Windows 8 app seems to work fine with Super HD streaming on my E-350.
rc05 is online now
post #10 of 16 Old 01-01-2014, 11:29 AM
DanPackMan's Avatar
Quoted: 232 Post(s)
Liked: 381
As I understand, Win 8 Netflix enables hardware acceleration. I assume the OP likely has a Win 7 setup, which means silverlight is the only option.
post #11 of 16 Old 01-01-2014, 01:32 PM
Ruiner's Avatar
e-350 boards were fairly plentiful and affordable. There is only one mITX Kabini quad board (zacate successor) and it's pricey. It seems AMD wants it for netbooks only.
Ruiner is offline
post #12 of 16 Old 01-01-2014, 11:32 PM
Jeff Krogue's Avatar
I really wish netflix would dump silverlight
Jeff Krogue is offline
post #13 of 16 Old 01-02-2014, 02:37 PM
mightyhuhn's Avatar
Quoted: 731 Post(s)
Liked: 250
cheaper than a new pc.
post #14 of 16 Old 01-02-2014, 05:48 PM
My e350 also has win 7, dang it.
post #15 of 16 Old 01-03-2014, 06:02 AM
DanPackMan's Avatar
Quoted: 232 Post(s)
Liked: 381
I still just use Roku and other devices like a BluRay player for Netflix. I quit trying the PC route long ago. My HTPC is pretty much for XBMC only, in which case the E350/E450 platforms are quite good performers. Particularly with OpenELEC.
post #16 of 16 Old 01-03-2014, 01:18 PM - Thread Starter
Kevin-14's Avatar
I use Windows 7. I am also having issues playing 720p and using flash..
I am trying a different approach as well I have am old e machines sitting around I am going to add a cheaper graphics card and see if that works out..
Kevin-14 is offline
Reply Home Theater Computers
