Need recommendations for a new optical drive. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 12-31-2013, 02:50 PM - Thread Starter
Skylark's Avatar
The optical drive in my tower PC died so I need to buy a replacement. I need a standard 5-3/4" wide x 1-5/8" high drive that fits in the tower drive bay. I don't need a Bluray drive.
I want to buy a SATA DVD/CD drive that can rip my standard DVDs to put on my home theater hard drive. One user review I read said that the Asus DRW-24B1ST drive can't rip DVDs because of its firmware restrictions.
Is the Lite-on IHAS124-04 a good drive? Anyone have one and used it to rip standard DVDs?
Any other suggestions for a good SATA optical drive?
Skylark
Skylark is offline
post #2 of 13 Old 12-31-2013, 03:28 PM
Aleron Ives's Avatar
Quoted: 1580 Post(s)
Liked: 1289
In my experience, the brand doesn't matter very much. I've gone through four or five DVD burners in the last decade, and they all eventually wore out, since burning discs is harder on the laser than ripping them. I've tried Samsung, Sony, Pioneer, and possibly Lite-On, and my current burner is LG. They all worked fine while they were in service and all died after a few years, so as long as you pick a reputable brand and a drive that has decent reviews on Newegg (e.g. no trend of drives coming DOA), you should be fine.
Aleron Ives is offline
post #3 of 13 Old 12-31-2013, 04:01 PM
pittsoccer33's Avatar
Quoted: 648 Post(s)
Liked: 426
no drive is prevented from ripping (not that ive heard yet - that would sure be something!)
what some have is a "feature" called riplock. the idea being that it slows down ripping. I guess the party line is that it keeps the drive from spinning too fast to make noise.
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is online now
post #4 of 13 Old 12-31-2013, 06:07 PM - Thread Starter
Skylark's Avatar
Thank you for taking the time to help.
Skylark
Skylark is offline
post #5 of 13 Old 12-31-2013, 06:11 PM - Thread Starter
Skylark's Avatar
This is the quote from an amazon review for the Asus DRW-24B1ST:
"The only down side to this drive and the reason I only gave it 4 stars, is that it has something built into the firmware that does not allow a CD or DVD encryption breaking program to run. If you have it installed and try to use the drive it locks up your computer."
Found here:
http://www.amazon.com/Asus-Serial-ATA-Internal-Optical-DRW-24B1ST/product-reviews/B0033Z2BAQ/ref=dp_top_cm_cr_acr_txt?showViewpoints=1
Strange if it's true.
Skylark
Skylark is offline
post #6 of 13 Old 12-31-2013, 06:25 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
if it can read.. it can rip.
The End.
Mfusick is offline
post #7 of 13 Old 12-31-2013, 06:39 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151267
Thirteen bucks. Six more hours to order it.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #8 of 13 Old 12-31-2013, 06:40 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I am grabbing it just to have it.
Mfusick is offline
post #9 of 13 Old 12-31-2013, 10:15 PM
captain_video's Avatar
Quoted: 510 Post(s)
Liked: 336
Optical drives are so cheap these days you just throw them away and get a different one if you don't like it. I've had extremely good luck with the Sony/Optiarc drives. They'll play or record any kind of disc I throw at it. I've had issues with just about every other brand of drive in the past, but obviously, YMMV. I've had LG, Samsung, Asus, and Lite-On drives all crap out on me, but the Sony/Optiarcs just keep on ticking.
captain_video is offline
post #10 of 13 Old 01-01-2014, 03:42 AM - Thread Starter
Skylark's Avatar
The End.
Sounds right. Thanks,
Skylark
Skylark is offline
post #11 of 13 Old 01-01-2014, 03:44 AM - Thread Starter
Skylark's Avatar
I think I'll try the Optiarc plus drive. A bit more expensive but I guess one gets what one pays for.
Skylark
Skylark is offline
post #12 of 13 Old 01-02-2014, 02:02 PM - Thread Starter
Skylark's Avatar
Learned that Optiarc was a joint venture between Sony and NEC and that Sony bought out NEC in Dec 2008. NEC made good optical drives which is may be why the Optiarc optical drives have good reviews. But Sony closed the Optiarc division in March 2013 so the Optiarc drives being sold now must be from remaining stock.
I ordered an Optiarc 5280S-CB-PLUS optical drive anyway since I liked the NEC optical drive that I had in my previous Windows XP PC. As you said "they just keep on ticking".
Skylark
Skylark is offline
post #13 of 13 Old 01-02-2014, 09:38 PM
Quoted: 510 Post(s)
Liked: 336
Interesting. I had seen the drives listed as Sony/Optiarc/NEC so I figured there was some sort of joint venture with NEC. NEC drives were extremely popular a while back and had websites dedicated to developing custom firmware for it. They had firmware available to enable recording on dual layer DVDs before the official firmware was released. I hadn't seen any new NEC drives released in quite some time so I suspected they went out of business.
Reply Home Theater Computers
