XBMC playercorefactory Help please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-05-2014, 02:53 PM - Thread Starter
jimray's Avatar
Hi all, Loving XBMC very much, I just discovered it. Everything is working great except for one thing.
I have XBMC set to play videos through MPC-HC. This works great for my movies and SOME streatming. But some streaming it doesn't work. It loads up MPC-HC but then doesn't start the video.
I'd like MPC-HC to play my files, but I'd like XBMC to use it's own internal player for streaming. I understand it needs to be set in playercorefactory, but I can't figure it out. Here is my playercorefactory.
Code:
<playercorefactory>
<players>
<player name="Universal_Player" type="ExternalPlayer" audio="false" video="true">
<filename>C:\MPC-HC\mpc-hc.exe</filename>
<args>"{1}" /fullscreen</args>
<hidexbmc>true</hidexbmc>
<hideconsole>true</hideconsole>
<warpcursor>none</warpcursor>
</player>
</players>
<rules action="prepend">
<!-- Universal Player -->
<rule filename="*.*" player="Universal_Player"/>
</rules>
</playercorefactory>
After extensive searching online I've found someone else who wanted the same thing and they were told to add:
Code:
  <rule internetstream="false" player="Universal_Player" />
</rules>
I have added this in it's entirety, and just the "rule" part several times and in several different places, but can't get it to work.
Can anyone help Please?
jimray is offline
post #2 of 2 Old 01-07-2014, 12:55 AM
acejh1987's Avatar
Not 100% sure about streaming but try the following as the rule section -
Code:
  <rule internetstream="true" player="DVDPlayer" />
</rules>
acejh1987 is offline
Reply Home Theater Computers
