Really important to clean your HTPC/PC regurarly - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-10-2014, 01:04 PM - Thread Starter
boguspomp's Avatar
Quoted: 118 Post(s)
Liked: 122
Hello there,
Just wanted to remind some of you that cleaning the HTPC (or any PC for that matter) is essential to keep those babies running for a long time. I do it every 4 - 6 weeks. This time I waited 6 weeks and the amount of dust being stuck onto the filters of my HTPC was impressive. Temperature of the MB and Graph went down 2°C immediately.
While I was at it, I also cleaned my Office/ Work PC, which is always open on one side to let the air circulate and the dust collected in the fan of the GT 630 Graphic Card was close to scary. After the cleaning the temperature of all the important parts went down between 4°C and 5°C. That is a lot and proves that dusting is essential for a long lifespan.
Cheers
boguspomp is offline
post #2 of 10 Old 01-10-2014, 02:03 PM
SlantNGo's Avatar
I just did my first cleaning after about 1 year after building my HTPC. MB and CPU temps dropped by about 6 C each. I was impressed by how little dust, namely none, got through the dust filters on my Silverstone GD-05B.
SlantNGo is offline
post #3 of 10 Old 01-10-2014, 02:07 PM
Djoel's Avatar
Quoted: 544 Post(s)
Liked: 417
You guys use a vacuum for the task, or some other method ?
Thanks for the heads up.
Djoel
Djoel is offline
post #4 of 10 Old 01-10-2014, 02:12 PM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
Originally Posted by boguspomp View Post
Hello there,
Cheers
We use 3M furnace filters, so that we don't end up breathing all that crap in the air.
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
post #5 of 10 Old 01-10-2014, 05:35 PM - Thread Starter
boguspomp's Avatar
Quoted: 118 Post(s)
Liked: 122
Djoel
I use the counter method, namely a hairdryer on COLD air of course. Very very important to keep the fans from moving while blowing the dust out of the power unit, the processor cooling unit and the Graphic Card's fan, preferably outside. I use cotton swaps for that but also for gently cleaning the cooling areas in the PC that don't have fans.
Works great and as mentioned in the initial post helps lowering the temperature considerably.
cheers
post #6 of 10 Old 01-11-2014, 05:20 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2695
Djoel
I use my air compressor with fine straw trigger .... It's the best option I've found.
Mfusick is offline
post #7 of 10 Old 01-11-2014, 08:56 AM
Djoel's Avatar
Quoted: 544 Post(s)
Liked: 417
Thanks for the suggestion Mike sounds like an inexpensive option, I know for some finishes I use to own (piano glossy types) I wound ovoid using an air compressor can, as it might projectile tiny particles thus scratching the surface. Wasn't too sure if the same case applied here.
Dan
Djoel is offline
post #8 of 10 Old 01-11-2014, 10:05 AM
olyteddy's Avatar
Quoted: 534 Post(s)
Liked: 940
Djoel
Doesn't that just push the dust further in? I use a brush and a piece of tubing shoved through a cork stuck in the end of my vacuum's hose.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #9 of 10 Old 01-11-2014, 10:22 AM
assassin's Avatar
Quoted: 155 Post(s)
Liked: 261
I use a shop vac on my server fwiw.
assassin is online now
post #10 of 10 Old 01-11-2014, 10:35 AM
tomandbeth's Avatar
Ditto. Set the regulator to 35 PSI or so. I also keep the case fans from spinning while I concentrate on the blade edges.
It had been years since I did mine. Big puffs of dust out of the CPU cooler and the PSU.
tomandbeth is offline
Reply Home Theater Computers
