HTPC video card problem! Help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-14-2014, 12:44 PM - Thread Starter
DigitalfreakNYC's Avatar
Quoted: 52 Post(s)
In March, I purchased this PC
http://www.newegg.com/Product/Product.aspx?Item=N82E16883220211
About 3 weeks ago, I was having major issues with it. It came down to the video card overheating and I noticed that the fan wasn't working. The temperature was getting to 90 degrees Celsius.
I decided to purchase a new fan from Ebay and that, too, didn't work. I assume my problem is with the card itself?
I contacted Asus and explained the problem. They told me that I would have to ship the entire unit back to them and supply them with all of my passwords and whatknot for them to fix it. I don't feel comfortable with that.
I also assume I could just purchase a new video card in the hopes that it would work but the power source on this computer is only 300w. The card I have is 3GB DDR3. I was thinking of getting a 2GB DDR5 but all of the cards I've seen need at least 400w.
Anyone have any advice?
"I have never seen it, but by all accounts it is terrible. However, I have seen the house that it built, and it is terrific." - Michael Caine, on Jaws the Revenge
DigitalfreakNYC is offline
post #2 of 3 Old 01-15-2014, 06:13 AM
Mac25's Avatar
Quoted: 14 Post(s)
you could just replace the video card with one that doesn't require a power feed from the power supply, but weak power supplies is a NoNo, I would suggest a better psu with a new video card before the cheap psu causes more problems at a latter date.
Mac25 is offline
post #3 of 3 Old 01-15-2014, 07:26 AM
LexInVA's Avatar
Quoted: 518 Post(s)
Liked: 218
Just swap out the video card for another low-end 600-series with DDR - make sure it's a Kepler and not a Fermi GPU - and you should be fine unless the PCIe socket isn't getting proper juice, which may be a board or PSU problem.
LexInVA is offline
Reply Home Theater Computers
