How do I know whether the signal from HTPC to AVR is "pure?" - AVS Forum | Home Theater Discussions And Reviews
Old 01-19-2014, 12:08 PM - Thread Starter
elee532's Avatar
Quoted: 78 Post(s)
How can I determine whether my Windows 8.1 HTPC connected to an AVR via HDMI is doing any "processing" of the audio signal before it send it to my HTPC?
elee532 is offline
Old 01-19-2014, 02:46 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
Use wasapi or bitstream the audio.
Mrkazador is offline
Old 01-19-2014, 05:31 PM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Google or search "bitstreaming". Then set your HTPC up to bitstream to your AV receiver.
assassin is offline
Old 01-19-2014, 05:39 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
Can you hear a difference? If not, does it matter?
Aleron Ives likes this.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is online now
Old 01-19-2014, 07:04 PM
bulls's Avatar
Quoted: 63 Post(s)
Liked: 33
^ hey hey hey, thats not how to sell M0n$ter cable or Bo$e speakers
bulls is offline
Old 01-21-2014, 08:55 PM - Thread Starter
elee532's Avatar
Quoted: 78 Post(s)
Mrkazador, assassin,
The purpose of my post was to see whether I was successfully bitstreaming to my AVR. How can I tell?
Mrkazador likes this.
elee532 is offline
Old 01-22-2014, 12:26 AM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
The display on the receiver should show, Dolby Digital, DTS, DTS-HD, and so on...
elee532 likes this.
Old 01-24-2014, 06:29 PM - Thread Starter
elee532's Avatar
Quoted: 78 Post(s)
Thank you Mrkazador. When I play DVDs and Blu-rays through Total Media Theater, my AVR shows DTS-HD, Dolby Digital, etc. So, it would appear I am bitstreaming to my AVR in this situation.
Why I play hi-rez multi-channel FLAC rips of DVD-Audio through Windows Media Center, my receiver shows "Multi-Channel In." What can I make of this? Being bitstreamed?
elee532 is offline
Old 01-24-2014, 06:44 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
As far as I know, you can't bitstream FLAC. It needs to be decoded to PCM first which is a lossless conversion. You can use a wasapi audio renderer to make sure Windows doesn't resample the audio.
Old 01-25-2014, 10:30 AM
Selden Ball's Avatar
Quoted: 3050 Post(s)
Liked: 1494
Also check to make sure your two-channel audio files (including FLAC) are being sent as two channels and not multichannel with the other channels silent. If your receiver can't apply Dolby Prologic or DTS Neo to stereo soundtracks, then they aren't being sent as stereo.
Selden
Selden Ball is offline
Old 01-25-2014, 01:27 PM
ser_renely's Avatar
B&W cm5
Pioneer Elite SC-27
Panasonic 50" GT50
HTPC - i5, ATI 7790
Crappy Klipsch sub
ser_renely is offline
