My 4 big obstacles to getting Windows Media Center working well (and the solutions) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 01-21-2014, 07:06 PM - Thread Starter
MadMyers's Avatar
Quoted: 204 Post(s)
Liked: 123
Quick update on my “upgrade” to a fully functional Windows Media Center PC.
I have an old Dell E510 from 2005 or maybe 2006. It has 2GB of memory and a dual core Pentium D running at 3Gz. For two years I’ve been using this as Windows Media Center along with an Xbox 360 as an extender. I used it solely as a DVR for over-the-air content. I’m running a 32-bit version of Windows 7.
I decided I wanted better video quality (mostly 1080i deinterlacing using Vector Adaptive as the 360 only does some form of motion adaptive) so I decided to connect the PC directly to my Onkyo AVR.
First thing was a new video card for the E510. I ended up getting a Zotek GT 630 card (nVidia). It fit in my E510 (with only supports a single “modern” PCI slot. It also it silent because it has no fan.
So the card arrives, I pull the existing video card and install the GT 630… install the latest nvidia drivers (332.21)…
Here are the non-trivial problems I ran into and their solutions.
1) Audio would stop working (“not plugged in”)
After leaving the Media Center for a while, I would come back and there would be no audio. Looking at the nVidia control panel, I would see it reporting that my Onkyo AVR wasn’t plugged in (via HDMI). This clearly wasn’t true as I had video.
Researching I found this is an exception common problem. I found people complaining about it 6 months ago.
I followed the “block pin 19” approach on the HDMI cable and it has solved my problem. I already had a cheap HDMI “elbow” connector and a couple reasonable priced HDMI cables (thanks Monoprice), so I wasn’t too worried about doing anything that couldn’t be backed out.
With this “hack”, I haven’t had any HDMI audio loss.
2) Decoder isn’t available
When playing around with all the configuration knobs available, I ended up setting my sound configuration to be 5.1. This seemed completely logical. However, once I made this change I found out that Windows Media Center wouldn’t decode any video.
A little research and I found out that, for whatever reason, you should leave the PC configured as 2 channel. I know the Dolby Digital from my OTA content is bitstreamed, but I don’t see how this setting should break anything. Anyway, back to stereo and it’s working again.
3) Fast Forward would cause screen to blank quickly and then show video
I had watched a lot of test content before i noticed this. I typically use the “skip ahead 30 seconds” feature rather than fast forward. Using regular fast forward, I found that 50% of the time the video would black out immediately. My display would act as if the signal was lost. While there was no video, you could hear the windows rendered “fast” audio.
I couldn’t find any info about this problem when searching the web. I just guessed it had something to do with windows rendering the audio, rather than bitstreaming, during this 1.4x playback. Normally I wouldn’t think there would be any relation, but from #1 above I knew that nVideo and/or Microsoft was a little funky with regard to HDMI audio.
I found out that you can change the 3 fast forward speeds. A set of registry keys are supported, but are not in the registry by default. You need to create the key FastForwardRates (regedit, edit, new, key)
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Media Center\Settings\VideoConstants\FastForwardRates
Within the FastForwardRates you need to 3 individual sting keys. They are called “0”, “1”, and “2” (without the quotes). “0” is the first FF speed, “1” is the second FF speed, and “2” is the 3rd FF speed. The defaults are (apparently) 1.4, 10 and 100. I changed them to 5, 10, and 100.
This solved my screen blanking problem. Also, it caused windows to not decode the audio “fast”. This was a huge benefit, IMHO, because the windows decoded audio was much louder than the bitstreamed audio.
4) Screen would blank randomly when watching (29/59 problem)
This one didn’t appear until later in testing. It appears to just show up with some content. I discovered this is the so called 29/59 problem.
When the content changes framerates, sometimes nVidia or Microsoft would tear down the entire video path and set it up again. While I don’t understand why making the following changes resolves the problem, I’m happy to report the settings do fix the problem.
Set "Digital Color Format" to YCbCr444
Set “Content Type Reported to the Display” to “Full Screen Video”
Set the various configurations to say “use nVidia settings” rather than “allow application to configure”
[EDIT: Adding my card and driver version]
I'm using a Zotac GT 630 card ("Zone Edition") with the 332.21 drivers on Win 7 32-bit.
[EDIT: Adding a 5th that I should have included]
5) The on-screen keyboard wasn't appearing
When I went into the guide and then attempted to search for a program, the virtual keyboard wasn't showing up. When using my Xbox 360 extended, the keyboard would appear automatically. This is easily fixed with a registry change.
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Media Center\Settings\MCE.PerUserSettings\showOskOnKeyboardEnter
Should be set to 1.
With this change, the virtual keyboard shows up immediately.
So in conclusion with these changes (which may have been obvious to those on this board but it took me several days of tinkering to get it right), it seems to be working well. I do find the 1080i channels look better with the GT 630 deinterlacing rather than the Xbox 360.
Now I just need to look for a new Hard Drive that doesn’t click as much. The E510 used to be in a different room so a little clicking from the hard drive wasn’t a problem. Now that it’s near my AVR, the clicking is a little bothersome.
Hope this is useful to someone. Enjoy.
Joshua B, hogues, Tyborg and 1 others like this.
MadMyers is offline
post #2 of 13 Old 01-21-2014, 08:00 PM
hogues's Avatar
Quoted: 73 Post(s)
Liked: 51
Thanks for the info. I had some of the same problems.
hogues is offline
post #3 of 13 Old 01-22-2014, 12:42 PM - Thread Starter
MadMyers's Avatar
Quoted: 204 Post(s)
Liked: 123
I forgot one...
Should be set to 1.
Again, nothing that isn't out there on the web... but at least some of these tweaks/fixes are in a single location now smile.gif
[I'm editing this back into my original post]
MadMyers is offline
post #4 of 13 Old 01-29-2014, 09:01 PM
Raistlin_HT's Avatar
Quoted: 31 Post(s)
Liked: 30
Out of curiosity, do you have HBO?
I've just got my HBO activated in my recently set up WMC maching, and have the 29/59 issue on HBO channels (Verizon FiOS). My little Vostro 270s uses an Ivy Bridge i5 (Intel HD 2500) and exhibits stuttering.
I'm currently researching a good card to install that is fanless and doesn't have this bug. If the 630 doesn't have it, I'll pick one up.
Raistlin_HT is offline
post #5 of 13 Old 01-30-2014, 08:59 AM
hogues's Avatar
Quoted: 73 Post(s)
Liked: 51
I don't think that it's the card so much as the drivers. Some have it, some don't. My current driver does not (I'm not at home, so I don't know which one it is). Once I found it, I stuck with it and haven't upgraded once since then.
Edit: maybe turn the 29/59 bug into #6 on the list?
hogues is offline
post #6 of 13 Old 01-30-2014, 09:10 AM
Quoted: 31 Post(s)
Liked: 30
Interesting. When you have the chance, could you post what drivers you are using, and the model of your GPU?
From the (admittedly limited) research I've done, it seems to be the GPU and the drivers in combination? Like only certain GPU/driver combos have ever demonstrated not having the bug. For many GPUs, there is no known driver that works properly with this?
Out of curiosity, do you have HBO? I know some other networks show it as well (FX, etc supposedly), but I've only seen it with HBO. That leads me to think the problem may be masked on certain networks with some set ups ... and only shows itself on the worst cases. HBO is basically switching between 29 and 59 constantly.
[EDIT] I just found out the 630 is actually a re-badged GT430 with a higher clock. However, there is also a Kepler version that is different hardware. I'm curious which version you are running?
post #7 of 13 Old 01-30-2014, 10:45 AM
hogues's Avatar
Quoted: 73 Post(s)
Liked: 51
I have had several NVIDIA cards, all of which have exhibited this bug. However, all of them have been fine with the correct drivers. There may be cards that will always have the bug no matter what driver you have, but i have never heard that being the case. This thread at TGB has a ton of info: http://www.thegreenbutton.tv/forums/viewtopic.php?f=5&t=6556. I think that you may get better info over there because they are pretty much a WWMC only board.
I do have HBO and it was awful until I got the drivers sorted out. Good luck!
hogues is offline
post #8 of 13 Old 01-30-2014, 10:57 AM
Quoted: 31 Post(s)
Liked: 30
post #9 of 13 Old 01-30-2014, 10:59 AM
blushrts's Avatar
This link has some information on the 29/59 issue. http://experts.windows.com/w/experts_wiki/71.aspx?Sort=MostRecent&PageIndex=1
At the bottom are cards confirmed to work without the issue. I've used both a gt430 and hd6450 and can confirm either one handle the issue without stutter or flashing. My only issue with those cards is that I have to dial back my madvr settings.
blushrts is offline
post #10 of 13 Old 01-30-2014, 12:01 PM
hogues's Avatar
Quoted: 73 Post(s)
Liked: 51
I checked on Newegg and I have the ASUS GTX660-DC2O-2GD5. Big fan of this card, really quiet. I know that my driver version is whatever was recommended by TGB, which I think is 314.22.
hogues is offline
post #11 of 13 Old 01-30-2014, 12:04 PM - Thread Starter
MadMyers's Avatar
Quoted: 204 Post(s)
Liked: 123
It's covered by #4 on the list. You need to have a video card that can do it correctly and then you need to have drivers that make it work. I'll edit that post with my drivers and specific card put 29/59 in the title of #4.
... Altan
MadMyers is offline
post #12 of 13 Old 01-30-2014, 12:09 PM - Thread Starter
MadMyers's Avatar
Quoted: 204 Post(s)
Liked: 123
I'm only getting over-the-air channels. It was CBS that showed the 29/59 problem the most, however.
Oddly, it was Fox that really caused screen blanking when doing FF ---which I'm suspicious was some variation of the 29/59 problem that was caused by doing fast forward trick mode.
I'm using a Zotac GT 630 card (http://www.newegg.com/Product/Product.aspx?Item=N82E16814500305). It's not obvious to me what version of the 630 is used here. If there is some way to check, let me know.
MadMyers is offline
post #13 of 13 Old 01-30-2014, 01:24 PM
hogues's Avatar
Quoted: 73 Post(s)
Liked: 51
... Altan
It certainly does! That's my adult ADD for you, can't concentrate on anything more than 2 paragraphs long.
hogues is offline
Reply Home Theater Computers
