Intel NUC DN2820FYKH Bay Trail - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #151 of 161 Old 09-29-2014, 09:36 AM
mastermaybe's Avatar
Quoted: 435 Post(s)
Liked: 344
Originally Posted by Dark_Slayer View Post
I'll go back and read the beginning, but when was this determined?
Last I heard, Bay Trail is Intel's "Haswell-by-marketing" chipset with ivy bridge hd graphics (which didn't handle 24p like haswell)
Also, one of the chromeboxes advantages to those of us who are only interested in additional boxes to run openelec was that ram+ssd are included (saving the expense of sodimm and a usb flash drive)
Hi, I've seen multiple screen shots with 23.976 and that's what I'm getting. As I understand it, the Ivy B graphics driver was brought into line some time ago.
http://i.imgur.com/mL99nZ1.jpg
James
My Parlor and Theatre: "Jimbo's Dugout" : http://www.avsforum.com/forum/15-gen...re-parlor.html
Actual phone call (see pic to left):
 Tech (responding to laughter): "I'm sorry sir, did I miss something?"
Me: "Yeah, a case of Diet Mountain Dew walking across my living room."
mastermaybe is offline
post #152 of 161 Old 10-04-2014, 12:32 PM - Thread Starter
originalsnuffy's Avatar
I must say I am impressed. I spoke with Intel about the fact that advanced audio codecs cannot be bitstreamed as originally claimed and marketed. The eventually ended up approving an upgrade to a unit that does support that feature. Very nice of Intel and very classy.
originalsnuffy is offline
post #153 of 161 Old 11-18-2014, 07:10 AM
fly_sig's Avatar
With the latest Intel® HD Graphics Driver for Windows* 7/8/8.1 version 15.33.30.3958 posted for Ivybridge and Baytrail in the Intel support community Graphics forum
I get now HD Audio bitstreaming without a flaw on my j1900 platform ASRock Q1900-ITX under Windows 7 64-bit and PowerDVD 13
Maybe you can install this driver also on your NUC.
Give it a try.
fly_sig is offline
post #154 of 161 Old 11-18-2014, 02:18 PM
Dark_Slayer's Avatar
Quoted: 729 Post(s)
Liked: 452
Yeah, @bryansj mentioned the latest driver provided bitstreaming in windows for him. Strange as the missing pap drm is usually in the mei drivers
Of course bitstreaming has always worked in openelec, which is more of a pleasure to use as an htpc IMO
Dark_Slayer is offline
post #155 of 161 Old 11-25-2014, 01:36 PM
mismjy1's Avatar
Quoted: 17 Post(s)
No video output from DN2820FYKH
Now that I store all my media on a NAS, I bought one of these units on Amazon to serve as my HTPC. I plan to run WMC and XBMC on it.
The unit seems to be one of the newer N2830 versions based on the SA number (H22962-103). The problem is that the machine doesn't produce any video output through the HDMI port. I've tried two monitors and three different cables without success. I've also tried booting it with and without memory or SSD installed.
From what I've read online, you may not be able to get to the BIOS screen if there is no memory installed (weird as that sounds). If that is true, I'm wondering if the problem is the memory I bought?
Here's what Amazon cross-sells:
http://www.amazon.com/Crucial-PC3-12...bxgy_pc_text_y
However, I read that the N2830 supports DDR3 1333Mhz memory so I ordered this:
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
The memory fits properly in the NUC, but again I get no signs of life beyond a power light.
Am I correct that not having the memory installed can mess up the boot process? Also, does the memory I ordered look compatible with the N2830 version?
I'm debating whether to keep tinkering or declare it a lost cause and return the box. Thanks for any info or advice.
mismjy1 is offline
post #156 of 161 Old 11-25-2014, 03:18 PM
3rob3's Avatar
Quoted: 71 Post(s)
Liked: 29
I had the same exact problem. You HAVE to use low voltage memory(DDR3L). Because the video shares the memory you will not even see bios. I tried two different sticks I had and eventually had to buy another stick that specifically said low voltage. I use this one now:
mismjy1 likes this.
3rob3 is offline
post #157 of 161 Old 11-26-2014, 10:05 PM
mismjy1's Avatar
Quoted: 17 Post(s)
Thanks for the tip - that did the trick. Kind of silly mistake on my part - the Intel product page clearly states you need DDR3L and not DDR3.
mismjy1 is offline
post #158 of 161 Old 12-03-2014, 06:17 AM
fmzip's Avatar
Quoted: 47 Post(s)
Liked: 102
Hi, Could you tell me the exact components you used in this little NUC?
I'd like to make a box that will run windows (7 or 8?) and Jriver and feed it into my Oppo then out to Anthem Preamp.
Thanks for the help
fmzip is offline
post #159 of 161 Old 12-18-2014, 07:32 PM
Quoted: 435 Post(s)
Liked: 344
This thread is a bit dead, but I'm not getting much help on the kodi/xbmc website.
I've begun to have issues with VC one files- lots of dropped frames. I never had this problem before so I'm wondering what I need to do in the settings area to correct this? at least that's my thought at this point. Thanks for any help.
James
post #160 of 161 Old 01-12-2015, 03:56 AM
HDGT's Avatar
https://communities.intel.com/thread/58966
Intel 10.18.10.4061 drivers released.
HDGT is offline
post #161 of 161 Old 01-23-2015, 11:41 AM
baumi's Avatar
Liked: 0
Hi everyone,
I'm thinking about getting this NUC to use as a HTPC, but I'm a bit confused by the whole PAP/HD-Audio passthrough story in Windows.
According to a post in the Intel Forum there seems to be a fix for this issue:
communities.intel.com/message/263590#263590 (sorry, I can't post it as a link yet)
Can anyone here confirm this? Is this problem solved with the newest driver? (I can't find the mentioned Version 10.18.10.3958 on the Intel HP anymore)
baumi is offline
Reply Home Theater Computers
