How to strip DRM from WTV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 01-27-2014, 08:10 AM - Thread Starter
macman13's Avatar
I have been researching this for weeks with no success. Can someone please tell me how to either record a copy once recording without the DRM or strip the DRM from a WTV.
2x HDHomeRun Prime - 3CC
Sharp 65" TV; Sharp 46" TV; Panasonic 42" TV; Sony 40" TV; Sony 32" TV
WMC HTPC Server: Intel Celeron G1840, 4GB RAM, MSI H81M-P33, 1TB
Main HTPC: Mac Mini 2.3Ghz i5, 8GB RAM, 500GB, 1TB, 2TB, 3TB
XB360 WMC Extender, Ceton Echo, Roku 3, Apple TV 3
macman13 is offline
post #2 of 17 Old 01-27-2014, 08:19 AM
pittsoccer33's Avatar
Quoted: 648 Post(s)
Liked: 426
If someone has cracked Microsoft's encryption then they definitely haven't shared it w/ the internet.
The easiest (and only) way around it is to use a capture device like a Hauppauge Colossus or HD-PVR. Typically you'd use it with a cable box, but you could probably also capture your pc's output with it too. That will give you a DRM-free recording.
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
post #3 of 17 Old 01-27-2014, 09:04 AM
shairob's Avatar
I've actually been looking to do this for two reasons:
1. I want to run some movies thru handbrake and reduce their size on my server as well as remove some commericals and more importantly,
2. I wanted to upgrade my HTPC (which was using a Core 2 Duo)
For the last 6+ months I've had to keep two HTPCs hooked up because I can't watch these recordings on anything but the computer that recorded them (and my Xbox 360's) and its been super annoying. I've got like a year of backlog shows to go thru before I can think about retiring this PC, but then I'll still probably have to keep it around for replays (like when the wife catches an episode of House of Lies in season 3 or whatever and wants to watch it from episode 1). The only solution that I've found is to use screen capture software, but the results from that have been mixed at best with some significant A/V degradation on a few shows.
shairob is offline
post #4 of 17 Old 01-27-2014, 10:22 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
Let us know when you crack it. I have been waiting for it since 2007...
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
post #5 of 17 Old 01-27-2014, 10:33 AM - Thread Starter
macman13's Avatar
I know it has to be possible, because go anywhere on the internet and you will see shows from HBO, Starz, which should only come from a CableCARD, without encryption. I know that they weren't recorded with a PVR because they are titled HDTV which means from a digital source, other than satellite or a capture card. If they were taken from a capture card, they would be titled AHDTV as explained in this Scene ruleset:
Video taken from the decoded HD output of a set-top box (e.g. ³
³ component, DVI, HDMI) may be used as a source; source must be tagged ³
³ in dirname as AHDTV. Releases taken from a natively recorded transport ³
³ stream shall be tagged as HDTV and do not dupe AHDTV releases. AHDTV ³
³ releases do dupe HDTV. AHDTV captures must be done at the native format ³
³ of the channel, i.e. 720p or 1080i.
macman13 is offline
post #6 of 17 Old 01-27-2014, 10:41 AM
Quoted: 648 Post(s)
Liked: 426
I'm not following. Are those metadata tags used by the cable companies somewhere in the MPEG transport stream?
Also, how are shows like Game of Thrones or Homeland transmitted in other countries (I'm just asking, I have no idea)? Is there anywhere in the world that you can watch these programs with a DVB tuner? That would mean they came over a digital source without analog capture.
post #7 of 17 Old 01-27-2014, 10:54 AM
ajhieb's Avatar
Quoted: 928 Post(s)
Liked: 663
Originally Posted by macman13 View Post
I know it has to be possible...
Possible? Probably. But that doesn't mean it has been done.
You're making two big, and likely wrong assumptions to reach your conclusion...
1) That people posting material always follow the "scene" rules.
2) That the content you've listed is only available in encrypted format.
Your argument is only one step removed from "I know The Romantics did a great cover of 'I Wanna Be Sedated' because I downloaded a version of it from Napster that was labeled that way." (It wasn't The Romantics it was The Ramones but sadly most 15 year old kids at the time didn't know the difference)
But the short answer to your original question, is "no." Even if it had been done (which it hasn't) it would violate the guidelines of the forum to discuss it here anyway.
RAID protection is only for failed drives. That's it. It's no replacement for a proper backup.
ajhieb is offline
post #8 of 17 Old 01-27-2014, 11:03 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
Anyone who has come close to cracking it, publicly, has been silenced by Microsoft, and CableLABS.
If there is a crack, it would not be in a public forum, and will be distributed in a private, secured medium, that keeps the outsiders out.
post #9 of 17 Old 01-27-2014, 11:08 AM
Quoted: 648 Post(s)
Liked: 426
I assume too that if it did happen somehow, and that it was released to the wild, that Microsoft would be pushing an update to patch it in short order.
post #10 of 17 Old 01-27-2014, 11:18 AM
captain_video's Avatar
Quoted: 510 Post(s)
Liked: 336
No need to crack it. That's what torrents are for.
captain_video is online now
post #11 of 17 Old 01-27-2014, 11:18 AM
ajhieb's Avatar
Quoted: 928 Post(s)
Liked: 663
If their track record of silencing leaks regarding Windows Activation and WGA are any indicator, I'm pretty sure it would be pretty widespread news by now.
ajhieb is offline
post #12 of 17 Old 01-27-2014, 12:04 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
They could be from BD discs which is easily ripped without effort. Also, not all cable cos encrypt/copy-protect everything. Verizon FIOS only started copy-protection on premium channels middle of last year.
WMC is the only PC software today that can record CableCard programs. If the DRM is cracked, we could kiss good bye to WMC forever (as MS wanted it to already). What's the point of cracking it if you can no longer record it?
Some evils are necessary to live with. PVR/DVR is a time shifting mechanism, not movie backups.
Foxbat121 is online now
post #13 of 17 Old 01-27-2014, 01:02 PM
bryansj's Avatar
Quoted: 1123 Post(s)
Liked: 555
You are assuming wrong. That stuff is recorded with an HD capture card. I think a newer way is appearing to gain ground in capturing the "webrips" of shows from places like the Google Play store.
bryansj is offline
post #14 of 17 Old 01-28-2014, 08:38 AM - Thread Starter
macman13's Avatar
Okay, thanks
macman13 is offline
post #15 of 17 Old 08-12-2014, 07:58 PM
Liked: 0
its easy really
Someone just needs to write device drivers for a virtual video card and monitor with a program that will record anything "displayed" on the virtual monitor. Then you WMC will think you have a dual monitor setup and you just play all your shows on the virtual device.
get crackin you brilliant programmers.
stephen hoos (Rexregum) is offline
post #16 of 17 Old 08-12-2014, 08:07 PM
ajhieb's Avatar
Quoted: 928 Post(s)
Liked: 663
Your virtual display driver isn't going to be HDCP compliant so it wouldn't allow you to play back copy protected content on that virtual display. And you wouldn't be capturing the transport stream, you'd be effectively just doing screengrabs of uncompressed video frames. You'd still need to recompress it again to have it in a manageable size, so you're no better off than having just used an analog capture card, or some screen capture software.
ajhieb is offline
post #17 of 17 Old 08-12-2014, 10:39 PM
techmattr's Avatar
Quoted: 71 Post(s)
Liked: 184
The easiest way to remove the copy-once protection is to just use a capture card. FiOS had copy-once in my area on a couple shows for about 6 months then they got rid of it. That's what I did to remove it though.
techmattr is offline
Reply Home Theater Computers
