Windows 7 drops from 5.1 hdmi audio back to stereo - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 01-31-2014, 08:36 AM - Thread Starter
Chriscorv58's Avatar
Quoted: 122 Post(s)
Liked: 82
I recently learned about installing wasapi for bit perfect audio, I noticed when using xbmc I get very choppy video playback unless windows is showing 5.1 sound under my AMD Hdmi output properties. I configured windows to match my current system setting all 3 front speakers set to small and clicked the box for a subwoofer. Well everything was great for listening to 24/192 audio through foobar with wasapi plug in same with xbmc. This is where it gets strange the computer went back to 2.0 stereo and I lost my selection for 5.1 audio tried rebooting still not showing up under speaker configure in windows, any help? Thanks
Sony 940c 75" Display, Marantz AV8801, HTPC, JTR 215RM Mains & JTR 210RM Center, DIY Surrounds, Crown Xti & Cdi Amps, Seaton Submersive HP+ Master and Slave.
Chriscorv58 is offline
post #2 of 17 Old 01-31-2014, 08:51 AM
steelman1991's Avatar
Quoted: 211 Post(s)
Liked: 116
No reason to set your windows config to match anything - if WASAPI is working properly it should by-pass any windows setting.
steelman1991 is offline
post #3 of 17 Old 01-31-2014, 09:19 AM - Thread Starter
Quoted: 122 Post(s)
Liked: 82
Wasapi seems to be playing fine. I just dont understand why my windows 7 speaker settings go from 5.1 to stereo . I'm not sure what's causing the change.
post #4 of 17 Old 01-31-2014, 09:25 AM
aliaskary77's Avatar
Quoted: 46 Post(s)
Liked: 56
were you switching receiver inputs....to tv for example, then back to htpc?
aliaskary77 is offline
post #5 of 17 Old 01-31-2014, 10:02 AM - Thread Starter
Quoted: 122 Post(s)
Liked: 82
Yes....
post #6 of 17 Old 01-31-2014, 10:05 AM
Quoted: 46 Post(s)
Liked: 56
i have an amd gpu as well that was having the same problem...the switching back to stereo. it was with a denon receiver though. i throught it was an edid issue, but found out it wasnt.
what worked for me was the hdmi pin 19 tape trick. google that. it disables the hotplug detection in hdmi, so tricks htpc to thinking it doesnt lose the receiver connection.
just have to make sure receiver is set to htpc during bootup. then switching inputs on receiver wont matter anymore and you wont lose 5.1 settings options. if you reboot htpc, same thing, make sure receiver is on htpc.
post #7 of 17 Old 01-31-2014, 10:34 AM - Thread Starter
Quoted: 122 Post(s)
Liked: 82
Thanks for the tip, I would have never found that on my own. Going to try it now.
post #8 of 17 Old 01-31-2014, 06:59 PM
Quoted: 46 Post(s)
Liked: 56
any luck?
post #9 of 17 Old 01-31-2014, 07:54 PM - Thread Starter
Quoted: 122 Post(s)
Liked: 82
Well the resolution of my windows doesn't get changed when switching back to the HTPC like before but it still dropped from 5.1 back to stereo. Strangely it didn't do it the first or second time that I switched sources but after I woke the computer up.
post #10 of 17 Old 01-31-2014, 08:44 PM
Quoted: 46 Post(s)
Liked: 56
get the devcon utility here. win 7x64: http://www.itworks.sk/storage/devcon.zip
for AMD cards, the command you have to run is probably:
Code:
devcon.exe restart =display *VEN_1002*
doesnt matter when you run it, see if this brings back the 5.1 option in the sound settings. the command restarts the driver, hence redetecting whats connected to the gpu.
the pin 19 works for me, but this is for backup so i dont have to reboot with the htpc selected.
Chriscorv58 likes this.
post #11 of 17 Old 01-31-2014, 08:48 PM - Thread Starter
Quoted: 122 Post(s)
Liked: 82
Sorry for the stupid question but how do I runt he command. Thanks - ignorance is bliss.
post #12 of 17 Old 01-31-2014, 10:19 PM
Quoted: 46 Post(s)
Liked: 56
download the devcon.zip. unzip it to devcon.exe maybe to your c: drive
then go to start, type cmd and from there, right click and run cmd.exe as administrator
then go to c: drive and run the command exactly as listed above. *VEN_1002* is for AMD gpus.
if that works, let me know, and i can help with creating a click icon to run it as a batch file.
post #13 of 17 Old 01-31-2014, 10:33 PM - Thread Starter
Quoted: 122 Post(s)
Liked: 82
Its telling me its not a recognized as an internal or external command. operable program or batch file
post #14 of 17 Old 01-31-2014, 10:39 PM - Thread Starter
Quoted: 122 Post(s)
Liked: 82
It worked, i moved the .exe file in to windows32 folder and retyped the command. Back to 8 channel audio!
post #15 of 17 Old 01-31-2014, 11:19 PM
Quoted: 46 Post(s)
Liked: 56
excellent.
i created a batch file, a text file with the extension .bat instead of .txt
with your location, you can copy paste this to it:
Code:
i have my devcon.exe in d:\devcon\devcon.exe so my batch file has:
Code:
d:
cd devcon
then create a shortcut to that batch file to your desktop. double click for ease of use. i dont know if you need to go into its properties and select run as administrator.
however, with the pin 19 trick, i dont have to use this command at all since the htpc stays on 24/7. it doesnt know the receiver switched to the tv and back, so keeps this setting.
i dont let mine sleep either. i think because you do, the pin 19 trick wont work unless you have the receiver selected to htpc when coming out of sleep.
however, someone talked about running that .bat file automatically when coming out of sleep, but unless htpc is selected on receiver, i dont know how it would be any better.
post #16 of 17 Old 01-31-2014, 11:25 PM - Thread Starter
Quoted: 122 Post(s)
Liked: 82
excellent.
Code:
Code:
d:
cd devcon
Just need to figure out how to set the receiver to wake up on my HTPC and not TV. Sounds like my problem will be all fixed. I cannot thank you enough.
post #17 of 17 Old 02-01-2014, 04:46 AM
Quoted: 46 Post(s)
Liked: 56
no problem. one of those stupid little things that gets frustrating.
there are a few things you can try. while it couldnt be fixed by edid for me with a denon and sony tv, your samsung and marantz may.
look at this post: http://www.avsforum.com/t/1482693/workaround-nvidia-hdmi-audio-not-plugged-in-after-resume-from-sleep-s3-or-turning-tv-off-then-on#post_24029456
you may want to ask on this thread http://www.avsforum.com/t/1227161/edid-overrides-to-solve-bitstreaming-issues-for-ati-5xxxs referring back to our thread, if edid override is what you need, or if devcon is the way to go.
Reply Home Theater Computers
